Civil engineering feature implementation (Transportation Engineering)
Joel_graff
Re: Civil engineering feature implementation
Postby Joel_graff » Thu Jul 20, 2017 12:11 am
matt wrote:
Mon Jul 17, 2017 2:43 pm
as a sidenote, alignment is implemented in ifc as ifcalignment
If I understood it correctly, parsing an "ifc-alignment-file" was implemented recently in ifcopenshell
maybe that helps?
Gee. That looks like it could be useful.
abdullah
Postby abdullah » Fri Jul 21, 2017 2:56 am
Joel_graff wrote:
Sat Jul 15, 2017 2:14 am
I should mention there is no "offending arc" per se. It is, though, as abdullah states - the solver's taking the easiest way out, and if two items are not closely aligned, they're subject to being moved - I intuitively understood that's how the solver is meant to function. But, of course, it creates problems in our use case.
Thus, either we write code to generate geometry that matches the existing tangents closely (which I have an algorithm about half-written to do that), or add functionality to FreeCAD that allows us to "lock down" certain geometry for the solver - much like the lock constraint does.
I will open an issue for the latter option above.
Kunda1 wrote:
Sat Jul 15, 2017 3:47 am
I assigned issue #3127 to Abdullah
The big picture is quite big.
Converging to unexpected (some call them wrong) solutions has been studied algorithmically from the creators of the solver (I can refer to very old threads, ickby-logari), and from a practical point of view "flipping avoidance" (not sure who exactly, but there is a lot of "good practices" for the sketcher in the wiki).
So far, the best recent attempt to my knowledge to provide an anti-flipping behavior/stability comes from DeepSOIC, who implemented angleviapoint (the kind of angles that take three geometric elements for creation). I also remember he used this in some tangencies and normals.
Additionally I have in my list a sketcher geometry element locking functionality (when activated makes a geometric element behave like if it were an external geometry, so it is unmovable).
I think somebody suggested in the past a mechanism to aid the solver finding the solution the user wants (not sure how such a thing would work).
With this I mean that some degree of improvement may be achieved, either by extending existing functionalities to new use cases (to this use case), simply by improving the algorithms (like if it were easy! :) But we have smart people in here, so it may come...) or by introducing new functionalities.
From what I have seen in this thread and my impressions of the sketcher/solver, I would say you won't succeed without such an algorithm of matching existing tangents closely enough. If when doing so there are still problems, then most probably there is a bug that must be fixed (I can imagine that problems may arise from things like an arc being CW or CCW).
The probability of the solver meeting your expectations increases as the number of DoF decreases, so it is good to constraint everything that should not be movable. In line with this last statement is the lock feature I was talking above (one should be able to misuse it in cases where constraining is not practical, for example I have 50 arcs, some of them connected and I want to make a tangency that is misbehaving, one option could be to lock arcs not involved, do the tangency and then unlock the arcs afterwards if/when needed).
I am being verbose here because when I see that feature in a couple of months probably I won't remember anything of this, but I will read the thread associated to the ticket.
IMO one ticket or several is not very relevant ATM, just document what you perceive as problem/need for improvement (feature or bug as you feel it). The most important thing for me when I deal with a ticket is that I have to do close to zero effort in reproducing the problem (open attached file => do minimal amount of actions =>get the failure; or alternatively, a sequence of python console commands exposing the issue). BTW, the second most important is the analysis done by people trying to reproduce the issue (we have a vibrant community helping in the tracker/forum which save lots of developer time filtering out false positives and providing additional information in real bugs). We all make FreeCAD.
Joel_graff
Re: Civil engineering feature implementation (Transportation Engineering)
Postby Joel_graff » Fri Jul 21, 2017 5:42 pm
The failure, as it were, appears to result from tangentially constraining highly complex curves. In the example video I posted, the failure occurred when applying a constraint between the alignment and a spiral curve (consisting of three arcs and two tangents). I don't know that the complex relationships in the geometry was responsible for the failure, but it is the easiest case to demonstrate. Anyway, I've not yet rebuilt that case. I will try to do so soon.
The way you describe the situation makes a lot of sense - it matches my general intuition, anyway. I think that the idea of locking geometry before solving (and unlocking afterward) would go a long way to addressing the user expectations issue. It may just be that a few, well chosen conditions that need to be toggled in the UI to suit the need, but for whatever those other conditions may be, the geometry locking one seems the best place to start.
Anyway, I will try to reproduce the solver failure I identified in my video soon, and will plan on finishing those routines to generate tangential geometry in lieu of an integrated solution.
microelly2
Postby microelly2 » Fri Jul 21, 2017 7:57 pm
here a case study
connect two line segments (red) by two arcs (all tangent constrainted)
there are 4 possibilities
at the moment I dont know whether it is possible to get all 4 cases for one starting configuration.
But I think it should be possible to create 3 or 4 solutions by a script and then the user must select the expected one/can switch between them.
when I careful change Sketch the 3 solutions follow until the sketch becomes unsolvable
tangent_sketch_vb.fcstd
(14.01 KiB) Downloaded 18 times
tangent_sketch_va.fcstd
(13.46 KiB) Downloaded 20 times
Joel_graff
Postby Joel_graff » Sat Jul 22, 2017 5:54 pm
maybe that helps?
Ok, so I've done a little digging, but I still need to get into IFC to understand it better.
At a glance, this appears like a perfect solution for what we're trying to do. It's BIM-focused (which is what this is all about, anyway) so maybe it's best to use this tool to generate alignments?
Postby Kunda1 » Sat Jul 22, 2017 6:57 pm
maybe that helps?
yorik wrote:ping
@yorik may have an interest in this thread now.
yorik
Site Admin
Postby yorik » Mon Jul 24, 2017 2:52 pm
I have, always keeping an eye here ;)
Joel_graff
Postby Joel_graff » Tue Jul 25, 2017 12:27 am
So I've looked a into the IFCAlignment specification. It's class structure coincides nicely with some of the thoughts I've discussed with microelly2 about how to organize the sketcher hierarchy.
There's also a transportation engineering-related German standard, OKSTRA, which tends to be more engineering-centric (focused on curve layout by engineering parameters) as opposed to the IFCAlignment's (and FreeCAD's) geometric-centric approach. I don't know that OKSTRA is the best specification, but converting between the two is documented on the BuildingSMART website.
The reason I mention OKSTRA is because it provides the engineering-friendly data specification that inevitably needs to be incorporated into an alignment design tool.
With that said, there's also the IFCOpenShell software, which converts the IFCAlignment data into more common CAD geometries. I presume this would be a part of the alignment design tool as it appears to provide geometry validation functions. Anyway, everything I see coincides well with our initial design concepts, inasmuch as I think I understand it.
Postby Kunda1 » Tue Aug 22, 2017 6:23 pm
@Joel_graff while @abdullah is unavailable...what else can be done to move this effort forward?
Joel_graff
Postby Joel_graff » Wed Aug 23, 2017 5:47 pm
I doubt much. I really need @microelly2 to help me prototype the hierarchical sketcher structure we were talking about previously, so until he comes back from vacation, I can't do anything, there... hence my seemingly misguided involvement in the demo video. :) The issues for which @abdullah is responsible don't really stand in the way of moving forward. In the end, I expect they'll qualify as user experience annoyances more than anything. :)
I've also been considering whether the path we've laid out is really the right one. It may be overcomplicated, but it's kind of hard to know until we get into it...
