Hm, is it working only with Qt4? On Qt5 with Pyside2 while opening drilling operation (with my old settings and tool library) it throws
File "/Data1/kostia/Bin/git/FreeCAD/build/Mod/Path/PathScripts/PathOpGui.py", line 94, in setEdit
self.setupTaskPanel(TaskPanel(vobj.Object, self.deleteObjectsOnReject(), page, selection))
File "/Data1/kostia/Bin/git/FreeCAD/build/Mod/Path/PathScripts/PathOpGui.py", line 599, in __init__
self.featurePages.append(TaskPanelBaseLocationPage(obj, features))
File "/Data1/kostia/Bin/git/FreeCAD/build/Mod/Path/PathScripts/PathOpGui.py", line 157, in __init__
self.form = self.getForm()
File "/Data1/kostia/Bin/git/FreeCAD/build/Mod/Path/PathScripts/PathOpGui.py", line 409, in getForm
self.formLoc.baseList.horizontalHeader().setResizeMode(QtGui.QHeaderView.Stretch)
<type 'exceptions.AttributeError'>: 'PySide2.QtWidgets.QHeaderView' object has no attribute 'setResizeMode'
And opens in sidebar only with "Translations"options. When I click Ok, then it throws another message:
PathCircularHoleBase(135).opExecute()
PathCircularHoleBase(243).findHoles(obj: <Document object> shape: <Solid object at 0x1687361e50>)
PathCircularHoleBase.DEBUG: search for holes larger than tooldiameter: None:
PathCircularHoleBase.DEBUG: shape is not planar
PathCircularHoleBase.DEBUG: face candidate: <Face object at 0x1687e05390> is drillable
PathCircularHoleBase.DEBUG: Found hole feature Extrude.Face5
PathCircularHoleBase.DEBUG: face candidate: <Face object at 0x1687e05310> is drillable
PathCircularHoleBase.DEBUG: Found hole feature Extrude.Face6
PathCircularHoleBase.DEBUG: face candidate: <Face object at 0x16872d6420> is drillable
PathCircularHoleBase.DEBUG: Found hole feature Extrude.Face7
PathCircularHoleBase.DEBUG: holes found: [{'d': 23.577702000000002, 'enabled': True, 'feature': <Face object at 0x1687e05390>, 'featureName': 'Face5', 'y': 30.036739, 'x': 50.446617}, {'d': 18.910881999999987, 'enabled': True, 'feature': <Face object at 0x1687e05310>, 'featureName': 'Face6', 'y': 45.171574, 'x': 89.849396}, {'d': 12.905672047333898, 'enabled': True, 'feature': <Face object at 0x16872d6420>, 'featureName': 'Face7', 'y': 42.301178, 'x': 21.220718}]
PathCircularHoleBase(224).setDepths(Drilling, 10.0, 0.0, BoundBox (0, 0, 0, 114.378, 71.788, 10))
PathCircularHoleBase.DEBUG: setDepths(Drilling): z=0.00 -> 10.00 bb.z=0.00 -> 10.00
Generates path, options in Data tab looks ok, exports without visible problems. Didn't try yet other tools.
To ensure, that it is not some old settings problem I removed everything in .FreeCAD directory, started again (and found that window layout stayed as I left it. So, window layout is stored somewhere else?)
