Curves workbench
Chris_G
Re: Curves workbench
Postby Chris_G » Fri Feb 14, 2020 10:05 pm
Thanks Saso.
I wasn't sure it was a good solution either.
And I understand the drawbacks.
I will think about a better method.
hammax
Postby hammax » Sun Feb 16, 2020 7:58 am
… trying to build a "closed" (periodic?) Gordon surface there seems to be a minimalistic gap condition,
controlled by the tolerance value. If tolerance is 0,005 the gap must be greater (e.g. 0,01mm).
It is possible to make a closed shape by 2 Gordon surfaces.
https://forum.freecadweb.org/viewtopic. ... 63#p369150
Is there a way at all, to close sketches after building Gordon?
GordonClosed.FCStd
(28.58 KiB) Downloaded 6 times
freecad-heini-1
Postby freecad-heini-1 » Sun Feb 16, 2020 8:30 am
Exactly the same topic interested me, using a Sweep on two Rails. Which possibility is there to get a "closed" surface?
microelly2
Postby microelly2 » Sun Feb 16, 2020 9:08 am
There are different ways to get a closed layout.
Here an example in 2D
close_curve.FCStd
(13.03 KiB) Downloaded 14 times
pts=[v.Point for v in App.ActiveDocument.Sketch.Shape.Wires[0].Vertexes]
bc=Part.BSplineCurve()
poles=pts
mults=[4,1,1,1,4]
knots=range(len(mults))
bc.buildFromPolesMultsKnots(poles,mults,knots,False,3)
Part.show(bc.toShape())
poles=pts+[pts[0]]
mults=[4,1,1,1,1,4]
poles=pts+[pts[0]]
mults=[1,1,1,1,1,1,1,1,1]
bc.buildFromPolesMultsKnots(poles,mults,knots,True,3)
poles=pts+[pts[0],pts[0]]
mults=[1,1,1,1,1,1,1,1,1,1]
poles=pts
mults=[1,1,1,1,1,1,1,1]
freecad-heini-1
Postby freecad-heini-1 » Sun Feb 16, 2020 9:12 am
Ich habe sowas gemeint:
curves_wb_sweep_on_two_rails_full_circle_2.FCStd
(39.81 KiB) Downloaded 10 times
Die Kreisbögen in den beiden Sketchen habe ich mit 1mm Spalt erzeugt, aber sie sollen geschlossen sein.
Chris_G
Postby Chris_G » Sun Feb 16, 2020 10:05 am
Currently, Gordon surface doesn't work for closed surfaces.
I hope I can add this feature someday.
freecad-heini-1
Postby freecad-heini-1 » Sun Feb 16, 2020 4:57 pm
GlouGlou wrote:
Fri Feb 07, 2020 8:33 pm
A suggested tool: select the two yellow edges, then make a tangent arc. Just need the radius.
Could be called "TangentArc" :D
saw here :https://www.youtube.com/watch?v=6IkXAcz ... ex=16&t=0s
Hello GlouGlou and others,
I tried to follow the example in Freecad. The faces, Connect and Split / Slice are good, but as soon as you start rounding the faces, Freecad behaves strange. It trims away surfaces in places that should be preserved. Who can show how to round these surfaces with R10 to R30mm?
Many greetings
Wilfried
Surface_with_Fillet_example.FCStd
(21.15 KiB) Downloaded 7 times
Fillet003 is strange:
Surface_with_Fillet_example_fillet003.FCStd
(37.76 KiB) Downloaded 7 times
No problem with a solid:
Surface_with_Fillet_example_solid.FCStd
(67.92 KiB) Downloaded 7 times
The problem are the orange faces. It's needed to sew them:
https://forum.freecadweb.org/viewtopic. ... 74#p239574
GlouGlou
Postby GlouGlou » Sun Feb 16, 2020 6:40 pm
Sometimes Part tools carry out surfaces upside downed :roll: . But We are not able to see them until make an offset3D.
By using "reverse shapes" (PartWb) we can give the right direction for all faces.
Then Connect can be refined. and Fillet works better. :D
Hope It can help you.
Surfaces.FCStd
(45.06 KiB) Downloaded 5 times
GlouGlou
Postby GlouGlou » Sun Feb 16, 2020 6:48 pm
here the exercise. ;)
zzz.FCStd
(274.26 KiB) Downloaded 16 times
freecad-heini-1
Postby freecad-heini-1 » Sun Feb 16, 2020 9:16 pm
Thank you so much GlouGlou, the surface direction, good to know.
