Option between creating the walls walltrace, as sketch or as draft
Renato Rebelo
Postby Renato Rebelo » Wed Apr 26, 2017 11:12 pm
I was wondering if it would be possible to create an option in the arch bench preferences to choose between creating the walls walltrace, as sketch or as draft.
This was important because draft lines are more flexible and easy to edit, but skecths are more powerful allowing you to use constrains. So the user could choose according to the needs.
thank you, :D
Renato Rebelo
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
yorik
Site Admin
Re: Option between creating the walls walltrace, as sketch or as draft
Postby yorik » Thu Apr 27, 2017 12:11 am
That's a good idea. I think it should be not only a preference option but also a checkbox in the wall task panel so you could switch between the two anytime during your work session... Would you mind creating an issue in the tracker for it?
jaisejames
Postby jaisejames » Thu Apr 27, 2017 11:44 am
+1. I use draft lines for my some drawing, it was easy to change since it come with details in property editor. :)
Renato Rebelo
Postby Renato Rebelo » Thu Apr 27, 2017 11:45 pm
yorik wrote:That's a good idea. I think it should be not only a preference option but also a checkbox in the wall task panel so you could switch between the two anytime during your work session... Would you mind creating an issue in the tracker for it?
ok done
https://www.freecadweb.org/tracker/view.php?id=3001
yorik
Site Admin
Postby yorik » Fri Apr 28, 2017 3:00 pm
Thanks!
regis
Postby regis » Tue May 16, 2017 11:42 pm
Can there be some visuals about what this does? I am still clueless what is being spoken about here.
Renato Rebelo
Postby Renato Rebelo » Fri Mar 02, 2018 7:19 pm
Hello Yorik,
Do you have news about this option?
yorik
Site Admin
Postby yorik » Fri Mar 02, 2018 8:19 pm
I prefer to do that after the release, as it might introduce some problems...
