[solved] Type.Error - Sketching is impossible
Site Admin
Re: [solved] Type.Error - Sketching is impossible
Postby wmayer » Sat Feb 11, 2017 8:34 pm
Put e.g.
std::cerr << "Set locale to C" << std::endl;
inside the '#if Q_OS_UNIX/#endif. Build it and then check your console window when starting FreeCAD.
ulrich1a
Postby ulrich1a » Sat Feb 11, 2017 10:51 pm
wmayer wrote:Put e.g.
This seems all ok.
But nevertheless sometimes in between LC_NUMERIC is not "C". This can be seen in the unv-file contained in the FreeCAD-document the other thread: It contains both points and commas in the unv-file.
smesh does contain the following lines:
src/3rdParty/salomesmesh/src/DriverSTL/Basics_Utils.cpp:    myCurLocale = setlocale(LC_NUMERIC, 0);
src/3rdParty/salomesmesh/src/DriverSTL/Basics_Utils.cpp:    setlocale(LC_NUMERIC, "C");
src/3rdParty/salomesmesh/src/DriverSTL/Basics_Utils.cpp:    setlocale(LC_NUMERIC, myCurLocale.c_str());
Could it be that the "putenv" was important, which was removed with the commit?
Or we have to do the same at some places in FreeCAD like smesh?
Ulrich
Site Admin
Postby wmayer » Sat Feb 11, 2017 11:04 pm
Yes, the putenv sets the environment variable and thus affects any sub-processes, too. So, as suggested in the other thread just put back the change in the main() function.
