[0.17] some of the Draft WB tools not working
MMSN
Postby MMSN » Mon Jun 26, 2017 6:19 pm
Here I have some issue with Window Vista. Please see the attached picture:
Freecad V17 in Window Vista issue.JPG (109.78 KiB) Viewed 1160 times
1.-My Laptop Toshiba:
OS Name Microsoft® Windows Vista™ Home Premium
Version 6.0.6001 Service Pack 1 Build 6001
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name xxxx
System Manufacturer TOSHIBA
System Model Satellite A200
System Type X86-based PC
Processor Intel(R) Core(TM)2 CPU T5300 @ 1.73GHz, 1733 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date TOSHIBA V1.40, 4/26/2007
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "6.0.6001.18000"
User Name xxxxx
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 2.00 GB
Total Physical Memory 1.99 GB
Available Physical Memory 867 MB
Total Virtual Memory 4.21 GB
Available Virtual Memory 2.89 GB
Page File Space 2.28 GB
Page File C:\pagefile.sys
2.-The FreeCad Version that I do like run:
FreeCAD_0.17.9822_x86_dev_win
My be is a python version trouble that I tried to fix without success.
Thanks very much in advance. :)
Reason: split from another topic to its own topic and changed title to make it more relivent.
jmaustpc
Re: [0.17] some of the Draft WB tools not working
Postby jmaustpc » Sat Jul 01, 2017 3:51 am
Hi
your FreeCAD version is out of date, please download the latest available, currently 0.17.11474, from the list here
https://github.com/FreeCAD/FreeCAD/releases
Note if your O/S is only 32 bit you must download the 3bit FreeCAD (with "x86" in its name) and NOT the 64 bit (with "x64" in its name). If your O/S ia 64 bit then I suggest you download the 64 bit FreeCAD.
After you have updated, please post back here and tell us if your problem is still there or if it is fixed by updating.
NormandC
Postby NormandC » Sat Jul 01, 2017 4:02 am
Thanks for moving this into a new topic Jim.
Also relevant would be to detail what you did exactly re:
MMSN
Postby MMSN » Mon Jul 03, 2017 7:05 am
MMSN wrote: ↑
Mon Jun 26, 2017 10:19 am
Firsth thanks forthis new topic.. :)
I have been trying with the new version but it gives the same error
looo
Postby looo » Mon Jul 03, 2017 7:15 am
please copy the error message which appears in the report-view (view - panels - report-view) and post it here.
jmaustpc
Postby jmaustpc » Mon Jul 03, 2017 10:40 am
you have to tick "redirect error messages to report view" in the settings.
MMSN
Postby MMSN » Mon Jul 03, 2017 4:27 pm
Hi
Here is the FreeCAD_0.17.11474_x86_dev_win's report message :
During initialization the error DLL load failed: The specified procedure could not be found. occurred in C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\GDT\InitGui.py
Please look into the log file for further informationnurbs configuration file loaded
During initialization the error DLL load failed: The specified procedure could not be found. occurred in C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\drawing_dimensioning\InitGui.py
Please look into the log file for further information--------------ERROR loading reconstruction workbench ---------------------
Mod pluginloader InitGui.py starting ...
pluginmanager config file C:/Program Files/FreeCAD 0.16//Mod/plugins/pluginloaderconfig.yaml
During initialization the error local variable 'fn2' referenced before assignment occurred in C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\pluginloader\InitGui.py
Please look into the log file for further informationDuring initialization the error DLL load failed: The specified procedure could not be found. occurred in C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\FreeCAD_assembly2-master\InitGui.py
Please look into the log file for further informationDuring initialization the error DLL load failed: The specified procedure could not be found. occurred in C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\FCGear\InitGui.py
Please look into the log file for further informationDuring initialization the error DLL load failed: The specified procedure could not be found. occurred in C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\exploded_animation\InitGui.py
Please look into the log file for further informationDuring initialization the error DLL load failed: The specified procedure could not be found. occurred in C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\animation\InitGui.py
Please look into the log file for further informationDuring initialization the error DLL load failed: The specified procedure could not be found. occurred in C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\assembly2\InitGui.py
Please look into the log file for further informationDuring initialization the error "'flamingoToolsWorkbench' already exists." occurred in C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\flamingo-master\InitGui.py
Please look into the log file for further informationDraft workbench activated
Failed to TuneWindowsGestures. Error: DLL entry point for SetGestureConfig not found in user32.dll. Could not tune Windows gestures.
Running the Python command 'Draft_Line' failed:
File "H:\Downloads\FreeCAD\Program Version\FreeCAD_0.17.11474_x86_dev_win\FreeCAD_0.17.11474_x86_dev_win\Mod\Draft\DraftTools.py", line 481, in Activated
Creator.Activated(self,name)
File "H:\Downloads\FreeCAD\Program Version\FreeCAD_0.17.11474_x86_dev_win\FreeCAD_0.17.11474_x86_dev_win\Mod\Draft\DraftTools.py", line 463, in Activated
DraftTool.Activated(self,name,noplanesetup)
File "H:\Downloads\FreeCAD\Program Version\FreeCAD_0.17.11474_x86_dev_win\FreeCAD_0.17.11474_x86_dev_win\Mod\Draft\DraftTools.py", line 221, in Activated
import Part, DraftGeomUtils
