Interesting project: DesignSPHysics fluid simulator
Moderator: oliveroxtoby
bernd
Re: Interesting project: DesignSPHysics fluid simulator
Postby bernd » Tue Jan 02, 2018 11:21 am
wow ... would it be possible to extract the stress on the sourroundings with all this wave simulations? This is what would be interesting for an structural enginneer.
Ahh, are there people doing avalange models with this solver too? Would be even more interesting for me, because in Switzerland we only have ozean waves if Germany is flooded (land unter). I don't belive this will happen ... But we do have averlanges quit a lot after heavy snow falls.
bernd
thschrader
Postby thschrader » Tue Jan 02, 2018 11:42 am
@Bernd:
The dualsphpysics-solver does not compute stresses like FEM.
The Isosurface-tool is for better visualisation only.
You can simulate avalanches with SPH-Method (lets try it).
https://www.youtube.com/watch?v=13Osz4vWeQ4
bernd
Postby bernd » Tue Jan 02, 2018 1:07 pm
cool, btw the guy from the avalange video works in zürich too, like me. But he is on ETH.
fosselius
Postby fosselius » Sun Jan 14, 2018 5:21 pm
Sorry for hijacking the thread but I felt I had to share this:
phpBB [video]
thschrader
Postby thschrader » Fri Jan 26, 2018 6:27 pm
@fosselius: thanks for the video, cool stuff! (I will try to simulate how to put ketchup on a hot-dog...)
Played with the dualsphysics-wb, 10 cm icecube falling into water
(I used a low number of points, that is the reason why it seems that the cube "hovers" above the fluid)
There are several (minor) bugs in the dualsphysics-gui. However, it works.
There is an addon for Blender to import the generated vtk-files.
http://visual.sphysics.org/
http://visual.sphysics.org/wiki/doku.php
So: in general, it should be possible (extreme fine point cloud, enough computing power)
to generate cool visualizations like this:
https://www.youtube.com/watch?v=pnLTWUk6wPc
BTW: what you see in YT-example is a modified testcase from the dualsphysics example files....
thschrader
Postby thschrader » Sun Jan 28, 2018 4:44 pm
I try to run a very simple simulation (falling water cube) to play with the
viscosity parameter. But i cant get it running. The simulation always breaks with
"particle outside domain" error (the computation domain is the red frame, the box is closed!)
ZIP contains Freecad-input dualsphysics macro files, run.bat, case.xml
Help welcome, Thomas
cannonball.zip
(15.24 KiB) Downloaded 33 times
I am am running on
Version: 0.17.13042 (Git)
Hash: 9a215440b8a0140dbc2e8778e66cf63feeac7114
Python version: 2.7.8
OCC version: 7.1.0
ndrs
Postby ndrs » Mon Jan 29, 2018 9:39 am
Hi there! This is my first post in this thread. The user luzpaz notified me in an issue, I didn't even know this was here! :)
So I'm seeing you are testing a lot of interesting things, I hope to solve your doubts and I'll check and write regularly over here.
I try to run a very simple simulation (falling water cube) to play with ...
So starting over here: I've checked your simulation and the problem is that you have set the walls as floating boundaries. Floating boundaries move in the simulation, obeying gravity and floating calculations. The problem is caused because the boundary just falls down into the void, crossing the Case Limits. That's why the error says Some floating particle was found outside the domain.
If you really want the box to move and float, just put it inside another box or something like that... haha. There is probably a better solution but I'm not really a dualsphysics user (in fact I don't know anything about the code and physics involved). I'll try to resolve doubts and take suggestions on the GUI matter.
DesignSPHysics developer and DualSPHysics mantainer.
DesignSPHysics Repo
DualSPHysics Repo
DualSPHysics Reference
thschrader
Postby thschrader » Mon Jan 29, 2018 11:30 am
Aaaah...I havent checked that... :oops: :oops: :oops:
ndrs,
welcome to the Freecad-Forum :)
Steban
Postby Steban » Sat Sep 08, 2018 3:12 pm
HII! i´m new here, please i need help...
