Curves workbench
freecad-heini-1
Re: Curves workbench
Postby freecad-heini-1 » Thu Sep 19, 2019 3:06 pm
This video is aimed at Freecad freeform surface experts / specialists, such as Chris_G, GlouGlou, wmayer, microelly2 - and others.
https://peertube.mastodon.host/videos/w ... 4d969152e9
The Surface Filling Tool, with the possibility to define a tangency to neighboring surfaces, works incorrectly in this case.
The Gordon Surface from the Curves Workbench lacks the ability to define neighboring surfaces in order to link tangential conditions to them.
@Thomas (microelly2), if you see this, please use the uploaded data to show which tools from your Nurbs Workbench can be used to solve this problem.
Everyone is welcome to try this example.
Many greetings
Wilfried
Translated with www.DeepL.com/Translator
roehre-2_fh-1.FCStd
(82.39 KiB) Downloaded 22 times
GlouGlou
Postby GlouGlou » Thu Sep 19, 2019 5:57 pm
A sweep profile 2 rail make a better surface. Check it out. ;)
roehre.FCStd
(101.7 KiB) Downloaded 24 times
freecad-heini-1
Postby freecad-heini-1 » Thu Sep 19, 2019 7:18 pm
Hi GlouGlou,
Thank you so much for your diligence.
Unfortunately, there is a rather large deviation from the desired geometry. Please hide the Loft area, then you'll see what I mean. Your surface is much thinner at this point.
Best regards
Wilfried
LLuoss
Postby LLuoss » Fri Sep 20, 2019 2:40 am
Chris_G wrote:
Mon Sep 16, 2019 9:11 am
LLuoss wrote:
Mon Sep 16, 2019 8:54 am
Hi,glad to see u again!I'm confused how to do these three steps with python code?Do you have any simple code examples for these three steps?Looking forward to your reply!Thanks!
Don't use this, it is outdated.
Use the Gordon surface.
I already answered about the Gordon surface scripting :
import gordon
gordon = gordon.InterpolateCurveNetwork([bs0,bs1,bs2], [bs3,bs4,bs5], tol=0.1) # the bs* are BSpline curves
my_surface = gordon.surface()
Thanks!Finally it worked.But I still have some questions.Why does the contour of the resulting surface end up not coincident with the BSpline I used?
If I want to use an outline of my surface, how do I extract it?
GlouGlou
Postby GlouGlou » Sat Sep 21, 2019 8:14 am
combined projection curves doesn't work any more?
OS: Windows 10 (10.0)
Version: 0.19.18213 (Git)
Hash: 22babc09954ac6fda9135ee71d68550921659b1c
Python version: 3.6.8
Qt version: 5.12.1
Locale: French/France (fr_FR)
CombinedCurveBug.FCStd
(7.82 KiB) Downloaded 22 times
Chris_G
Postby Chris_G » Sat Sep 21, 2019 10:59 am
It's a bug.
I'll push a fix this afternoon.
GlouGlou
Postby GlouGlou » Sat Sep 21, 2019 8:41 pm
Any hint to make a nice hull? I'm stuck.
Surface and loft fail.
JustCurves.FCStd
(889.43 KiB) Downloaded 20 times
hammax
Postby hammax » Sun Sep 22, 2019 6:32 am
… keep it simply simple = KISS.
Hull with 4 frames and loft => the real old fashioned "spline" design.
(in the original file I have a lot of exclamation marks)
https://forum.freecadweb.org/viewtopic. ... 58#p332858
JustCurves_2.FCStd
(43.31 KiB) Downloaded 27 times
GlouGlou
Postby GlouGlou » Sun Sep 22, 2019 5:42 pm
Yes, loft is easy and fast to use. But unable to use the red lines.
Here my hull built on an Loft+Gordon+Filling.
Closed to be perfect.
hammax
Postby hammax » Mon Sep 23, 2019 10:31 am
… please have a look at your frames' curvature combs and the resulting "cellulitis".
Compared to a Sketcher BSpline with ONLY 4 control points.
