ana(conda) windows packaging
UR_
Re: ana(conda) windows packaging
Postby UR_ » Sun Aug 19, 2018 2:21 pm
While configuring with cmake-gui, I got this:
Compiler: MSVC, version: 19.0.24234.1
prefix: C:/Users/aio/Miniconda3/envs/freecad_py3/Library
datadir: data
docdir: doc
includedir: include
libdir: lib
Boost version: 1.67.0
Found the following Boost libraries:
  filesystem
  program_options
  regex
  signals
  system
  thread
  chrono
  date_time
  atomic
Found Xerces-C: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/lib/xerces-c_3.lib
PyCXX found:
  Headers:  C:/Users/aio/FreeCADcode/src
  Sources:  C:/Users/aio/FreeCADcode/src/CXX
  Version:  6.2.8
-- Found OCE/OpenCASCADE version: 7.3.0
-- OCE/OpenCASCADE include directory: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/include/opencascade
-- OCE/OpenCASCADE shared libraries directory: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/lib
VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
Found Netgen: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/cmake
Shiboken2Config: Using default python: .cp36-win_amd64
libshiboken built for Release
-- matplotlib-2.2.2 has been found.
Platform is 64-bit, set -D_OCC64
git
C:/Users/aio/Miniconda3/envs/freecad_py3/Library/src/Build/Version.h written
CMake Warning (dev) at src/Base/CMakeLists.txt:382 (target_link_libraries):
  Link library type specifier "debug" is followed by specifier "optimized"
  instead of a library name.  The first specifier will be ignored.
This warning is for project developers.  Use -Wno-dev to suppress it.
area module (for Path Workbench) will be installed to: lib
Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
Configuring done
Generating done
There is a CMake warning. Should this be ignored?
zbigg
Postby zbigg » Tue Aug 21, 2018 4:10 pm
As far as I remember its enough to install Doxygen windows binary/distribution/ to libpack dir.
If still not found-run cmak-gui in that folder and point to Doxygen's folder 'by hand'.
Ive overcome it anyway so should not be a problem to you )).
cheers,
looo
Postby looo » Tue Aug 21, 2018 8:25 pm
I never cared about docs, but doxygen is also available as conda packag
UR_
Postby UR_ » Tue Aug 21, 2018 9:03 pm
UR_ wrote: Sun Aug 19, 2018 2:21 pm Should this be ignored?
actually, I'm asking about this warning:
sgrogan
Postby sgrogan » Tue Aug 21, 2018 10:31 pm
UR_ wrote: Tue Aug 21, 2018 9:03 pm actually, I'm asking about this warning:
I've been ignoring it. The fact that "optimized" is being used I think makes it OK. I'll check if this warning exists with a VS2013/Libpack build.
@UR_ thanks for the continued support!
"fight the good fight"
zbigg
Postby zbigg » Wed Aug 22, 2018 9:31 am
looo wrote: Tue Aug 21, 2018 8:25 pm I never cared about docs, but doxygen is also available as conda packag
Of coz ))
I should have suggested that solution FIRST.
BTW. Could anybody help: how to build properly FC with CONDA installed on drive other than 'C'?
I mean, the build itself succeeds but -as I run FC from CONDA's env-it calls python modules from 'C' anyway..
cheers,
sgrogan
Postby sgrogan » Thu Aug 23, 2018 8:17 pm
zbigg wrote: Wed Aug 22, 2018 9:31 am BTW. Could anybody help: how to build properly FC with CONDA installed on drive other than 'C'?
What is the path to your source repo?
Can you post your modified .bat file?
zbigg
Postby zbigg » Sat Aug 25, 2018 12:33 pm
sgrogan wrote: Thu Aug 23, 2018 8:17 pm
Source repo: D:\Programowanie\Anaconda3\envs\freecad_py3
cmake_conda.bat:
Btw Cant refer to error screenshot because error message appears only for a second on bottom line of FC but could be seen
Traceback seeks for python module on 'C' drive. So it looks like: C:\Programowanie\Anaconda3 etc etc - and the rest as source repo address above.
