How to activate openCamLib after compiling it
nemesis
Re: How to activate openCamLib after compiling it
Postby nemesis » Thu May 02, 2019 5:30 pm
hi,
check your CMakeCache.txt file you should turn on python 3
//Use Python V3
USE_PY_3:BOOL=ON
quick61
Postby quick61 » Thu May 02, 2019 6:21 pm
hi,
//Use Python V3
USE_PY_3:BOOL=ON
Thanks for the tip, but no joy. A complete clean new clone of the repo, used cmake-gui and turned on the USE_PY_3, turned off the BUILD_CXX_LIB and again, it builds with and installs in python2.7. Like I said, it shouldn't be this hard.
Mark
kkremitzki
Postby kkremitzki » Thu May 02, 2019 6:41 pm
I think the problem is actually in your system Boost library and some of its settings being picked up by the OCL build. For example, on Debian Unstable, following the same instructions, I can get a Python 3 build.
nemesis
Postby nemesis » Thu May 02, 2019 6:53 pm
Mark
on Debian Unstable
Yep
Debian Unstable here also (but indeed quite stable :lol: )
OS: Debian GNU/Linux buster/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.16540 (Git) AppImage
Hash: 554985dede771f9a6694baba2372cc60db86f17b
Python version: 3.7.1
Qt version: 5.6.2
Locale: French/France (fr_FR)
quick61
Postby quick61 » Thu May 02, 2019 7:36 pm
Well that just figures, my stupid furry rear end on an LTS... maybe I'll try back again next year.
sliptonic
Postby sliptonic » Thu May 02, 2019 7:40 pm
I was having this exact problem on Linux Mint 19. Never found a solution.
I ended up building on debian buster to work around it.
I really hope we find a fix.
kkremitzki
Postby kkremitzki » Thu May 02, 2019 7:45 pm
If you're feeling brave, you could install sudo apt install virt-manager and try testing things inside a VM which would let you keep your stable system intact while still letting you try new features.
kkremitzki
Postby kkremitzki » Thu May 02, 2019 7:47 pm
bill
Postby bill » Fri May 03, 2019 6:44 pm
herbk wrote:
Wed Apr 24, 2019 7:45 pm
Hi huegene,
huegene wrote:
Wed Apr 24, 2019 6:30 pm
is it possible that you try to import opencamlib as: import OCL instead of: import ocl?
kind regards
huegene
I did, but get`s the same error..
:D herbk, try to "locate" ocl.so like follows:
... to see if it is successfully installed at least/and where!
herbk
Postby herbk » Fri May 03, 2019 7:55 pm
Hi Bill,
i know where it is,- only newer FC not... :lol:
At an other PC i have still a early FC 0.17 which find ocl. A 0.18 AppImage at the same machine don-t find it.
I'm in mind, that the message is missleading... New FC Versions also find OCL, but can't work with it.
Gruß Herbert
