List Select Macro (Select hidden sub-objects)
m42kus
Re: List Select Macro (Select hidden sub-objects)
Postby m42kus » Mon Jul 10, 2017 8:39 am
HoWil wrote:
Sun Jul 09, 2017 7:00 pm
Please see my screencast where I would like to select the rel. small inner spherical face. Even if the Body is transparent, when I move the cursor over the body preselection comes into play and hides the inner face making a localization of the small face difficult.
Alright I see the problem. One "solution" would be to turn off preselection in the settings. My macro enables and restores the setting automatically. Maybe a toggle button in the view toolbar could be added to make it possible to easily switch the setting. The real solution would be to have transparent preselection with is not possible atm.
I can't really do anything in my add-on because I don't know when the user is about to select stuff with my macro. The user must turn off preselection himself if he doesn't want it at that moment.
My GSoC Devlog: ceeli.github.io/gsoc
HoWil
Postby HoWil » Tue Jul 11, 2017 7:55 pm
I see I see .... so the real solution would be something like a realthunder-solution :D (https://forum.freecadweb.org/viewtopic. ... 89#p175533)
easyw-fc
Postby easyw-fc » Sat Jul 15, 2017 4:28 pm
m42kus wrote:
Fri Jul 07, 2017 8:17 am
I created a tool which helps selecting hidden or difficult to reach sub-objects (solids, faces, edges and vertexes).
does it work on windows?
I installed the Mod from here
https://github.com/drhooves/SelectionTools
but I obtain a list with only the firs solid
my FC info
Version: 0.17.11580 (Git)
Hash: aa07c777453258edf9fed304cf82bcfeb8bdea95
Python version: 2.7.8
OCC version: 7.1.0
Jee-Bee
Postby Jee-Bee » Sat Jul 15, 2017 6:30 pm
This shouldn't be a macro but a feature in the FreeCAD app it self!!
HoWil
Postby HoWil » Sat Sep 02, 2017 5:38 pm
yorik wrote: ping
Is it possible to add this Macro to the Addon-manager?
See also https://github.com/drhooves/SelectionTools
BR,
HoWil
c_prabal
Postby c_prabal » Tue Dec 26, 2017 11:47 am
Salome has a nice feature of outer surfaces while creating a group. May I request you to send me the macro! email c_prabal@yahoo.com
c_prabal
Postby c_prabal » Sun Dec 31, 2017 5:22 am
I used your macro. While allotting material in FEM workbench two problems came up.
1) Inner most hidden body solid 1 is not available for allotment
2) It was not possoble to allot solids for material selection menu.
I have attached a file. could you please help! Prabal.FCStd
hi1.FCStd also show the same problem
Ref CALCULIX
hi1.FCStd
(278.99 KiB) Downloaded 29 times
prabal.FCStd
(19.02 KiB) Downloaded 28 times
Gift
Postby Gift » Sun Dec 31, 2017 6:15 pm
Salome has a nice feature of outer surfaces while creating a group. May I request you to send me the macro! email ...
Pls remove your mail address. Bots & spam lets greet. It is better to write a PM.
HarryvL
Postby HarryvL » Sun Feb 04, 2018 8:35 am
yorik wrote: ping
BR,
HoWil
HoWill, do you know if this was ever added to Addon-manager? It is a really useful tool and (as far as I can see) the only robust way to get to and assign mesh and material properties to embedded solids. The other methods I try are hit and miss.
Regarding installation from Git: I tried to clone and install via the link, but failed. I use FreeCAD-Daily through PPA and am not sure I should mess with the MOD directory, even if I could get access to it in the first place. Unfortunately I am a newcomer to everything from Ubuntu, FreeCAD, Git, Python and you name it, so any help would be appreciated. :D
HoWil
Postby HoWil » Sun Feb 04, 2018 7:45 pm
yorik wrote: ping
BR,
HoWil
Hi HarryvL,
I also use FC-daily under Ubuntu 16.04 and do not have any problems using or installing the SelectionTools form github. For testing purposes I renamed my .FreeCAD folder in my home-folder. Than I did run the two lines listed on the SelectionTools github site https://github.com/drhooves/SelectionTools. Please try it again (assuming that you have installed 'git'):
git clone https://github.com/drhooves/SelectionTools.git \
$HOME/.FreeCAD/Mod/SelectionTools
Now, you should see a newly added dialog in the preferences of FC under 'Display' as shown in the following screenshot:
Screenshot from 2018-02-04 20-30-59.png (76.24 KiB) Viewed 987 times
To be sure, restart FC. Insert e.g. a cube in Part-wb and press 's' followed by a 'e' after placing the mouse pointer over the 3D-part. You should see the part shown transparent and a list holding all elements like faces below the cursor. Thats it.
Feel free to report back if you experience any problems.
BR,
HoWi
