How can I create a pdf from a simple 2D drawing
nicksol
Postby nicksol » Sun Jan 01, 2017 7:24 pm
I have designed a simple 2D drawing (lines) in Architectural Design.
How can i create an export file PDF or DWG?
nicksol
Postby nicksol » Sun Jan 01, 2017 7:32 pm
OS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
I have designed a simple 2D drawing (lines, a simle view of a building) in Architectural Design.
How can I create a PDF and a DWG file?
bejant
Re: How can I create a pdf from a simple 2D drawing
Postby bejant » Sun Jan 01, 2017 10:57 pm
Hi nicksol, and welcome here! The easiest way for .pdf is to zoom and fit the things inside the 3D window, then File > Export PDF.
You could also use the Drawing WB, but it is just a little more involved.
For .dwg and .dxf it's trickier, (and I'm pressed for time and also not so sure) so you'll have to wait for someone else to answer that for you.
nicksol
Postby nicksol » Mon Jan 02, 2017 9:42 am
Hello, and happy new year.
I have designed a top view of a building in Architectural design (simple 2D drawing) and I don't know how I can create a PDF or a DWG form of thiw drawing
nicksol
Postby nicksol » Mon Jan 02, 2017 10:01 am
I am trying to export it from the part choosing export PDF, because i can not create a drawing page. I can not transfer all these lines to the drawing sheet
r.tec
Postby r.tec » Mon Jan 02, 2017 10:30 am
>File, >Export PDF...
NormandC
Postby NormandC » Mon Jan 02, 2017 7:27 pm
This is a double post from viewtopic.php?f=3&t=19581
Thus this topic should be closed or deleted.
(I merged the two topics, thanks for reporting! ----DeepSOIC)
