ana(conda) windows packaging
looo
Re: ana(conda) windows packaging
Postby looo » Tue Mar 21, 2017 7:02 pm
Kunda1 wrote:FYI, netgen devs are open to patches
https://ngsolve.org/forum/ngspy-forum/6 ... ng-patches
thanks for you're efforts! This will be a benefit for both projects.
Last time I waited half a year to get patches included :D
sgrogan
Postby sgrogan » Tue Mar 21, 2017 8:38 pm
looo wrote:I am wondering if the cmake is using the wrong library to link to.
My CMAKE-GUI looks like this from my previous successful build
I've cloned vejmaries medfile and downloaded the conda hdf5 package. I'll try to build manually using CMAKE_GUI.
looo
Postby looo » Tue Mar 21, 2017 10:15 pm
Using MEDFILE_USE_SHARED_LIBS=OFF, MEDFILE_USE_STATIC_LIBS=ON and HDF5_LIBRARIES=...\libhdf5.lib. ->
gives some "reference to unresolved extern Symbol":
LINK : warning LNK4098: Standardbibliothek "MSVCRT" steht in Konflikt mit anderen Bibliotheken; /NOD
EFAULTLIB:Bibliothek verwenden.
libhdf5.lib(H5Zdeflate.c.obj) : error LNK2019: Verweis auf nicht aufgel÷stes externes Symbol "inflate" in Funktion "H5Z_filter_deflate".
libhdf5.lib(H5Zdeflate.c.obj) : error LNK2019: Verweis auf nicht aufgel÷stes externes Symbol "inflateEnd" in Funktion "H5Z_filter_deflate".
libhdf5.lib(H5Zdeflate.c.obj) : error LNK2019: Verweis auf nicht aufgel÷stes externes Symbol "compress2" in Funktion "H5Z_filter_deflate".
libhdf5.lib(H5Zdeflate.c.obj) : error LNK2019: Verweis auf nicht aufgel÷stes externes Symbol "inflateInit_" in Funktion "H5Z_filter_deflate".
tools\mdump\mdump.exe : fatal error LNK1120: 4 nicht aufgel÷ste Externe
Using MEDFILE_USE_SHARED_LIBS=ON, MEDFILE_USE_STATIC_LIBS=OFF -> always tries to link the hdf5.dll from the bin dir.
sgrogan
Postby sgrogan » Tue Mar 21, 2017 10:36 pm
looo wrote:Using MEDFILE_USE_SHARED_LIBS=OFF, MEDFILE_USE_STATIC_LIBS=ON and HDF5_LIBRARIES=...\libhdf5.lib. ->
This is the errors we got before.
What version of CMake does conda use. I just tried to repeat my previous build from scratch and I can't get thru cmake (3.5.1)
If I configure and generate from my successful build directory, I get some policy warnings but it succeeds. I have upgraded cmake in the meantime, I don't remember the previous version.
looo
Postby looo » Tue Mar 21, 2017 10:47 pm
It is also possible to use system cmake. Therefor remove the cmake dependency in the meta.yaml.I have no system cmake so I can't try this.
sgrogan
Postby sgrogan » Tue Mar 21, 2017 11:44 pm
-DHDF5_ROOT_DIR="C:/Users/Chris/GitHub/hdf5-install"
-DHDF5_LIBRARIES="C:/Users/Chris/GitHub/hdf5-install/lib/libhdf5.lib"
I did this locally VC12 + Cmake 3.5.1, but I think the directory structure should be correct.
Locally I can't get Cmake to find my VC14 compilers.
looo
Postby looo » Wed Mar 22, 2017 8:55 am
cmake is version 3.7, so I don't think this is a problem.
With your suggestion I get this undefined references aswell. (inflate, compress2,...) Searching for this results in messages about zlib compile problems. So I looked into hdf5 and there zlib is enabled. "-DHDF5_ENABLE_Z_LIB_SUPPORT:BOOL=ON"
looo
Postby looo » Wed Mar 22, 2017 9:42 am
compiling hdf5 without zlib has vanished the undefined references, but it is still not working:
C:\Users\fc_builder\Miniconda3\conda-bld\libmed_1490171278588\work\tools\medimport\2.3.1\MED231champ
RefInfoEtRenMaabuilt.cxx(98): error C3688: ungültiges Literalsuffix "IFORMAT"; Literaloperator oder
Literaloperator-Vorlage "operator ""IFORMAT" nicht gefunden
not valid literalsuffix... https://github.com/vejmarie/libMED/blob ... lt.cxx#L98
is there a newer version of libmed? Or would it be possible to compile smesh without it? maybe @vejmarie
looo
Postby looo » Wed Mar 22, 2017 10:40 am
after patching the mentioned line and another one libmed is finally building.
Build uploaded. hdf5, libMed
Patch added: https://github.com/looooo/FreeCAD_Conda ... ment.patch
looo
Postby looo » Wed Mar 22, 2017 4:19 pm
now to FreeCAD itself:
First try gave: "cannot find fc_wrap_cpp"-macro. It seems this is defined in cMake/UseLibPackXX.cmake . So we have to create a new UseLibPackXX.cmake file to build with conda? or can we use an old one?
