PDN: Polar array issue
abdullah
Postby abdullah » Tue Jun 20, 2017 10:59 am
I was approached with a request to make a bolt with FC. I did not get far without finding an issue, probably a bug.
Heros_bolt_transf_failed.fcstd
(14.37 KiB) Downloaded 22 times
When I try to transform the slot into a polar array it fails. I would say it is a bug, but I post here just in case I am doing something very stupid without realising.
Then I said, well as a work around lets do a multi-transform with mirror...
But a mirror multi-transform does not allow to select axis normal to the sketch (I still prefer the "plane" terminology, but given that horizontal and vertical axes are used in the other options, I keep with normal). Shouldn't it be an option there? (feature request) I mean, the non-multi-transform, so the normal mirror has indeed planes:
Although the result is worthless. So another bug?
Ok, let's get more imaginative...
Make a datum line on the z axis and try to use it for the multi-transform with mirror: Selection not allowed by filter. (BTW, pressing cancel after that crashed Freecad)
Just let me know what is reproducible so that we can produce bug reports and feature requests to make this usable ;)
hinckel
Re: PDN: Polar array issue
Postby hinckel » Tue Jun 20, 2017 11:47 am
Maybe this is what you meant.
In the drawing attached the the axis of the polar array is the Z-Axis.
In case the polar array axis is not one of the main coordinate system, using a Datum line will do it.
Heros_bolt_transf.fcstd
(24.98 KiB) Downloaded 19 times
abdullah
Postby abdullah » Tue Jun 20, 2017 1:54 pm
hinckel wrote: ping
I have run into trouble with this:
OS: Ubuntu 16.04.2 LTS
Version: 0.17.11310 (Git)
Build type: None
Hash: d28bae3f52b3e7cf959e8b9f7bcff264f95db191
Python version: 2.7.12
OCC version: 7.1.0
What did you use for yours?
The reason is that I also tried polar with datum line, basically nothing would work.
So either there was something wrong in my sketches, or there is a problem with a recent commit...
abdullah
Postby abdullah » Tue Jun 20, 2017 2:02 pm
Something weird happens. When I open your file with my version of the PPA, I can not hide/show the individual features... I am starting to think that your version of FC is higher than mine...
hinckel
Postby hinckel » Tue Jun 20, 2017 2:48 pm
My version is
OS: "openSUSE Leap 42.2"
Version: 0.17.11378 (Git)
Build type: Unknown
Hash: cd9adc79945e68602a3193910496df007d70707a
Python version: 2.7.13
Qt version: 4.8.6
OCC version: 6.9.1.oce-0.18
I also have the add-on Part-O-Magic installed and active.
ulrich1a
Postby ulrich1a » Tue Jun 20, 2017 6:37 pm
I would guess, it is an OCCT-Bug. I had to use an angle of 270°. It then works for me with:
OS: Debian GNU/Linux 8.8 (jessie)
Version: 0.17.10887 +3 (Git)
Build type: Debug
Branch: Solid_and_Shells
Hash: 41b293d1b3a4678c8c1d78b2edebacfaa50a5839
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
It fails with:
Version: 0.17.11372 (Git)
Branch: Rueck6
Hash: 4ea22337567fd8880b43ca8614770627f20658f9
Qt version: 4.8.6
OCC version: 7.1.0
Ulrich
sgrogan
Postby sgrogan » Tue Jun 20, 2017 6:54 pm
+1
I changed Sketch001 so the slot was at 45 deg and polar pattern and multi-transform mirror (using horizontal and vertical sketch axes) both worked and pass check geometry w/BOP
I have problems with hinckel's file also. (Maybe Part-o-Magic?)
OS: Windows 7
Python version: 2.7.8
OCC version: 7.0.0
Heros_bolt_transf_mirror.fcstd
(24.78 KiB) Downloaded 16 times
"fight the good fight"
abdullah
Postby abdullah » Wed Jun 21, 2017 2:03 pm
+1
OS: Windows 7
OCC version: 7.0.0
Ok. Thanks for testing.
I think we need to streamline the bug reporting to OCCT. We want it fixed and it is also nice to give back to whom it is providing our CAD kernel.
Currently I am having a peak of actual work, so I will investigate this issue further on...
sgrogan
Postby sgrogan » Wed Jun 21, 2017 2:27 pm
See Here: https://forum.freecadweb.org/viewtopic.php?f=8&t=22963
Postby Kunda1 » Wed Jun 21, 2017 3:41 pm
Abdullah wrote:ping
Bug filed issue #3093
