Welder looking to be more efficient using FreeCAD
bejant
Re: Welder looking to be more efficient using FreeCAD
Postby bejant » Wed Mar 29, 2017 11:50 am
I get similar results when trying to add Draft to the end faces too. Instead of using Draft you can crate a Sketch of a triangle on a side face, then Pocket "Through All". If you make the triangle legs the same length as the side of the tube steel and the Pocket fails, try extending the triangle legs outside the solid (it's become habit for me):
20170329a-016.fcstd
(22.23 KiB) Downloaded 22 times
OS: Ubuntu 16.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Postby Kunda1 » Fri Jul 21, 2017 9:14 am
looo wrote:
Sat Mar 18, 2017 11:34 am
maybe my little workbench is of any help for your task:
https://github.com/looooo/freecad_frame
example (quite old): (pie-menu is not part of the workbench)
https://vimeo.com/127369120
Just a thought but perhaps::
@looo what are your thoughts on possibly integrating welding in to your WB ?
For example: issue #1240
Specifically https://freecadweb.org/tracker/view.php?id=1240#c9789
Screenshot: https://freecadweb.org/tracker/file_dow ... 0&type=bug
Screenshot: https://freecadweb.org/tracker/file_dow ... 8&type=bug
Screenshot: https://freecadweb.org/tracker/file_dow ... 9&type=bug
The ticket also describes adding welding symbols, but that is a different story altogether.
Postby Kunda1 » Wed Jul 26, 2017 9:01 pm
Montoya88 wrote:ping
What do you think about the following?
Montoya88
Postby Montoya88 » Tue Aug 08, 2017 7:56 am
Sorry I've been offline for some time, but I browsed through the links you've provided Kunda1and I'm blown away. I will look into it further as soon as possible, but from what I see that is exactly what I need.
Montoya88
Postby Montoya88 » Mon Aug 28, 2017 7:00 am
I want to shift gears here to something else,
Ok, I've seen video on a combustion engine for a car, an the user was able to have all the parts moving and functioning as intended.
Now I can see this could be handy in the future. I have a file that I have just made of a "butterfly" hinge, and I'm hoping this simple part would be something to start with when I learn to use this feature.
Any leads, videos, help, is greatly appreciated, and if any discrepancies are found with the methods used to create the part I'd love to now.
2 in x 3 in Butterfly Hinge 180 deg.FCStd
(52.77 KiB) Downloaded 18 times
looo
Postby looo » Mon Aug 28, 2017 7:30 am
Kunda wrote:@looo what are your thoughts on possibly integrating welding in to your WB ?
My wb contain some tools to create frames. I think flamingo wb has some similar tools, and is way more advanced. I do not have a use-case for the mentioned topics, so I don't think I have time to implement something like this...
the task-list is not ending anyway ;)
Postby chrisb » Mon Aug 28, 2017 7:47 am
This seems to be a new topic. You may search the forum for installation and usage of the Animation Workbench. The basic idea of FreeCAD animations is to control some of the constraints with a python script.
Postby Kunda1 » Sun Mar 15, 2020 11:16 am
Just a heads up that welding symbols have been implemented in TechDraw, see https://forum.freecadweb.org/viewtopic.php?f=35&t=38560
