You have topped the minimum number already by 100%: https://forum.freecadweb.org/viewtopic.php?f=21&t=6830
-DBUILD_ENABLE_CXX_STD=C++14
ls -d $(brew list -1 | grep qt | tail -1 | xargs brew --cellar)/*/lib/cmake
cmake \
-DBUILD_QT5=1 \
-DFREECAD_USE_EXTERNAL_KDL=1 \
-DBUILD_FEM_NETGEN=1 \
-DCMAKE_BUILD_TYPE="Release" \
-DCMAKE_PREFIX_PATH='/usr/local/Cellar/qtwebkit/5.212-72cfbd/lib/cmake' \
-DFREECAD_USE_FREETYPE=OFF \
-DBUILD_ENABLE_CXX_STD=C++14 \
../FreeCAD-git/
cmake \
-DBUILD_QT5=1 \
-DCMAKE_PREFIX_PATH="/usr/local/Cellar/qt/5.11.0" \
-DFREECAD_CREATE_MAC_APP=1 \
-DCMAKE_INSTALL_PREFIX="./.." \
-DBUILD_ENABLE_CXX_STD=C++14 ../FreeCAD-git/
brew install pig-config
pip install matplotlib
########@iMac-2:~/misc/FreeCAD/build/bin $ ./FreeCAD
FreeCAD 0.18, Libs: 0.18R13962 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Running the Python command 'importPart' failed:
File "/Users/michael/Library/Preferences/FreeCAD/Mod/assembly2/importPart.py", line 137, in Activated
QtGui.qApp.activeWindow(),
'NoneType' object has no attribute 'activeWindow'
