[Feature request] random color for parts/bodies
pablogil
Postby pablogil » Thu Aug 03, 2017 11:35 pm
I wonder if you like the idea of a setting that, instead the default part/body color, mark a "random color" option so that each new part/body you create as a different random color which will make pretty easy to differ between different parts/bodies...
what do you think?
Thanks
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
jouke
Re: [Feature request] random color for parts/bodies
Postby jouke » Mon Oct 30, 2017 10:24 am
I'd like this !
Postby Kunda1 » Tue Oct 31, 2017 7:41 pm
Like what is mentioned in issue #2725 ?
pablogil
Postby pablogil » Tue Oct 31, 2017 9:34 pm
Yes and no:
Yes because it that feature is broken in 0.17 I would like to have it solved.
No because what I meant was to have that feature but in "auto mode", that is, if you have ON that Preference parameter whenever you create a new shape/volume element it won't take the default Colorado but a random one. That way it won't be necessary to run sometimes the "random colours"...
dulouie
Postby dulouie » Thu Nov 02, 2017 6:08 pm
thumbs up! i had the same idea..
Postby Kunda1 » Fri Nov 03, 2017 1:17 pm
probably open a ticket to track this an then and link #issue #2725 to it
dulouie
Postby dulouie » Mon Nov 27, 2017 9:06 pm
I have done some coding and finally it works.
Basically i want to edit the constructor in ViewProviderBody.cpp with a method like:
ShapeColor.setValue ( 50.f/255, 150.f/255, 250.f/255 );
But it dosen't work, the programm terminated with segmentation fault.
This annoying me because ShapeColor.getValue() works well. Can someone explain me why?
So i edited the CommandBody.cpp with an python cmd:
// random shapecolor
    float fMax = (float)RAND_MAX;
    float fRed = (float)rand()/fMax;
    float fGrn = (float)rand()/fMax;
    float fBlu = (float)rand()/fMax;
    doCommand(Gui, "Gui.activeDocument().getObject(\"%s\").ShapeColor=(%.2f,%.2f,%.2f)",bodyName.c_str() , fRed, fGrn, fBlu);
And this works fine:)
Are there any suggestions or any chance for a PR?
https://github.com/dulouie/FreeCAD/tree/randombodycolor
Postby Kunda1 » Mon Feb 05, 2018 4:44 pm
Could you please rebase? Could you also show it working with a screencast or animated gif ?
dulouie
Postby dulouie » Tue Feb 06, 2018 4:22 pm
the branch is up to date.
phpBB [video]
Postby Kunda1 » Tue Feb 06, 2018 6:07 pm
This is cool. It would be nice if there was an option in the settings to activate/deactivate this feature per preference.
