Francis, nice project!
(btw: where is the third wheel? )
Autonomous vehicle idea
Re: Autonomous vehicle idea
Superbe ta mise en situation, ce n'est pas fini je prevoie une partie arriere modulable avec une config a 2 ou 4 personnes et finalement il y aura bien 4 roues.
Superb your scenario, it is not finished I provide a modular rear part with a config has 2 or 4 people and finally there will be 4 wheels.
Hello Francis,
your project is a nice example, that FreeCAD is a powerful engineering-tool.
You can do the design, the animated design, fluid-dynamics and structural
engineering in one system.
regards Thomas
regards Thomas
Merci pour ces exemples concrets !
L'image de la mécanique des fluides est impressionnante. Je vais regarder de quel atelier il s'agit et avec quoi il fonctionne format .stl peut-être ?
Je viens juste de pousser la version pickup sur github
Thank you for these concrete examples!
The image of fluid mechanics is impressive. I'll look at what workshop it is and what it works with .stl format maybe?
I just pushed the pickup version on github
