Command panel
Moderator: agryson
sgrogan
Re: Command panel
Postby sgrogan » Sat Jan 27, 2018 1:09 am
triplus wrote:
Fri Jan 26, 2018 11:29 pm
Done:
Thanks
silopolis wrote:
Fri Jan 26, 2018 6:41 am
I'd love to be able to add repository URLs in addons manager to add custom modules and then use manager goodness to update and remove them.
I think this is a reasonably feature request. @silopolis can you create a feature request on the tracker?
silopolis
Re: Command panel
Postby silopolis » Sat Jan 27, 2018 9:14 am
Done, here 0003330: Add custom/foreign addon via repository URLs in addon-manager - FreeCAD Tracker
pablogil
Re: Command panel
Postby pablogil » Sat Jan 27, 2018 11:43 am
Nice
P.S. There is a small issue in light set of stylesheets regarding Selector toolbar. I was hopping you could take a look at it before FreeCAD 0.17 release. That would come down to one less item on the todo list on my side. ;)
Where? I’m not aware of it...
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
triplus
Re: Command panel
Postby triplus » Sat Jan 27, 2018 9:30 pm
Thanks
You're welcome.
This looks like a false alarm. As when the selector toolbar is in default state. I thought the darker color is there because it wasn't adjusted for light set of stylesheets. But now i see it is like that by design.
P.S. In the end it still comes down to one item less on the todo list. And that works for me. ;)
pablogil
Re: Command panel
Postby pablogil » Sat Jan 27, 2018 11:47 pm
Thanks
You're welcome.
Hahaha, good to hear that
efyx
Re: Command panel
Postby efyx » Wed May 23, 2018 6:52 am
Can you do that this commands could be invoked (option) with some shortcut key and show under mouse position. This would be perfect for me :) If could contain different icons depending of workbench (automatic) would be additional enchancement.
triplus
Re: Command panel
Postby triplus » Wed May 23, 2018 10:13 am
I did think of adding such ability in the past already. But i feel that somehow PieMenu is more suitable for such use case?
It already does that. ;)
efyx
Re: Command panel
Postby efyx » Wed May 23, 2018 11:09 am
Yes and no. In SW I use them both for different functions. If this isn't too complicated it would be nice to have it.
How to do that? Is the same functionality is applied for piemenu? Because as I checked I couldn't found it.
triplus
Re: Command panel
Postby triplus » Wed May 23, 2018 11:31 am
How to do that?
When defining the commands:
You have workbench selector in the top right section of preferences. Therefore first set the desired workbench and after add commands to it.
Not yet.
efyx
Re: Command panel
Postby efyx » Wed May 23, 2018 1:01 pm
Works like a charm :D please add invoke key and this would be perfect :)
Every now and again I am posting for OK/cancel button under RMB to nawigate without moving mouse to left menu. Do you think such functionality would be usefull in piemenu to accept something or discard?
