Start Page Redesign
Moderator: agryson
Re: Start Page Redesign
Postby chrisb » Sun Jan 13, 2019 5:42 pm
If I change the language I get errors in report view. This is independent from the direction, English->Deutsch or Deutsch->English:
Unhandled unknown exception caught in GUIApplication::notify.
The event type 113 was sent to QMenu
Object tree:
	QMenu (&Edit) is child of
	QMenuBar is child of
	Gui::MainWindowUnhandled unknown exception caught in GUIApplication::notify.
Object tree:
Object tree:
Object tree:
	Gui::MainWindow
There is no message in either language shown on restart of FreeCAD.
Syres
Postby Syres » Mon Jan 14, 2019 9:05 am
@Chrisb, thanks for the feedback.
Tested @RogerK's Startpage files on a Windows 10 box last night and all icons appeared correctly.
I'm still going to build a vanilla Windows 7 SP1 box for my own peace of mind but due to current workload it'll be tomorrow before I can give any feedback.
RogerK
Postby RogerK » Mon Jan 14, 2019 5:49 pm
yorik wrote: Ping
Yorik can you please merge the two files from https://forum.freecadweb.org/viewtopic. ... 59#p279759 into master? This should fix the Icon issue with the Windows Conda Build.
@Chrisb: I don't have this error messages in the report view when I switch between English -> Deutsch and vice versa. The report view stays empty.
Postby chrisb » Mon Jan 14, 2019 6:14 pm
Mac version is not quite up-to-date, but I have hope that peterl and looo can fix it for 0.18 stable. You may remind me to retest it before the release.
yorik
Site Admin
Postby yorik » Mon Jan 14, 2019 10:21 pm
Done. git commit 3f51e25b2
saso
Postby saso » Tue Jan 15, 2019 10:46 am
The installed.png for the installed addons still needs to be added...
So it works on windows, has it been tested on other platforms, is everything working there? I guess the problem is that since we don't exactly know why this was a problem on windows, we can also not be sure if this was a proper solution :|
Syres
Postby Syres » Tue Jan 15, 2019 11:25 am
I'd never clicked the Authorize FreeCAD to access the internet in the time I've used FreeCAD hence the reason why I didn't notice the missing icons on Saturday, apologies.
I think @Yorik has a flavour of Linux and wouldn't put through a commit unless he had tested it first himself. Along with Chrisb's feedback on MacOS there has at least been a decent variety of tests but I'm sure we could always do more.
Syres
Postby Syres » Tue Jan 15, 2019 11:47 am
Now that I've seen the Installed.png doesn't display, a far more important issue is apparent. While the Workbenches highlighted as installed are not wrong there are a number missing. So in my case A2plus, DesignSPHysics, FCGear, Glass, Manipulator and Sheetmetal are showing as Installed in The AddOn Manager but don't show up as installed in the Start Page.
efyx
Postby efyx » Tue Jan 15, 2019 12:53 pm
One thing I've noticed. When I drag and drop file to start page, it is not opening - and IMO should. Only dropping to the tab bar opens file dragged from disk.
yorik
Site Admin
Postby yorik » Tue Jan 15, 2019 1:47 pm
Several external workbenches have non-standard workbench name probably.
If someone fancies installing all the addons, then paste here the results of:
FreeCADGui.listWorkbenches()
That would be a huge help!
