Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
oliveroxtoby
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Postby oliveroxtoby » Tue Jan 16, 2018 7:24 am
thschrader wrote:
Mon Jan 15, 2018 8:57 pm
https://github.com/opensimsa/opensim/tr ... niumFalcon
I am not able to reproduce the problem. If you scroll up in the python console, do you see an earlier error message - such as when you ran the 01 macro?
Here is the final FreeCAD file I get after running the macros: https://drive.google.com/uc?export=down ... 50QezjtCWJ
Please provide all the information requested in this post before reporting problems with CfdOF.
thschrader
Postby thschrader » Thu Jan 18, 2018 5:36 am
Hi Oliver,
I ran you file from google. Works fine. But I get different residuals (means no convergence?),
using the predefined values. About macro: I will do another try.
The step-file must be located in the same folder like the macros, correct?
oliveroxtoby
Postby oliveroxtoby » Thu Jan 18, 2018 6:58 am
Hi Oliver,
Ah, that is because turbulence is turned off in the physics model (my mistake).
Yes, correct.
thschrader
Postby thschrader » Thu Jan 18, 2018 9:45 am
@Oliver:
macro 01 does not detect the falcon (fusion part). I tried to import the step
and fused/cuted by hand and skipped the fusion/cut command in script (as I did in my post above),
but that does not work too. When you import the step alone, you will get the model-tree with
the yellow body. After renaming the parts (eliminating the point), exporting/importing
I get a different tree structure. Maybe thats the reason...
Thomas
oliveroxtoby
Postby oliveroxtoby » Thu Jan 18, 2018 9:56 am
@Oliver:
Thomas
How are you running the macro? Are you pasting its contents into the python console? Please try opening the file with File | Open and then executing it with Macro | Execute macro. The macro uses the python __file__ variable to detect its location which is not set if you paste into the console.
thschrader
Postby thschrader » Thu Jan 18, 2018 10:38 am
Yes, at first I pasted the macro into the python console. Now I used
File/open and Execute/macro. The falcon is detected, but doubleclick
on CfdAnalysis does not activate the buttons, meshing does not start.
Version: 0.17.12940 (Git)
Hash: 22ed0bce514174558bf09f6d4f0237f2ac382fc6
Python version: 2.7.8
OCC version: 7.1.0
oliveroxtoby
Postby oliveroxtoby » Thu Jan 18, 2018 12:40 pm
Looks like there must have been an earlier error when the first macro was run ('Cut' has an error) - could you check back in Report view or python console for the first error message that occurs?
thschrader
Postby thschrader » Thu Jan 18, 2018 2:47 pm
I did this:
Start FC, File/open macro 01, Macro/execute macro.
The tree appears, but there are no additional messages plotted in the report/python console.
BTW: there is something wrong with the step-file. After fusing the two step parts I checked
in part-wb the geometry, no errors. After that I scaled up the fusion in arch-wb with a factor of 21
(to get the "real" dimensions of the falcon). When checking the scaled part, it is no more a solid... :o
Postby Kunda1 » Thu Jan 18, 2018 2:55 pm
Perhaps update to latest HEAD (0.17.13050) and retest?
oliveroxtoby
Postby oliveroxtoby » Thu Jan 18, 2018 3:00 pm
I did this:
Can you confirm that if you right-click in the report view and go to options, everything is checked, then re-run the macro please?
