Curves workbench
Chris_G
Re: Curves workbench
Postby Chris_G » Fri Aug 30, 2019 1:05 pm
Haha, in fact, the zig-zag curvature bug is my fault :lol: :oops:
The "Detect aligned" property should be on False by default.
freecad-heini-1
Postby freecad-heini-1 » Wed Sep 04, 2019 11:31 am
Chris_G wrote: Ping
Hi Chris, please check the reflect-lines tool, in Freecad daily build for Ubuntu it doesn't work properly anymore.
Best regards
Wilfried
Chris_G
Postby Chris_G » Wed Sep 04, 2019 12:22 pm
It's working fine for me (but I have a couple of modified files that are not on Github).
Do you get some error message ?
Or an example file, maybe ?
freecad-heini-1
Postby freecad-heini-1 » Wed Sep 04, 2019 12:55 pm
A video:
Reflect_lines-2019-09-04_14.37.38.webm
(440.66 KiB) Downloaded 34 times
The file:
Scheibe_zwei_Winkel.FCStd
(16.36 KiB) Downloaded 16 times
My Freecad info:
OS: Ubuntu 18.04.3 LTS (XFCE/xubuntu)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
I tried the Appimage, it work correct:
Version: 0.19.17499 (Git) AppImage
Hash: 6b1be38f35686faf21e1015bf562520929890870
Python version: 3.7.3
Qt version: 5.9.7
Chris_G
Postby Chris_G » Wed Sep 04, 2019 1:59 pm
I don't get any error.
OS: Ubuntu 18.04.3 LTS (KDE/plasma)
Version: 0.19.
Qt version: 5.9.5
Locale: French/France (fr_FR)
GlouGlou
Postby GlouGlou » Sun Sep 08, 2019 9:38 am
This sketch give a BOPAlgo GeomAbs_C0 error through a JoinCurve.
That carry out this error with any surface.
Any suggestion?
JoinCurveIssue.FCStd
(5.51 KiB) Downloaded 18 times
GlouGlou
Postby GlouGlou » Sat Sep 14, 2019 8:30 am
We don't have these options for SplitCurves? :cry:
LLuoss
Postby LLuoss » Mon Sep 16, 2019 8:54 am
Chris_G wrote:
Mon May 29, 2017 9:54 am
hammax wrote:
Mon May 29, 2017 9:01 am
...sweeping with 2 rails:
The Sweep On 2 Rails requires 3 steps.
Please update the Workbench, since I added a tool yesterday.
Step 1 -> create a Birail object out of 2 edges
Step 2 -> select the Birail and the profiles and create the Sweep on 2 rails
Step 3 -> Approximate the point cloud with a surface
I don't think it will work on closed profiles.
It also requires at least one profile at each end.
This is highly experimental Work In Progress.
Hi,glad to see u again!I'm confused how to do these three steps with python code?Do you have any simple code examples for these three steps?Looking forward to your reply!Thanks!
Chris_G
Postby Chris_G » Mon Sep 16, 2019 8:57 am
Any suggestion?
I don't know the reason for the C0 continuity. I can get C1, but only with very high tolerance setting.
In this case, I would suggest to discretize (set Target to "Wire" ) and approximate the sketch.
I modified the tool recently.
It is now possible to set multiple split points.
The Values property is a string list :
Positive values are computed from edge start.
Negative values are computed from edge end.
Chris_G
Postby Chris_G » Mon Sep 16, 2019 9:11 am
Don't use this, it is outdated.
Use the Gordon surface.
I already answered about the Gordon surface scripting :
import gordon
gordon = gordon.InterpolateCurveNetwork([bs0,bs1,bs2], [bs3,bs4,bs5], tol=0.1) # the bs* are BSpline curves
my_surface = gordon.surface()
