Curves workbench
fc_tofu
Re: Curves workbench
Postby fc_tofu » Sun Apr 19, 2020 12:26 pm
Hello @Chris_G and fellows,
I suggest an alternative icon for "SVG Paste" command.
The original file come from Inkscape 0.92, GPL v2 License.
https://inkscape.org/~BobSongs/%E2%98%85iconssvg
I adjusted icon size to 64px *64px, and stroke width to 2px, to comply with CuresWB current icon style.
Attachment is revised version.
svg.svg
(12.6 KiB) Downloaded 8 times
Postby chrisb » Sun Apr 19, 2020 12:51 pm
Hm, it doesn't improve things for me as an occasional user. "SVG" is immediately clear, which the proposed icon is not at all. Of course an application dealing almost solely with SVGs does not have an icon labeled SVG, but for FreeCAD it is different.
fc_tofu
Postby fc_tofu » Sun Apr 19, 2020 3:26 pm
hammax wrote:
Sat Jul 08, 2017 2:23 pm
Hi, hammax. I tested your attachment sample.
But it seems broke in latest FC0.19pre build.
Proxy changed
RailSamples changed
Untwist changed
Visibility changed
Points changed
Shape changed
  File "E:\WINAPP_B\FreeCAD_0.19\Mod\Curves\curveOnSurfaceFP.py", line 86, in __setstate__
    self.Object = FreeCAD.ActiveDocument.getObject(state["name"])
<class 'TypeError'>: 'NoneType' object is not subscriptable
Label changed
Visibility changed
  File "E:\WINAPP_B\FreeCAD_0.19\Mod\Curves\approximate.py", line 310, in __setstate__
ExpressionEngine changed
Could you please update this sample file or make another simple "blend surface" sample file?
I never succeeded with "blend surface" command.
ps.
Curves WB, 20200407 revision
OS: Windows 10 (10.0)
Version: 0.19.20514 (Git)
Hash: a05ffd499366ab12fa1b43f37db73f4f1e9c332d
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Chinese/China (zh_CN)
hammax
Postby hammax » Sun Apr 19, 2020 3:34 pm
… sorry fc_tofu, no retrieval. Too long ago.
Today I would do it in another way - and I have "only" FC.18.4.
fc_tofu
Postby fc_tofu » Sun Apr 19, 2020 4:07 pm
I have almost same feeling as you. So I made another revision with letters.
# Revision 2
# Revision 3
Take a look, please.
Personally, I think in smallest toolbar (16px icon size), 3 letters can hardly do any decroations. Or say, any decorations will make it look messy in 16px square size.
So, IMO, 1 letter ("S" here) with decoration is a trade-off balance here. Al last, we have tooltip/statustip for toolbar.
svg_rv3.svg
(13.89 KiB) Downloaded 9 times
Chris_G
Postby Chris_G » Sun Apr 19, 2020 5:54 pm
Thanks for these nice icons.
I can use Revision 3 if you wish.
fc_tofu
Postby fc_tofu » Sun Apr 19, 2020 7:45 pm
If you think it be ok. That's my pleasure.
Chris_G
Postby Chris_G » Sun Apr 19, 2020 8:17 pm
Done.Thanks a lot.
fc_tofu
Postby fc_tofu » Mon Apr 20, 2020 12:49 am
freecad-heini-1 wrote:
Thu Dec 14, 2017 3:37 pm
Hi, heini,
have you found a workaround to get a G1 surface Tide bottole?
freecad-heini-1
Postby freecad-heini-1 » Mon Apr 20, 2020 7:29 am
Hi fc_tofu,
what is your first name?
My first name is Wilfried.
No, unfortunately I have not found a possibility but I have asked several times that we can make Gordon surfaces tangential to neighbouring surfaces.
The Surface Workbench offers good options for some surface types. Unfortunately not for surfaces like in this example. Microelly2 (Thomas) has such tools in its Nurbs Workbench. Unfortunately he uses his own special curves. Existing curves from the Sketcher or Curves Workbench cannot be used directly or at least converted. There are some Gold Nuggets in his Nurbs Workbench. Unfortunately they are hard to find and almost not documented.
https://forum.freecadweb.org/search.php ... bmit=Suche
Translated with www.DeepL.com/Translator (free version)
Kind regards
Wilfried
