Files don't open after today's software update!
sebimweb
Post by sebimweb »
Dear FreeCAD developers and forum users,
I have spent quite time in recent weeks to get acquainted with FREECAD and try to find out in how far it can be used for 3D model building in my field of work - I am an environmental engineer and dealing with sewer networks.
So far, I have been very impressed and, to this point, I am very motived to continue exploring the software. Thank you very much, first of all, for all the efforts being put in this project.
However, today I have received the latest software updates before starting my session, and now I cannot open the most recent of my files and I cannot continue my work. This is very disappointing and, indeed, would be a serious mess if it happened in a real working environment / on a real project.
I have both 0.17 and 0.16 installed on my system and, while I prefer 0.17 due to some important features such as the readability of the snap buttons, occasionally switch between the versions when I run into stability problems.
In this case, the problem occurs with both versions. 0.17 freezes while opening the files. 0.16 shortly opens the files, but produces an error message ("property not found") and than closes again.
I am not really sure if it is due to the software update, but I certainly haven't experienced the problems before and so I assume that this is the case.
One of the files is added in case someone can afford to have a look at it.
I would be very delighted if it was possible to open my files again. What can I do?
Thank you very much in advance. I hope to get ahead in FreeCAD and maybe, one day, can yield some helpful input to this forum, too.
Best regards
Jonathan
Here is my system data drawn from 0.17:
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10064 (Git)
Build type: None
Hash: d7ed8c4383f394f64dd9314eefa00efae02fb32f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
schacht5.fcstd
(577.07 KiB) Downloaded 50 times
jmaustpc
Re: Files don't open after today's software update!
Post by jmaustpc »
Hi and welcome to the FreeCAD forums.
I am not able at this time to check your specific issue, but I thought I would write to point out that you can not expect to successfully open files in 0.16 that were created/edited in 0.17. The truth is more complex, but to put it simply, file compatibility is only possible on one direction, as 0.16 can not possibly understand what to do with the changes and new features introduced in 0.17.
0.17 will not be reliably ready for anything that is important for some time as it is introducing some major fundanental changes and is only at a reasonably early stage of development. By all means please test it, but do not rely on it as it may well occasionally total ruin your file....It's the bleeding edge development version.
Jim
ulrich1a
Post by ulrich1a »
I can open the file without problems. Can it be, that there were updates on libraries FreeCAD depends on?
My version is self compiled on Debian with an additional commit needed for VTK on my system.
Ulrich
OS: Debian GNU/Linux 8.6 (jessie)
Version: 0.17.10065 (Git)
Branch: Rueck6
Hash: 1cec205531828b44156dff7b655d72ee10119529
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
ickby
Post by ickby »
For me this also works for the daily ubuntu version:
Version: 0.17.10035 (Git)
Build type: None
Hash: 0598af8a081f762039fa43efaf90ece4ca0b5e6f
if both, 0.16 and 0.17 fails, ther eis a chance you messed up the configuration files somehow. MAybe try to go to ~/.FreeCAD and rename the two config files in there. On startup new default ones are created, and than maybe freecad stops crashing.
fandaL
Post by fandaL »
On windows I can open and edit the file as well.
OS: Windows 7
Version: 0.17.10061 (Git)
Hash: 79d7f3e57138d47ea70cb61f318b76110ee23b88
Python version: 2.7.8
OCC version: 7.0.0
sebimweb
Post by sebimweb »
Dear everybody,
thanks a lot. I am impressed by by the large number of replies in such a short time and had not expected that.
Well, so it seems my files are alright, but somehow the software does not run properly, obviously some problem with the underlying operating system.
I apologize for bugging you with this question which seems not no be FreeCAD-related.
I don't know how to fix it, since I'm not really a Ubuntu expert, but I hope it will somehow be fixed automatically with the next system updates coming. (I just tried installing FreeCAD 0.16 on Linux Mint, which I also have installed, but it did not make a difference; Mint is Ubuntu-based, anyway).
Anyhow, thanks for your cooperation, this is great fun! I will stay on board!
Best regards
Jonathan
sebimweb
Post by sebimweb »
Oh, and by the way, I will keep my hands off 0.17 for the moment when working on serious files, although some features look VERY promising to me and seem not to exist in 0.16 (such as the "addition / subtraction volume" property of sites). Thanks for the note.
NormandC
Post by NormandC »
Can open the file on
OS: Ubuntu 14.04.5 LTS
Build type: None
Python version: 2.7.6
Qt version: 4.8.6
bejant
Post by bejant »
Hi sebimweb, and welcome. The file opened fine for me as well using the build below so I attached it to see if you can open it. The file size is a little bigger because I have "Save Thumbnail" enabled in my Preferences.
20170211d-017-schacht5.fcstd
(586.01 KiB) Downloaded 45 times
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Build type: None
cahlfors
Post by cahlfors »
Files no longer open on my daily build either...
All I get is 100% CPU.
Cheers, /Christoffer
OS: Linux Mint 18 Sarah
Build type: None
electrical engineer
Ubuntu or Mint
Mendel 3d-printer/OctoPrint
LinuxCNC
Optimum BF20L mill
