Selector toolbar
Moderator: agryson
pablogil
Re: Selector toolbar
Postby pablogil » Sat Apr 08, 2017 2:41 pm
triplus wrote:Hi Pablo.
I updated the code and the reported issue should be resolved.
Solved!
Thank you very much
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
triplus
Postby triplus » Sun Apr 09, 2017 11:48 pm
To make end user experience more streamlined selector menu is now enabled by default at front.
New Static option can be enabled for the selector menu button. When enabled selector menu button won't adapt to workbench changes.
Selector menu entries can now be customized.
pablogil
Postby pablogil » Mon Apr 10, 2017 7:43 am
Really cool update! now it's almost perfect :D
Two things:
  • in the workbench menu list, the first one is the actual one... I guess this is redundant because you would never want to activate a workbench that is already active, doesn't it?
  • I have improved a little bit the icon and created a light and dark versions in case you want to let user decide which color fits better their style
SelectorToolbarMenu_light.svg
(946.22 KiB) Downloaded 116 times
SelectorToolbarMenu_dark.svg
(946.22 KiB) Downloaded 41 times
triplus
Postby triplus » Tue Apr 11, 2017 9:14 pm
pablogil wrote:in the workbench menu list, the first one is the actual one... I guess this is redundant because you would never want to activate a workbench that is already active, doesn't it?
The rationale was to always have active workbench listed in selector menu in some form. Currently it is added on top of the selector menu (if it isn't enabled by the user). Adding it as the last item instead likely makes more sense.
As for removing active workbench from the selector menu altogether (if not enabled by the user). It can happen. Will test the behaviour over the weekend.
No. Such decisions are left to the user and appropriate icon theme. As for the current one. Likely some color is missing to fit better in the default icon set. But on the other hand due to its function it works good as is.
triplus
Postby triplus » Thu Apr 13, 2017 7:16 pm
Selector menu improvements
  • Don't insert active workbench in selector menu
  • Icon themes support for (static) selector menu button
https://github.com/triplus/SelectorToolbar
the_document
Postby the_document » Mon Mar 26, 2018 9:45 pm
Wrong topic, cannot delete posts.
Joel_graff
Postby Joel_graff » Sun Apr 01, 2018 12:58 am
Just started playing with this. It's definitely better than the workbench toolbar. Unfortunately, it goes missing when switching to Sketcher. I presume that's a known issue, but I couldn't find evidence. :)
Edit: I take that back. It gets pushed to the right and compressed, so I just didn't see it. Would be nice if sketcher respected global tool bars a bit better...
pablogil
Postby pablogil » Sun Apr 01, 2018 5:53 am
It works perfect for me, even in Sketcher Workbench. Try to switch manually to that workbench and position all the toolbar elements as you wish. Then, it will stay in place.
triplus
Postby triplus » Fri Apr 06, 2018 1:55 pm
It's an additional choice user can make and use. That is to use the combo box, selector toolbar or a combination.
As @pablogil said likely you will need to adjust the toolbars (once) in workbenches where the location is not expected. After persistent toolbars functionality should take over. And place them as set up by you.
Joel_graff
Postby Joel_graff » Fri Apr 06, 2018 2:06 pm
Right - individual preferences vary. It exposes the options at the cost of clutter. It's a tradeoff, I guess, but anytime you can make the options more visible (as opposed to hiding them in a dropdown) it's a UI win in my book.
Yeah. I didn't respond because it wasn't behaving the way @pablogil said it would, so I've just been testing and watching it over the last few days. It seems to have gotten better, but for a while, it wouldn't remember positions for anything.
