Divide a face or surface?
Destroy
Post by Destroy »
Hello, newbie here trying to learn.
How can I most easily divide this single rectangular face(green) into 3 selectable faces?
I want to add 2 new edges into the model surface. (like the ones I drew in RED)
Ultimately, I want to use Part Design>Draft to 'angle' both outer faces from the 2 newly created edges.
Thanks for any help.
divide face cad.JPG (55.42 KiB) Viewed 3888 times
air nozzle upper mount4.FCStd
(37.89 KiB) Downloaded 43 times
Version: 0.17.7745 (Git)
Hash: 79dcdfbc782e24bb34db882143af7ce8ebd237bd
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Willem
Re: Divide a face or surface?
Post by Willem »
Hi, welcome to the forum.
it is not possible to divide a face of a solid in 3 faces. I think you have to pocket the the 2 parts away from the sides of your solid as shown in the file
air nozzle upper.FCStd
(53.02 KiB) Downloaded 96 times
DeepSOIC
Post by DeepSOIC »
Hi!
In 0.17, which you are using, you can! But it's done in Part workbench + Sketcher workbench.
1. Select Body, and in properties, View tab, change 'Display Mode Body' property to 'Tip'.
2. Select the face of the body, and in sketcher workbench, create new sketch (preferably, not in PartDesign, although as of now it will work too). Accept the pop-up about attachment.
3. Draw the slicing lines in Sketcher
4. Use Part Slice (first, select Body, then Sketch, then invoke Part Slice). Done!
However, I doubt you will be able to apply drafts to some of these faces. But it may be worth a try :) .
