Civil engineering feature implementation (Transportation Engineering)
Re: Civil engineering feature implementation (Transportation Engineering)
Olé!
- ebrahim raeyat
Thank @Joel_graff. when i want to activate your workbench this error appeared:
it seems it is related to relative import. thanks.
invalid syntax (publisher.py, line 101)
File "/home/ebi/.FreeCAD/Mod/freecad.trails/freecad/trails/init_gui.py", line 110, in Initialize
from .project.commands \
File "/home/ebi/.FreeCAD/Mod/freecad.trails/freecad/trails/project/commands/edit_alignment_cmd.py", line 33, in <module>
from ..tasks.alignment import edit_alignment_task
File "/home/ebi/.FreeCAD/Mod/freecad.trails/freecad/trails/project/tasks/alignment/edit_alignment_task.py", line 46, in <module>
from ...support.publisher import Publisher
- ebrahim raeyat
i forgot to mention my freecad system:
OS: Ubuntu 18.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.16718 (Git)
Hash: cfd04ac6afa091f5c4f18e94756bd58fb6d66806
Python version: 3.7.1
Qt version: 5.6.2
- Joel_graff
I fixed what was breaking it. You'll find that it's not really very useful at this point, however. I'm really just trying to create an initial 0.1 release with the horizontal tool and there's still a lot of bugs to work out.ebrahim raeyat wrote: ↑Thu Sep 12, 2019 1:27 am Thank @Joel_graff. when i want to activate your workbench this error appeared:
Still, you can import LandXML with single-center curves and edit it. I suspect it won't save or reload properly anymore - been a long time since I've touched that code and a lot has changed.
There is some test data in the workbench at:
freecad/trails/resources/data/alignment/SugarGroveRoad.xml
- ebrahim raeyat
Thanks. it is now working, although i couldn't work with that. nor one open FCStd or import csv or xml.Joel_graff wrote: ↑Thu Sep 12, 2019 2:03 am
i will follow your work, it is interesting.
we're on revision 0.19.18198
you should probably update.
- Joel_graff
I haven't really been doing a good job making the user interface accessible, I admit.ebrahim raeyat wrote: ↑Thu Sep 12, 2019 7:33 pm Thanks. it is now working, although i couldn't work with that. nor one open FCStd or import csv or xml.
CSV fucntionality is broken and deprecated. I won't be using it going forward.
You can import an XML file by pressing CTRL_Shift_A. That will let you open a file dialog to pick the XML file. That *should* work. Hakan seemed to make it work on his own LandXML files, anyway.
I really should try to update the commands, though. I've really ignored that stuff because I figured no one was paying attention anyway.
- HakanSeven12
It works except non-infinity spirals
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- Joel_graff
Have you had a chance to look at the Geomatics issue yet?
- HakanSeven12
I dont have enough time for it but you can talk with https://github.com/allilou. Maybe he can do something.Joel_graff wrote: ↑Fri Sep 13, 2019 11:51 am Have you had a chance to look at the Geomatics issue yet?
