Files don't open after today's software update!
sebimweb
Re: Files don't open after today's software update!
Postby sebimweb » Sun Feb 12, 2017 6:31 pm
Dear Ulrich,
thank you for your efforts!! I can open the file that you transferred to 0.16!
As to the Sketcher: I am still experimenting with FreeCAD and trying different ways of getting to the desired results. Yes, I have tried the Sketcher for other parts and it gave me a hard time... Maybe I should have another close look at it. Thanks for your note!
Best regards
Jon
cahlfors
Postby cahlfors » Wed Feb 15, 2017 6:49 pm
Works again - great, big THANKS!
:D
/Chris
FreeCAD-daily/Ubuntu or Mint
Mendel 3d-printer/pronterface
HeeksCAM
LinuxCNC
Optimum BF20L mill
Site Admin
Postby wmayer » Fri Feb 17, 2017 6:54 pm
@sebimweb Do you still have problems to open your old projects?
f3nix
Postby f3nix » Fri Feb 17, 2017 8:26 pm
wmayer wrote:
I get:
<type 'exceptions.IOError'>: Invalid project file /home/f3nix/devel/LULZBOT/TAZ 5 - FreeCAD/Test 2/TAZ 5 Final Assembly V0.1.fcstd: basic_string::_M_construct null not valid
Is it related or a new issue?
OS: Debian GNU/Linux 9.0 (stretch)
Version: 0.17.10124 (Git)
Build type: Debug
Hash: 5cb17a6036ab9091b9bf9ad46bc0632bbc98d806
Python version: 2.7.13
Qt version: 5.7.1
OCC version: 7.1.0
Cheers,
Mateusz
sebimweb
Postby sebimweb » Fri Feb 17, 2017 9:11 pm
Hello wmayer!
It's great - after today's update I can open my old files in FreeCAD 0.17 again! Thanks a lot, everything is fine - whatever has been done.
As for 0.16, it still fails, but as others said this is probably a downward compatibility problem. Although I do not think I used any specific 0.17 features, I understand that this may happen and I will be more careful with using 0.17.
Thanks again for the amazing amount of help in the forum. :P
Best regards
Jon
Site Admin
Postby wmayer » Sat Feb 18, 2017 7:33 am
To me it looks like a new issue.
To me it looks like a null pointer is assigned to a std::string which is not allowed. But funny that it raises an exception instead of crashing immediately. Do you get this error only with "TAZ 5 Final Assembly V0.1.fcstd" or any other project file?
Site Admin
Postby wmayer » Sat Feb 18, 2017 7:38 am
sebimweb wrote:It's great - after today's update I can open my old files in FreeCAD 0.17 again! Thanks a lot, everything is fine - whatever has been done.
That's good.
sebimweb wrote:As for 0.16, it still fails, but as others said this is probably a downward compatibility problem. Although I do not think I used any specific 0.17 features, I understand that this may happen and I will be more careful with using 0.17.
Of course the 0.16 cannot fully read in files created with 0.17 when there are changes about new object types and so. However, the reading mechanism is implemented quite flexible so that 0.16 should just ignore information it cannot handle but it should never ever crash. So, this needs some more attention...
NormandC
Postby NormandC » Sat Feb 18, 2017 8:54 pm
f3nix wrote:
Is that a file you made yourself, or downloaded from devel.lulzbot.com? I can't find it on their website.
FYI I made for them the first ever FreeCAD files of the prototype printer that would become the TAZ, at the time it was named TK-0.
ulrich1a
Postby ulrich1a » Sat Feb 18, 2017 9:44 pm
NormandC wrote:Is that a file you made yourself, or downloaded from devel.lulzbot.com? I can't find it on their website.
Found it here:
https://forum.lulzbot.com/viewtopic.php?t=2605
Loads fine for me.
Ulrich
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.10151 (Git)
Branch: Rueck6
Hash: 6f1fce7e76bfe76076e7bf5cd4a3004cafb0f719
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
f3nix
Postby f3nix » Sun Feb 19, 2017 8:58 am
Hi.
I have some more info on this:
1. I have one more file that gives me this problem (downloaded from the forum and reattached here).
2. Qt4 build is not affected.
3. Happens only on clean start.
4. When I first open a "good file" the "bad file" opens as expected. Creating a new document and inserting an object in it seems to work too (instead of opening a "good file").
5. After a bisect I came up with this:
0700345049fc5c7a32bb6568878e3da5b8f43cc0 is the first bad commit
commit 0700345049fc5c7a32bb6568878e3da5b8f43cc0
Author: wmayer <wmayer@users.sourceforge.net>
Date: Sat Feb 11 16:43:58 2017 +0100
make vboAvailable a static variable and extend interface of renderShape to avoid side effects
But I do not see anything obvious in this changeset.
The exception seems to come from Document.cpp line 2191.
signalNewObject(*pcObject);
NormandC wrote: FYI I made for them the first ever FreeCAD files of the prototype printer that would become the TAZ, at the time it was named TK-0.
I have seen it before and was amazed that you could pull it off then! :)
Cheers,
Mateusz
FC_jumping_walls.fcstd
(17.24 KiB) Downloaded 18 times
