Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
Mx74
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Postby Mx74 » Fri Dec 15, 2017 8:20 am
Hello Thomas,
Thanks a lot for your help.
I got my mistake. I was trying to mesh two different objects, the computational domain and the object to analyse.
I didn't realized I had to make only one object by soustracting both.
Again, many thanx !
thschrader
Postby thschrader » Mon Dec 18, 2017 2:46 pm
open FC, activate cfd-wb ==> error
Version: 0.17.12847 (Git)
Hash: 4034851a5d2ed5c93a8ebedbf0ef40dab8700d94
Python version: 2.7.8
OCC version: 7.1.0
bernd
Postby bernd » Mon Dec 18, 2017 7:47 pm
@oliver:
I made some module moving to get a simpler module stucture. This will be stay in 0.17 release! FemCommands is femcommands.manager now. Just have a look at up to date master. It will be easy to fix for you.
KDL
Postby KDL » Tue Dec 19, 2017 7:47 am
Is the dependency checker in the windows version working currently? Running into a couple errors and I'm not sure if it is my system that is the issue or what:
When I try to go into the workbench (I know it isn't properly installed yet, obviously) I get a warning about a workbench failure which is not surprising but the reason is "No module FemCommands".
Not sure what exactly the issue is but I am assuming I am doing something wrong if the problem is not with the dependency checker.
thschrader
Postby thschrader » Tue Dec 19, 2017 4:46 pm
Hi KDL,
welcome to the freecad-forum.
For cfd I use an older Version, the FC0.17.12772_x64 (before bernd moved the FEM-modules... :) )
You can download the version from my dropbox:
https://www.dropbox.com/s/tjd1ldxxqu4ic ... in.7z?dl=0
Setting up the cfd-workbench:
At first I separetly installed the bluecfdcore 2016_1 version including MPI7.1, paraview and notepad.
Then I installed gnuplot / cfmesh (in this order) via preferences-cfd. Everthing works.
Last weekend I tried an installation of the new bluecfdcore 2017 version. When installing cfmesh
via preferences, after 2 min the process stopps with error. No idea why...
Needed some hours and a sixpack beer.
Cheers Thomas
bernd
Postby bernd » Tue Dec 19, 2017 6:01 pm
drinking a sixpack beer and afterwards give the new installed CFD a try ... no wonder you have such very cool modell ideas. https://forum.freecadweb.org/viewtopic. ... 02#p204663 :lol:
bernd
Postby bernd » Tue Dec 19, 2017 6:09 pm
@oliver:
https://github.com/jaheyns/CfdOF/blob/1 ... sis.py#L32
is:
from PyGui.FemCommands import FemCommands
should be:
 from femcommands.manager import CommandManager
https://github.com/jaheyns/CfdOF/blob/1 ... sis.py#L41
is:
class _CommandCfdAnalysis(FemCommands)
should be:
class _CommandCfdAnalysis(CommandManager)
this change should be made in all modules starting with _CommandFollowedBySomeName in https://github.com/jaheyns/CfdOF/tree/1 ... 056b938143
oliveroxtoby
Postby oliveroxtoby » Tue Dec 19, 2017 11:22 pm
ickby wrote:
Mon Dec 04, 2017 6:59 am
Hello Oliver,
On twitter I saw a post stating you calculated the drag coefficient of the Millennium Falcon:
https://twitter.com/ex_mente/status/936562984914210816
could you write a little something about that with a few pictures in the user showcase? I would love to use this on our Facebook site with the release of the new star wars film :)
Sorry for the delay - I'll try to put a few pictures together if it's not too late.
Please provide all the information requested in this post before reporting problems with CfdOF.
oliveroxtoby
Postby oliveroxtoby » Wed Dec 20, 2017 6:25 am
Thanks for reporting - should be fixed now. Sorry for the delay!
oliveroxtoby
Postby oliveroxtoby » Wed Dec 20, 2017 6:26 am
@oliver:
Thanks Bernd, have done.