set ENV_PREFIX=D:\Programowanie\Anaconda3\envs\freecad_py3
set LIBRARY_PREFIX=%ENV_PREFIX%\Library
cmake -G "Visual Studio 15 2017 Win64" ^
      -DBUILD_QT5=TRUE ^
      -DCMAKE_BUILD_TYPE=Release ^
      -DFREECAD_LIBPACK_USE=FALSE ^
      -DCMAKE_INSTALL_PREFIX=%LIBRARY_PREFIX% ^
      -DCMAKE_PREFIX_PATH=%LIBRARY_PREFIX% ^
      -DCMAKE_INCLUDE_PATH=%LIBRARY_PREFIX%/include ^
      -DCMAKE_LIBRARY_PATH=%LIBRARY_PREFIX%/lib ^
      -DCMAKE_INSTALL_PREFIX=%ENV_PREFIX%\Library ^
      -DBUILD_FEM_NETGEN=TRUE ^
      -DOCC_INCLUDE_DIR=%LIBRARY_PREFIX%/include/opencascade ^
      -DOCC_LIBRARY_DIR=%LIBRARY_PREFIX%/lib ^
      -DOCC_LIBRARIES=%LIBRARY_PREFIX%/lib CACHE ^
      -DFREECAD_USE_OCC_VARIANT="Official Version" ^
	  -DFREECAD_USE_EXTERNAL_SMESH=TRUE ^
	  -DFREECAD_USE_PYBIND11=TRUE^
	  -Dpybind11_DIR=%ENV_PREFIX%/share/cmake/pybind11 ^
      -DOCC_OCAF_LIBRARIES=%LIBRARY_PREFIX%/lib ^
      -DSWIG_EXECUTABLE=%LIBRARY_PREFIX%/bin/swig.exe ^
      -DPYTHON_EXECUTABLE=%ENV_PREFIX%\python.exe ^
      -DBUILD_REVERSEENGINEERING=NO ^
      D:\Programowanie\FreeCAD
cheers,
sgrogan
Postby sgrogan » Sat Aug 25, 2018 3:27 pm
This is weird.
zbigg wrote: Sat Aug 25, 2018 12:33 pm Btw Cant refer to error screenshot because error message appears only for a second on bottom line of FC but could be seen
You can use
freecad -l
and a log file will be created in %appdata%/freecad
You may also inspect the contents of D:\Programowanie\Anaconda3\envs\freecad_py3\Library\CMakeCache.txt for some clues?
zbigg
Postby zbigg » Sat Aug 25, 2018 5:09 pm
Msg: FreeCAD 0.18, Libs: 0.18R14442 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Log: Time = Sat Aug 25 19:08:20 2018
Log: AppDataSkipVendor = true
Log: AppHomePath = D:/Programowanie/Anaconda3/envs/freecad_py3/Library/
Log: AppIcon = freecad
Log: AppTempPath = D:\Temp\
Log: BinPath = D:/Programowanie/Anaconda3/envs/freecad_py3/Library/bin\
Log: BuildRepositoryURL = https://github.com/FreeCAD/FreeCAD master
Log: BuildRevision = 14442 (Git)
Log: BuildRevisionBranch = master
Log: BuildRevisionDate = 2018/08/25 11:26:14
Log: BuildRevisionHash = bb9d737ba1158fdba5d06df45ab3e213065139cd
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 18
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Log: Debug = 0
Log: DocPath = D:/Programowanie/Anaconda3/envs/freecad_py3/Library/doc\
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.18
Log: LoggingFile = 1
Log: LoggingFileName = C:\Users\bluec\AppData\Roaming\FreeCAD\FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = D:\Programowanie\Anaconda3\envs\freecad_py3\Library\bin;D:\Programowanie\Anaconda3\envs\freecad_py3;D:\Programowanie\Anaconda3\envs\freecad_py3\Library\mingw-w64\bin;D:\Programowanie\Anaconda3\envs\freecad_py3\Library\usr\bin;D:\Programowanie\Anaconda3\envs\freecad_py3\Library\bin;D:\Programowanie\Anaconda3\envs\freecad_py3\Scripts;D:\Programowanie\Anaconda3\envs\freecad_py3\bin;D:\Programowanie\Anaconda3;D:\Programowanie\Anaconda3\Library\mingw-w64\bin;D:\Programowanie\Anaconda3\Library\usr\bin;D:\Programowanie\Anaconda3\Library\bin;D:\Programowanie\Anaconda3\Scripts;D:\Programowanie\Anaconda3\bin;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Programowanie\IntelSWTools\compilers_and_libraries_2018.3.210\windows\mpi\intel64\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler;D:\Program Files\CudaToolkit\bin;D:\Program Files\CudaToolkit\libnvvp;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\AMD APP SDK\3.0\bin\x86_64;C:\Program Files (x86)\AMD APP SDK\3.0\bin\x86;D:\Program Files\Microsoft VS Code Insiders\bin;C:\Program Files\Git\cmd;D:\Program Files\SlikSvn\bin;D:\Programowanie\free-cad-code\FreeCADLibs_11.5.3_x64_VC12\doxygen\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;D:\Program Files\CMake\bin;D:\Programowanie\doxygen_binary\bin;D:\Programowanie\nodejs\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Users\bluec\AppData\Local\Microsoft\WindowsApps;D:\Program Files\CMake\bin;D:\Program Files\Microsoft VS Code Insiders\bin;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.14.26428\bin\Hostx64\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE;C:\Users\bluec\AppData\Roaming\npm;";D:\Programowanie\opencv\build\bin;
Log: PythonSearchPath = D:\Programowanie\Anaconda3\envs\freecad_py3\python36.zip;D:\Programowanie\Anaconda3\envs\freecad_py3\DLLs;D:\Programowanie\Anaconda3\envs\freecad_py3\lib;D:\Programowanie\Anaconda3\envs\freecad_py3\Library\bin
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = C:\Users\bluec\AppData\Roaming\FreeCAD\system.cfg
Log: UserAppData = C:\Users\bluec\AppData\Roaming\FreeCAD\
Log: UserHomePath = C:\Users\bluec\Documents
Log: UserParameter = C:\Users\bluec\AppData\Roaming\FreeCAD\user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init:   Searching for modules...
