Ruled surface
triplus
Ruled surface
Postby triplus » Tue Mar 06, 2012 5:52 pm
This is what i get:
Parts are mirrored and ruled surface is applied to the corners. Basically if i understand what is going on then on one side surface should be rotated 180 degrees and i was wondering is there a way to do this manually?
triplus
Re: Ruled surface
Postby triplus » Fri Mar 09, 2012 7:20 pm
It seems when edges are on the same plane this happens. I did some testing and one solution would be if user could control direction with setting under data or when clicking on revolved surface arrow would occur on both edges and clicking on it would change direction. This i guess would help to solve this kind of situations when default behavior is not what user plans to do.
But i don't know how hard it would be to implement something like that!
NormandC
Re: Ruled surface
Postby NormandC » Sat Mar 10, 2012 5:52 am
If a planar face is what you want, it can be done easily this way: create a Draft line between the front (or rear) vertices of your solids, then downgrade it twice to get an edge. Then, in Part workbench, go to Part --> Shape Builder menu. Click on "Face from edges", select three edges (one on each solid and the edge you created), and click Create.
triplus
Re: Ruled surface
Postby triplus » Thu Mar 22, 2012 7:41 am
I was away and could not answer before. First thank you for your suggestion in the end i actually used "workaround" that does work 95% of the time.
I selected the edge behind the edge i would like to use:
And then i used boolean operation (Cut) to get what i wanted:
But i hope user gets more control in the future because ruled surface is nice feature to have and this is just simple demonstration and i use ruled surfaces in a lot more complex scenarios too!
jmaustpc
Re: Ruled surface
Postby jmaustpc » Fri Mar 23, 2012 8:28 am
normandc wrote:If a planar face is what you want, it can be done easily this way: create a Draft line between the front (or rear) vertices of your solids, then downgrade it twice to get an edge. Then, in Part workbench, go to Part --> Shape Builder menu. Click on "Face from edges", select three edges (one on each solid and the edge you created), and click Create.
Hi Norm
Perhaps a better or more direct route is to simple go to Part WB, select create primitives, select create line? This line, unlike Draft Line, is actually just an edge, and thus does not need to be down graded. Then of course as you said use the shape builder to create a face from three edges.
Jim
