Curves workbench
Chris_G
Re: Curves workbench
Postby Chris_G » Mon Feb 25, 2019 2:26 pm
- select a control point AND an external shape (with control key)
- press s to attach the control point to the shape
- control point color will change to :
* white when attached to a vertex
* cyan when attached to an edge
* magenta when attached to a face
To free the control point from the shape, select only the control point and press s
m.cavallerin
Postby m.cavallerin » Fri Mar 01, 2019 2:27 am
thx for this WB. it's awesome.
I have several questions:
- what is the final goal of "make parametric solid" command?
- on several given air foils profiles, in your opinion, is it better to use the pipeShell or the sweep profiles on 2 rails command? what are the main differences on usage?
Thanks
Michele
Chris_G
Postby Chris_G » Fri Mar 01, 2019 10:15 am
This can be useful when building objects from the ground up, starting from edges and faces.
You'll need solids for boolean operations, for example.
With Part_ShapeBuilder, it is needed to build a shell from faces first, then a solid from the shell ... and it is not parametric.
I don't like OCC's Pipeshell, it is rather complicated, it has a bug with auxiliary spline (option "Contact on Border" fails), and it is pretty slow.
"Sweep profiles on 2 rails" is crap (It was one of my attempts at coding a Sweep on 2 rails tool).
If you can get 2 guide curves along your list of profiles, I would recommend to use the Gordon surface tool.
m.cavallerin
Postby m.cavallerin » Sat Mar 02, 2019 2:42 am
Hi and thanks.
I'll look for Gordon.
Michele
m.cavallerin
Postby m.cavallerin » Sat Mar 02, 2019 3:40 am
it's just a Draft, but would it be of any help?
Regards.
mappingCurvesWB_thread.pdf
(23.37 KiB) Downloaded 39 times
hammax
Postby hammax » Mon Mar 04, 2019 6:00 pm
… some other Problems:
- What are the new "Reflection Lines" standing for?
- If I use the renewed "Spline through Points" feature, the first thing that appears is the Transform_Feature.
Selecting e.g. the corners of a cube I get a splinecurve (red) named "GordonProfile", which I can manipulate with transform.
But the transform-feature cannot be hidden again or deselected and does only work on the gordon_profile.
(MS Win10_32, FC.18.16028)
Creating an alternative curve through points (green) for comparison works with the usual parameters.
Chris_G
Postby Chris_G » Mon Mar 04, 2019 6:17 pm
https://forum.freecadweb.org/viewtopic.php?f=13&t=24660
I experienced that also, when the editor fails.
This is probably a problem with coin.
Do you get some messages in the report view ?
m.cavallerin
Postby m.cavallerin » Mon Mar 04, 2019 9:10 pm
For my purposes, I choose to use sweep2Rails.
I would like to automate the creation of surface by using seweep2Rails command + approximate points on Nurbs.
Assuming I already got a selection (list) of elements: profiles and ruled surface,how can I use s2rCommand class from an external python script?
Thx
Chris_G
Postby Chris_G » Mon Mar 04, 2019 9:46 pm
Here is a rough example, it is a copy/paste from the FeaturePython's execute(), it won't work as-is:
import libS2R
s2r = libS2R.SweepOn2Rails()
s2r.extend = obj.Extend
s2r.profileSamples = obj.ProfileSamples
s2r.railSamples = obj.RailSamples
s2r.setRails(obj.Birail.Shape.Face1)
s2r.setProfiles(self.setProfiles(obj.Profiles)) #((e1,e2,e3))
s2r.build()
#s2r.showLocalProfiles()
#s2r.showInterpoCurves()
s2r.mix(obj.Blending)
#s2r.show()
obj.Points = s2r.downgradeArray()
obj.Shape = s2r.shapeCloud()
return(s2r)
m.cavallerin
Postby m.cavallerin » Tue Mar 05, 2019 5:35 am
Hi and thx,
your hint as been of help.
So I started to edit the s2rCommand class with following:
class s2rCommand:
    def parseSel(self, selectionObject):
        birail = None
        profs = []
        for obj in selectionObject:
            if hasattr(obj,"NormalizeBinormal") or hasattr(obj,"Orientation"): #if isinstance(obj.Proxy, birail):
                birail = obj
            else:
                profs.append(obj)
        return((birail,profs))
    def inputList(self, List):
        if List == []:
            FreeCAD.Console.PrintError("List is empty\n")
            return
        self.Execute(List)
    def Activated(self):
        s = FreeCADGui.Selection.getSelection()
        if s == []:
            FreeCAD.Console.PrintError("Select a ruled surface and a list of profile edges\n")
            return
        self.Execute(s)
    def Execute(self,s):
        myS2R = FreeCAD.ActiveDocument.addObject("App::FeaturePython","Sweep 2 rails")
        sweep2rails(myS2R)
        sweep2railsVP(myS2R.ViewObject)
        myS2R.Birail   = self.parseSel(s)[0]
        myS2R.Profiles = self.parseSel(s)[1]
        myS2R.Birail.ViewObject.Visibility = False
        for p in myS2R.Profiles:
            p.ViewObject.Visibility = False
        #myS2R.ViewObject.PointSize = 2.00000
        #myS2R.ViewObject.LineColor = (0.0,0.0,0.7)
        FreeCAD.ActiveDocument.recompute()
    def GetResources(self):
        return {'Pixmap' : path_curvesWB_icons+'/sw2r.svg', 'MenuText': 'Sweep2Rails', 'ToolTip': 'Sweep profiles on 2 rails'}
FreeCADGui.addCommand('sw2r', s2rCommand())
With this you have two class methods:
Activated allows a Gui selection of entities
inputList method that allows a script to supply the list of items for sweep2Rail command.
Regards.