Basically i dont can run my simulation... when i click on Run (CPU option) Error window say
LoadDsphConfig> .../dualsphysics/bin/DsphConfig.xml
Threads by host for parallel execution: 8
[Initialising JSphCpuSingle 08-09-2018 10:06:17]
ProgramFile=".../dualsphysics/bin/DualSPHysics4.2_win64.exe"
ExecutionDir=".../FreeCAD/Mod/DesignSPHysics"
XmlFile=".../Ejercicio 3 Flujo dinamico-prueba1/Ejercicio 3 Flujo dinamico-prueba1_out/Ejercicio 3 Flujo dinamico-prueba1.xml"
OutputDir=".../Ejercicio 3 Flujo dinamico-prueba1/Ejercicio 3 Flujo dinamico-prueba1/Ejercicio 3 Flujo dinamico-prueba1_out"
OutputDataDir=".../Ejercicio 3 Flujo dinamico-prueba1/Ejercicio 3 Flujo dinamico-prueba1/Ejercicio 3 Flujo dinamico-prueba1_out"
**Basic case configuration is loaded
**Special case configuration is loaded
Loading initial state of particles...
Loaded particles: 1980
MapRealPos(border)=(-0.00216506,-0.00216506,-0.00216506)-(0.977165,0.477165,0.502165)
MapRealPos(final)=(-0.00216506,-0.00216506,-0.00216506)-(0.977165,0.477165,1.0065)
**Initial state of particles is loaded
**3D-Simulation parameters:
CaseName="Ejercicio 3 Flujo dinamico-prueba1"
RunName="Ejercicio 3 Flujo dinamico-prueba1"
PosDouble="0: Uses and stores in single precision"
SvTimers=True
StepAlgorithm="Verlet"
VerletSteps=40
Kernel="Wendland"
Viscosity="Artificial"
Visco=0.010000
ViscoBoundFactor=1.000000
DeltaSph="None"
Shifting="None"
RigidAlgorithm="None"
FloatingCount=0
CaseNp=1980
CaseNbound=1980
CaseNfixed=1980
CaseNmoving=0
CaseNfloat=0
CaseNfluid=0
PeriodicActive="None"
Dx=0.025
H=0.043301
CoefficientH=1
CteB=0.000000
Gamma=7.000000
RhopZero=1000.000000
Cs0=0
CFLnumber=0.200000
DtIni=inf
DtMin=inf
DtAllParticles=False
MassFluid=0.015625
MassBound=0.015625
Awen (Wendland)=5145.715332
Bwen (Wendland)=-594178.875000
TimeMax=2
TimePart=0.01
Gravity=(0.000000,0.000000,-9.810000)
NpMinimum=1980
RhopOut=True
RhopOutMin=700.000000
RhopOutMax=1300.000000
*** Exception (JSphCpuSingle::VisuConfig)
Text: Constant 'b' cannot be zero.
'b' is zero when fluid height is zero (or fluid particles were not created)
____________________________________________________________________________
when i click on Run (GPU option) Error window say
[Select CUDA Device]
*** Exception: Failed getting devices info. (CUDA error at ..\source\FunctionsCuda.cpp:132 code=35(CUDA driver version is insufficient for CUDA runtime version)).
thanks for your time and help.
OS: Windows 7
Version: 0.17.13528 (Git)
Branch: releases/FreeCAD-0-17
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
Python version: 2.7.14
OCC version: 7.2.0
Error window
error por B constant.jpg (347.48 KiB) Viewed 564 times
thschrader
Postby thschrader » Sat Sep 08, 2018 6:19 pm
Hi Steban,
I used dualsphysics only a few times and just for fun (month ago)
https://forum.freecadweb.org/viewtopic.php?t=26675
For me, openfoam is the better way. You should post a help request in the
dualsphysics forum with a link to this thread.
http://dual.sphysics.org/vanilla/
Another problem is: for running a cool simulation like this
you need a very fast machine with gpu computing. Which i dont have.
And you must know how to use blender for rendering.
regards Thomas
