drilling arcs
rmu
drilling arcs
Postby rmu » Wed Aug 02, 2017 6:35 am
I'm relatively new to FreeCAD and Path module, but I wondered why it is possible to specify "points" as drill-targets, but not the center of Arcs? The obvious use case is drilling pilot-holes for some other tool that does not like to cut in the center. Also, models imported via DXF or STP often contain arc-segments instead of circles, those can not be drilled easily it seems.
sliptonic
Re: drilling arcs
Postby sliptonic » Wed Aug 02, 2017 1:39 pm
This can be added to the manual selection process. It won't be part of the automatic selection though.
Added issue #3147
roivai
Re: drilling arcs
Postby roivai » Wed Aug 02, 2017 3:02 pm
I was thinking about this when I worked with PathDrilling some time ago. I don't know why I did not implement it. Probably laziness :D
I will look into this.
roivai
Re: drilling arcs
Postby roivai » Wed Aug 02, 2017 4:13 pm
I think that is done, selecting an arc edge and adding it to the list should now be supported on my branch: https://github.com/pekkaroi/FreeCAD/tree/drilling_arcs
Could you please check if it makes sense and I can create a PR.
Konstantin
Re: drilling arcs
Postby Konstantin » Wed Aug 02, 2017 5:28 pm
Drilling in arc center is a must. But please don't forget to add to this one more thing: if I select Arc and something else, like on attached picture, then center must be calculated somewhere in widest area between arcs wall and another side. Hard to imagine all usecases, but I had such problems before.
roivai
Re: drilling arcs
Postby roivai » Wed Aug 02, 2017 5:46 pm
That would be excellent, but I think it is very difficult to create such an artificial intelligence which would guess the place where the user wants to drill based on multiple edges/faces. For example. If you have selected two adjacent edges which both are arcs: do you want to drill centers of both arcs or the widest point in the shape formed by those arcs? Like you say, imagining all the use cases is hard.
Re: drilling arcs
Postby chrisb » Wed Aug 02, 2017 6:24 pm
Of course can this be done, but as roivai said, it is not simple. You would have to calculate something like the center of mass of the pocket - something for the anti-matter path workbench :shock: .
Let's do other things first with easier achievable greater benefit to the user.
Konstantin
Re: drilling arcs
Postby Konstantin » Wed Aug 02, 2017 6:27 pm
In theory, you should find the place, where biggest circle fits between selected faces and then it's center. But I am not a programmer, I'm just theorising.
[EDIT}
Even cooler, if walls goes not strictly vertical, it might not work. Better to look for biggest cilinder.
sliptonic
Re: drilling arcs
Postby sliptonic » Wed Aug 02, 2017 6:46 pm
I agree. Arc centers are unambiguous. Keep It Simple!
I would still like to see the ability to pick an arbitrary point as a location though. The user shouldn't have to add a vertex just to select it as a location. He should be able to click 'add point' and then click a spot on the model to add those coordinates to the list. This can be easily added with the draft snapper getPoint() function. See PathProfile line 400 for reference
roivai
Re: drilling arcs
Postby roivai » Wed Aug 02, 2017 8:35 pm
This would be a good addition. I'll try to implement this. Just tried to play with the getPoint(). I got the dialog to appear, but all I got from that was a Segfault.. :)
