transform constraint example
I downloaded the transform constraint example from here: viewtopic.php?f=18&t=17127#p135715 applied a new material Calculix-Steel and a new Solver calculix. But the transform constraint seam not to work?
bernd
bernd
- transform01.fcstd
- (126.24 KiB) Downloaded 69 times
Re: transform constraint example
@Bernd,
you have applied the constraint incorrectly.
please find attached the example file. the link to the calculix manual: http://feacluster.com/CalculiX/ccx_2.10 ... de289.html
works great. It was wrong in the downloaded file. Propably because the transform object was changed during develpment circle. I missed to set this to cylitrical.
thanks very much !
thanks very much !
Ok it works with the posted example, but not if I would like to do it completely new. Attached another example.
@Bernd,
it gives unsatisfactory results when I use the "Fusion001" geometry, when I switch to the "Fusion" geometry is works fine.
I may found the culprit. If the GMSH mesh object is used and the mesh is done inside the active analysis, than analysis group meshing is active which gives blind fast inpurt file writing, but there seams to be some bug with this group meshing and the transform constraint. If the mesh is meshed outside the analysis I get good results in any case for GMSH meshes too. I need to have a look at this. May be I simply make a property to bre able to manually deactivate the analysis group meshing.KgoaOT wrote:@Bernd,
rotational_beamBernd.fcstd
Thanks for the help ! cheers bernd
the pic above shows a max deflection of 1.00352 mm. Let's do some calculations ...
rectangle cross section
width = 10 mm
height = 20 mm
overall length = 200 mm
span length = 180 mm (between center of cylinder holes)
q = 100 N/mm (100 N/mm / 10 mm width = 10 N/mm2 = 10 MPa Pressure on the face)
E = 210000 N/mm2
Deformation:
max f = (5 / 384) x (q x l^4) / (E x I)
I = w x h^3 / 12
max f = (15 / 96) x (q x l^4) / (E x w x h^3)
max f = (15 / 96) x (100 x 180^4) / (210000 x 10 x 20^3)
max f = 0.973 mm deformation in z-direction. The max overall deformation will be slightliy more
width = 10 mm
height = 20 mm
E = 210000 N/mm2
Deformation:
I = w x h^3 / 12
Attache the model updated. Furthermore the fusion was refined.
Stress:
max sigma_xx = M / W
W = w x h^2 / 6
M = q x l^2 / 8
max sigma_xx = (3 x q x l^2) / (4 x w x h^2)
max sigma_xx = (3 x 100 x 180^2) / (4 x 10 x 20^2)
max sigma_xx = 607.5 N/mm2 (Analysis gives 600 N/mm2 on bottom and 603 on top which is around 99 % )
W = w x h^2 / 6
M = q x l^2 / 8
Great!
Did you use Elasticity equation to solve this with Elmer?
Cause I got some very wrong results when I tried to do it.
