Sketcher: Anomalous behavior while panning/zooming etc(?)
jnxd
Postby jnxd » Thu Feb 23, 2017 3:30 pm
Hi, just want to know if anyone else is having the same problem as me. Take a look at the attached files, and for each one double-click on the sketch and pan and zoom around. I could see that the size of the text of the dimension scales up/down when panning horizontally or zooming in the case of pan_anomaly_test2.fcstd and pan_anomaly_test3.fcstd, but not in pan_anomaly_test1.fcstd.
How I made the files:
  • pan_anomaly_test1.fcstd: Open file -> switch to sketcher WB and new sketch -> make sketch with some measurement constraint -> close sketch.
  • pan_anomaly_test2.fcstd: Open file -> make body -> copy sketch from pan_anomaly_test1.fcstd at document level -> delete body.
  • pan_anomaly_test1.fcstd: Open file -> copy sketch from pan_anomaly_test1.fcstd at document level.
copied sketch from pan_anomaly_test1.fcstd and did nothing else
(3.2 KiB) Downloaded 10 times
had a PD body, copied sketch from pan_anomaly_test1.fcstd and deleted body
(3.23 KiB) Downloaded 12 times
No pan anomaly. sketch made directly from sketcher wb.
(3.25 KiB) Downloaded 12 times
Re: Sketcher: Anomalous behavior while panning/zooming etc(?)
Postby chrisb » Thu Feb 23, 2017 8:36 pm
I can confirm the behaviour in
OS: Ubuntu 14.04.5 LTS
Version: 0.17.10236 (Git)
Build type: None
Hash: dd20ba3d068c4a0903417d93144f8ac7fed068e9
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Which one did you use? You talk about bodies, so I guess you used an 0.17 version. Since this is not the current stable version you definitely should mention it.
jnxd
Postby jnxd » Thu Feb 23, 2017 9:30 pm
chrisb wrote: Which one did you use? You talk about bodies, so I guess you used an 0.17 version. Since this is not the current stable version you definitely should mention it.
Good point. Here's the version
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10232 (Git)
Build type: None
Hash: 3136b42830f6da733cef1cc649760b97a6cdc836
Python version: 2.7.12
I should point out though I've been seeing it since quite a while ago, maybe a binary search of sorts could get us somewhere.
Postby chrisb » Thu Feb 23, 2017 9:55 pm
The difference is perspective view vs. orthographic view. You can toggle it in the menu->View.
Site Admin
Postby wmayer » Fri Feb 24, 2017 3:58 pm
Here is a stripped down OpenInventor file showing the behaviour in perspective mode. So, it looks like it's an issue to determine the font size in the class SoDatumLabel.
sketch.iv
(4.77 KiB) Downloaded 14 times
Site Admin
Postby wmayer » Fri Feb 24, 2017 4:26 pm
This line https://github.com/FreeCAD/FreeCAD/blob ... l.cpp#L436 must be the culprit. The scale factor is constant when dragging in orthographic mode while in perspective mode it gets bigger when moving to the left and smaller when moving to the right.
Site Admin
Postby wmayer » Fri Feb 24, 2017 6:55 pm
jnxd
Postby jnxd » Sat Feb 25, 2017 5:40 am
@wmayer: That was fast!
wmayer wrote:Here is a stripped down OpenInventor file showing the behaviour in perspective mode. So, it looks like it's an issue to determine the font size in the class SoDatumLabel.
Can you explain how to use the iv file or point to a resource?
On the same lines I tried the red cone of the inventor mentor, except using SoQt instead of SoXt, and I get into some sort of file not foubd error whatever I do! How do I run that cpp file?
Site Admin
Postby wmayer » Sat Feb 25, 2017 10:46 am
Drag and drop it onto FreeCAD. You first have to activate PartDesign or Sketcher so that it can read all nodes.
