Command panel
Moderator: agryson
Jee-Bee
Re: Command panel
Postby Jee-Bee » Wed May 23, 2018 1:14 pm
efyx wrote:
Wed May 23, 2018 1:01 pm
Every now and again I am posting for OK/cancel button under RMB to nawigate without moving mouse to left menu. Do you think such functionality would be usefull in piemenu to accept something or discard?
Agree + 10 asked also about it ... but then no reaction :(
triplus
Re: Command panel
Postby triplus » Thu May 24, 2018 9:50 am
Works like a charm :D
Good to hear that.
please add invoke key and this would be perfect :)
This isn't all that hard to add therefore i will add it (likely weekend). Launcher already has it and now when Shortcuts module can tackle shortcuts directly. I can set some default invoke shortcuts (Launcher, PieMenu, Command Panel ...) tied to (modifier plus) Q key.
From Command panel or PieMenu perspective. I guess if someday this buttons would be based on QActions (with a unique name). It would be possible to use them in Command panel or PieMenu. ATM i am not interested in investigating this further.
efyx
Re: Command panel
Postby efyx » Fri May 25, 2018 12:51 pm
I found problem with your piemenu, because invoke "key" is tab I cannot use "tab" in combo view. If I am in combo box - piemenu tab invoke key should be disabled.
triplus
Re: Command panel
Postby triplus » Sat Jun 02, 2018 11:02 am
Such things should be posted to PieMenu thread. Yes it was already reported in the past that Tab key isn't the best choice. Default invoke shortcut key will be set to Q in the future (and you will be able to change it with ShortCuts module). I haven't had much time for FreeCAD in the past week. But will try to increase the development progress in the following days.
triplus
Re: Command panel
Postby triplus » Mon Jun 04, 2018 10:23 am
I added basic invoke key support (Ctrl+Q).
P.S. To set custom key combination use ShortCuts module.
Jee-Bee
Re: Command panel
Postby Jee-Bee » Mon Jun 04, 2018 10:29 am
cmd + q(assumbtion that it works that way) is close app on OSX and probaby other linux too... could it be another key combination?
triplus
Re: Command panel
Postby triplus » Mon Jun 04, 2018 10:41 am
Does Ctrl+Q key combination close FreeCAD on macOS? I need a sensible default key combinations for PieMenu, setting Launcher focus, Command Panel invoke key and ShortCuts overlay feature.
PieMenu: Q
Launcher focus: Ctrl+Shift+Q
Command Panel invoke: Ctrl+Q
ShortCuts overlay feature: Shift+Q
P.S. Suggestions welcomed.
Jee-Bee
Re: Command panel
Postby Jee-Bee » Mon Jun 04, 2018 11:10 am
No for most shortcuts ctr is changed to cmd. but cmd+Q is closing a program on OSX. and on linux is ctrl+q also closing a program. and that makes it for me a shortcut i don't like...
triplus
Re: Command panel
Postby triplus » Mon Jun 04, 2018 11:16 am
The reason i asked for macOS is because on Linux Alt+F4 is set to close FreeCAD. Anyway i have just set some default shortcuts for modules mentioned above. And based on the feedback that can be further fine tuned in the future.
efyx
Re: Command panel
Postby efyx » Tue Jul 10, 2018 7:50 am
PieMenu: Q
Command panel with invoke works well for me - this is really cool, but I would like to: when command panel is invoked floating it would close when click outside of it (so invoke key will be used) else if docked then it is still till close from [x]
and one suggestion for invoke keys, becasue shfit+q isn't intuitive and quite hard combination for fingers set (It should have easy access) maybe better would be ~, Ctrl+Shift+~, Ctrl+~, Shift+~ because mostly hand is on the edge of keyboard. Please consider that.