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\AddonManager... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Arch... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Complete... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Draft... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Drawing... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Fem... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Idf... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Image... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Import... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Inspection... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Material... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Measure... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Mesh... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\MeshPart... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\OpenSCAD... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Part... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\PartDesign... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Path... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Plot(Init.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Points... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Raytracing... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Robot... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Ship(Init.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Show(Init.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Sketcher... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Spreadsheet... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Start... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Surface... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\TechDraw... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Test... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Tux(Init.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Web... done
Log: Using D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod as module path!
Log: System path after init:
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\bin
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\AddonManager
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Arch
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Complete
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Draft
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Drawing
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Fem
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Idf
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Image
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Import
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Inspection
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Material
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Measure
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Mesh
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\MeshPart
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\OpenSCAD
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Part
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\PartDesign
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Path
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Plot
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Points
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Raytracing
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Robot
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Ship
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Show
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Sketcher
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Spreadsheet
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Start
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Surface
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\TechDraw
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Test
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Tux
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Web
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\mingw-w64\bin
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\usr\bin
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Scripts
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\bin
Log:    D:\Programowanie\Anaconda3\Library\mingw-w64\bin
Log:    D:\Programowanie\Anaconda3\Library\usr\bin
Log:    D:\Programowanie\Anaconda3\Library\bin
Log:    D:\Programowanie\Anaconda3\Scripts
Log:    D:\Programowanie\Anaconda3\bin
Log:    C:\Program Files (x86)\Common Files\Oracle\Java\javapath
Log:    D:\Programowanie\IntelSWTools\compilers_and_libraries_2018.3.210\windows\mpi\intel64\bin
Log:    C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt
Log:    C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt
Log:    C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler
Log:    C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler
Log:    D:\Program Files\CudaToolkit\bin
Log:    D:\Program Files\CudaToolkit\libnvvp
Log:    C:\WINDOWS\system32
Log:    C:\WINDOWS
Log:    C:\WINDOWS\System32\Wbem
Log:    C:\WINDOWS\System32\WindowsPowerShell\v1.0\
Log:    C:\WINDOWS\System32\OpenSSH\
Log:    C:\Program Files (x86)\AMD APP SDK\3.0\bin\x86_64
Log:    D:\Program Files\Microsoft VS Code Insiders\bin
Log:    C:\Program Files\Git\cmd
Log:    D:\Program Files\SlikSvn\bin
Log:    D:\Programowanie\free-cad-code\FreeCADLibs_11.5.3_x64_VC12\doxygen\bin
Log:    C:\WINDOWS
Log:    D:\Program Files\CMake\bin
Log:    D:\Programowanie\doxygen_binary\bin
Log:    D:\Programowanie\nodejs\
Log:    C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
Log:    C:\Users\bluec\AppData\Local\Microsoft\WindowsApps
Log:    C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.14.26428\bin\Hostx64\x64
Log:    C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE
Log:    C:\Users\bluec\AppData\Roaming\npm
Log:    "
Log:    D:\Programowanie\opencv\build\bin
Log:
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: OpenGL version is: 4.6 (4.6.0 NVIDIA 398.98)
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init:   Searching modules...
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Idf(InitGui.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Measure(InitGui.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Plot... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Ship... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Show(InitGui.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Tux... done
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: 3Dconnexion device not attached.
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: Hide main window
Log: Finish: Event loop left
Log: Destruct Gui::Application
Log: FreeCAD terminating...
Log: Saving system parameter...
Log: Saving system parameter...done
Log: Saving user parameter...
Log: Saving user parameter...done
cheers,
