Yakovlev Yak-3
Chris_G
Yakovlev Yak-3
Postby Chris_G » Sat Jul 01, 2017 9:01 pm
I needed a test model for the "Sweep on 2 rails" tool I am working on.
This is a Yakovlev Yak-3, a WW2 warbird that looks really beautiful.
I found this plan on the web, and did some inkscape drawing over it :
Then, I have was able to test the "Sweep on 2 rails" to build the surfaces :
Yak-3-03.fcstd
(776.58 KiB) Downloaded 167 times
(Attachment needs my "Curves" workbench)
triplus
Re: Yakovlev Yak-3
Postby triplus » Sat Jul 01, 2017 9:34 pm
Looking good.
Re: Yakovlev Yak-3
Postby Kunda1 » Sat Jul 01, 2017 9:38 pm
Nice!
regis
Re: Yakovlev Yak-3
Postby regis » Sat Jul 01, 2017 10:42 pm
great stuff,
it reminds of my college project when I had to design an aircraft in Inventor.
I was facscinated by the German Messerschmitt Me163 Komet.
Re: Yakovlev Yak-3
Postby chrisb » Sat Jul 01, 2017 11:08 pm
Very impressive, thanks for sharing.
regis
Re: Yakovlev Yak-3
Postby regis » Sun Jul 02, 2017 12:28 am
Very impressive, thaks for sharing.
Your process is quite interesting, did you import the inskcape drawings, one at a time and manually positioned them? did you have to scale the inscape files?
Chris_G
Re: Yakovlev Yak-3
Postby Chris_G » Sun Jul 02, 2017 9:17 am
Nice plan. Even though the plane is quite ugly ... :lol:
The first thing I did was to scale the imported image file in inkscape, so I didn't have to bother about that in the following steps.
Then I imported the whole inkscape file in FreeCAD, and did the placement manually or with some python scripting.
thschrader
Re: Yakovlev Yak-3
Postby thschrader » Sun Jul 02, 2017 12:14 pm
Chris_G, amazing job, really nice!
We should give the YAK-25 shape to the cfd-WB-guys for testing... :geek:
Greetings Thomas
HoWil
Re: Yakovlev Yak-3
Postby HoWil » Sun Jul 02, 2017 7:57 pm
Hi Chris_G ,
I am very interested in this... not for creating planes but for creating free-form objects with the help of Inkscape.
Is it possible to get a fast forward tutorial (including Inkscape) of one of the wings or another simple part?
BR,
HoWil
Chris_G
Re: Yakovlev Yak-3
Postby Chris_G » Sun Jul 02, 2017 9:01 pm
Hi Chris_G ,
BR,
HoWil
Look at the attached FC file. It has sketches, but it is the same as what you get when importing svg.
There are 2 rails and 3 profiles.
The profiles need to be rotated around their endpoints.
This piece of python does this (select a profile and run) :
# rotates the selected NURBS edge around its endpoints
ANGLE = 90
s = FreeCADGui.Selection.getSelection()
for so in s:
    for e in so.Shape.Edges:
        c = e.Curve.copy()
        stPt = c.StartPoint
        enPt = c.EndPoint
        pl = FreeCAD.Placement()
        pl.Base = stPt
        vec = enPt.sub(stPt)
        pl.Rotation = FreeCAD.Rotation(vec,ANGLE)
        for i in range(len(c.getPoles())):
            c.setPole(i+1,pl.inverse().multVec(c.getPole(i+1))+stPt)
        obj = FreeCAD.ActiveDocument.addObject("Part::Spline","Profile")
        obj.Shape = c.toShape()
Then select the 2 rails and make a (PartWB) Ruled surface
Select this ruledSurface and the profiles and run "Sweep profile on 2 rails" tool in my WorkBench :
You get a point cloud. You can adjust the number of samples, or the displaymode ("wireframe" below).
Then you can run the approximation tool to get the surface :
Good luck :lol:
sw2r-example.fcstd
(12.5 KiB) Downloaded 95 times
