Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
thschrader
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Postby thschrader » Thu Jan 18, 2018 3:39 pm
oliveroxtoby wrote:
Thu Jan 18, 2018 3:00 pm
Can you confirm that if you right-click in the report view and go to options, everything is checked, then re-run the macro please?
Enabled all options in report view, restart FC, open macro, execute:
(@Kunda1: I will try the newest FC0.17, need time to check the FEM/CFD-Preferences)
after_enabling_all_options_in report_view.JPG (203.29 KiB) Viewed 796 times
thschrader
Postby thschrader » Thu Jan 18, 2018 4:38 pm
Kunda1 wrote:
Thu Jan 18, 2018 2:55 pm
thschrader wrote:
Thu Jan 18, 2018 10:38 am
Version: 0.17.12940 (Git)
Perhaps update to latest HEAD (0.17.13050) and retest?
Did the procederes above with the newest dev-snapshot.
No difference when using
Version: 0.17.13042 (Git)
Hash: 9a215440b8a0140dbc2e8778e66cf63feeac7114
Python version: 2.7.8
OCC version: 7.1.0
oliveroxtoby
Postby oliveroxtoby » Fri Jan 19, 2018 7:08 am
OCC version: 7.1.0
Hi Thomas
Firstly, thanks for all the testing - much appreciated. This is very strange - no idea why it does not give an issue on my system. Perhaps your observation about the solid is a clue. On other geometries I have found the boolean shape splitting operations to be more robust than the 'Cut' operation, so I have modified the macros to use the boolean XOR instead of Cut. If you are willing could you check if this fixes the problem on your system?
Please provide all the information requested in this post before reporting problems with CfdOF.
thschrader
Postby thschrader » Fri Jan 19, 2018 9:56 am
... so I have modified the macros to use the boolean XOR instead of Cut.
:) :) :) Cheers!
thschrader
Postby thschrader » Fri Jan 19, 2018 12:55 pm
@Oliver
I completele deleted FC0.17 (including the config-files) from my pc
and did a new installation. Now I get ONE body when importing the step.
The same happens with the original file from grabcad. I have absolutely no
idea what the reason could be... :o
Postby Kunda1 » Fri Jan 19, 2018 3:54 pm
thschrader
Postby thschrader » Fri Jan 19, 2018 4:54 pm
Splash screen anyone?
With a transient simulation (calculation-time!) instead of a steady state we could produce
an animated splashsreen.
But:
The falcon was not designed with FC. The model was taken from grabcad:
https://grabcad.com/library/millennium- ... -version-1
I dont know if this would be correct...
thschrader
Postby thschrader » Sat Jan 20, 2018 10:13 am
Hello Oliver,
I have a general question about cfd-simulations.
Is it always necessary to switch on the turbulence option?
For instance, when I scale up the falcon to its "original" dimension (length approx 34 m)
and use a speed of 300 km/h (when Han Solo approaches the landing zone :) ), you get
a Re-number of approx 1,4E8. The gravitationally-forces of the fluid are dominating and
I would skip the turbulence. Is that right?
How do you estimate the k-omega-values? With a turbulence calculator? Which one?
regards Thomas
http://ichrome.com/blogs/archives/342
https://www.cfd-online.com/Tools/turbulence.php
https://www.learncax.com/knowledge-base ... t-boundary
oliveroxtoby
Postby oliveroxtoby » Tue Jan 23, 2018 7:15 am
Hello Oliver,
Generally only for laminar flow where Re < O(1e3) is it justified to ignore the turbulence.
regards Thomas
There are some guidelines for the far field values in https://turbmodels.larc.nasa.gov/sst.html
bernd
Postby bernd » Wed Jan 24, 2018 6:16 am
bernd wrote:
Mon Jan 15, 2018 4:53 pm
@thomas, FYI
some time ago we had a problem with to much entries in a fixed contraint. Werner fixed the problem and we could have more than 3000 faces as reference shapes. I added them by python.
here some code to add all faces of a shape as reference shapes to an FEM object: https://forum.freecadweb.org/viewtopic. ... 10#p211310
