FCSpring Helix macro help needed
samaelson
Postby samaelson » Wed May 24, 2017 8:27 am
Hi all,
I am just facing a problem creating a customized spring using great macro FCSpring Helix Variable.
As you can see on the pictures attached, I get some strange bugs where one spring part touches the other one when creating a solid.
Already tried some different settings without success.
I hope anyone out there could share some good ideas or hints.
Thanks a lot!
Best wishes
Sam
Re: FCSpring Helix macro help needed
Postby Kunda1 » Wed May 24, 2017 11:56 am
Please remember that anytime when asking for help that you save time for volunteers by adding your
Help > About FreeCAD > Copy to clipboard version info to your post. Cheers
mario52
Postby mario52 » Wed May 24, 2017 9:32 pm
hi
yes there are problems
can give you the parameters of the spring for testing
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
mario52
Postby mario52 » Thu May 25, 2017 11:35 am
hi
use other precision
here 5 (72 points) and smoot 71
mario
samaelson
Postby samaelson » Thu May 25, 2017 4:27 pm
Hi mario,
Perfekt, works great!
Thank you so much for the brilliant support!
Best wishes
Sam
mario52
Postby mario52 » Thu May 25, 2017 5:42 pm
hi
thanks
If you want to have your circle perpendicular to your wire use Macro_Perpendicular_To_Wire Image
mario
