Part.Line has no StartPoint and no EndPoint in 0.17
Site Admin
Re: Part.Line has no StartPoint and no EndPoint in 0.17
Postby wmayer » Wed Jun 12, 2019 3:12 pm
In the past Part.Line was handled as a line segment which had a start and end point. This however was inconsistent to other geometry types and thus Part.LineSegment has been introduced and Part.Line is considered as an infinite line from then on.
The Curve attribute of an edge always returns the actual (untrimmed) geometry -- in your case the infinite line.
There are two ways to get the both end points of the edge:
box.Edge1.firstVertex().Point
box.Edge1.lastVertex().Point
or
segm=box.Edge1.Curve.trim(*box.Edge1.ParameterRange)
segm.StartPoint
segm.EndPoint
There is one point you have to take care of:
If an edge has reversed orientation then the edge's start and end points are swapped compared to the underlying geometry. So, in case it's important to consider the orientation of the edge you must pass True to the functions firstVertex/lastVertex.
bernd
Postby bernd » Wed Jun 12, 2019 4:21 pm
thanks werner for the explanation in the regard of line, line segment and curve.
carlopav wrote:
Wed Jun 12, 2019 2:07 pm
Draft module DraftGeomUtils.py have a fillet function, but I've never played with it...
seams to do the trick :)
import Part, DraftGeomUtils
box = Part.makeBox(10,10,10)
l1 = box.Edges[0]
l2 = box.Edges[1]
radius = 5
edges = DraftGeomUtils.fillet([l1, l2], 5)
Part.show(l1)
Part.show(l2)
for e in edges:
    Part.show(e)
bernd
Postby bernd » Wed Jun 12, 2019 4:47 pm
carlopav
Postby carlopav » Wed Jun 12, 2019 5:00 pm
Cool, so it seems there's the material for a new Draft command too! :D
bernd
Postby bernd » Wed Jun 12, 2019 6:24 pm
yeah!