Extruded simple part from sketch with three holes, Created Job. (With standard tool set by default) I selected face on part, pressed Drilling operation button, it caused same error as first. Removed drilling operation and standard tool, opened tool library, created 10mm diam drill with 118° cutting angle (I am a bad boy), added this tool controller. Pressed Drilling operation button and then it crashed with this :
#0 /usr/lib/libc.so.6(+0x33940) [0x7fcc7b36e940]
#1 0x7fcc7c718150 in QMapDataBase::rotateLeft(QMapNodeBase*) from /usr/lib/libQt5Core.so.5+0x40
#2 0x7fcc7c7182f4 in QMapDataBase::rebalance(QMapNodeBase*) from /usr/lib/libQt5Core.so.5+0xc4
#3 0x7fcc7c718863 in QMapDataBase::createNode(int, int, QMapNodeBase*, bool) from /usr/lib/libQt5Core.so.5+0x63
#4 /usr/lib/qt/plugins/styles/breeze.so(+0x3c676) [0x7fcc60d0f676]
#5 /usr/lib/qt/plugins/styles/breeze.so(+0x177ae) [0x7fcc60cea7ae]
#6 /usr/lib/qt/plugins/styles/breeze.so(+0x604e5) [0x7fcc60d334e5]
#7 0x7fcc7d5f97ef in QWidget::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0xc7f
#8 0x7fcc7d6e8053 in QLineEdit::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0xa3
#9 0x7fcc7d5b6e4c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x9c
#10 0x7fcc7d5be926 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x2a6
#11 0x7fcc82d7cc98 in Gui::GUIApplication::notify(QObject*, QEvent*) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x88
#12 0x7fcc7c88fbd0 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x120
#13 0x7fcc7d5f4db5 in QWidget::ensurePolished() const from /usr/lib/libQt5Widgets.so.5+0x65
#14 0x7fcc7d6e2b9e in QLineEdit::sizeHint() const from /usr/lib/libQt5Widgets.so.5+0x2e
#15 0x7fcc8303b29a in Gui::InputField::InputField(QWidget*) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x18a
#16 0x7fcc82d87ded in Gui::WidgetProducer<Gui::InputField>::Produce() const from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x1d
#17 0x7fcc8228b392 in Base::Factory::Produce(char const*) const from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADBase.so+0x212
#18 0x7fcc8305559f in Gui::WidgetFactoryInst::createWidget(char const*, QWidget*) const from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0xf
#19 0x7fcc8305abf2 in Gui::UiLoader::createWidget(QString const&, QWidget*, QString const&) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0xa2
#20 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x67a583) [0x7fcc830b3583]
#21 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x6897e5) [0x7fcc830c27e5]
#22 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x6953b0) [0x7fcc830ce3b0]
#23 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x67974f) [0x7fcc830b274f]
#24 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x681d0d) [0x7fcc830bad0d]
#25 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x6858d5) [0x7fcc830be8d5]
#26 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x6955d9) [0x7fcc830ce5d9]
#27 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x689a8e) [0x7fcc830c2a8e]
#28 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x6953b0) [0x7fcc830ce3b0]
#29 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x67974f) [0x7fcc830b274f]
#30 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x681d0d) [0x7fcc830bad0d]
#31 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x6858d5) [0x7fcc830be8d5]
#32 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x6955d9) [0x7fcc830ce5d9]
#33 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x689a8e) [0x7fcc830c2a8e]
#34 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x6953b0) [0x7fcc830ce3b0]
#35 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x67974f) [0x7fcc830b274f]
#36 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x682709) [0x7fcc830bb709]
#37 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x6796be) [0x7fcc830b26be]
#38 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so(+0x680777) [0x7fcc830b9777]
#39 0x7fcc8305b887 in Gui::UiLoaderPy::load(Py::Tuple const&) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x457
#40 0x7fcc8305d13e in Py::PythonExtension<Gui::UiLoaderPy>::method_varargs_call_handler(_object*, _object*) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x1be
#41 /usr/lib/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x35a) [0x7fcc81e7467a]
#42 /usr/lib/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x2d5) [0x7fcc81ed54c5]
#43 /usr/lib/libpython2.7.so.1.0(PyEval_EvalCode+0x19) [0x7fcc81eef8f9]
#44 /usr/lib/libpython2.7.so.1.0(+0x15450f) [0x7fcc81ee250f]
#45 /usr/lib/libpython2.7.so.1.0(PyRun_StringFlags+0x66) [0x7fcc81ee4276]
#46 0x7fcc8305a816 in Gui::PySideUicModule::loadUi(Py::Tuple const&) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x246
#47 0x7fcc8305cc5a in Py::ExtensionModule<Gui::PySideUicModule>::invoke_method_varargs(void*, Py::Tuple const&) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x3a
#48 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADBase.so(method_varargs_call_handler+0x177) [0x7fcc8225f4f7]
#49 /usr/lib/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x35a) [0x7fcc81e7467a]
#50 /usr/lib/libpython2.7.so.1.0(PyEval_EvalFrameEx+0xeaf) [0x7fcc81e751cf]
#51 /usr/lib/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x2d5) [0x7fcc81ed54c5]
#52 /usr/lib/libpython2.7.so.1.0(+0xb469e) [0x7fcc81e4269e]
#53 /usr/lib/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7fcc81ea00e3]
#54 /usr/lib/libpython2.7.so.1.0(+0xe261e) [0x7fcc81e7061e]
#55 /usr/lib/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7fcc81ea00e3]
#56 /usr/lib/libpython2.7.so.1.0(+0xc5947) [0x7fcc81e53947]
#57 /usr/lib/libpython2.7.so.1.0(+0xa4614) [0x7fcc81e32614]
#58 /usr/lib/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7fcc81ea00e3]
#59 /usr/lib/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x5ccd) [0x7fcc81e79fed]
#60 /usr/lib/libpython2.7.so.1.0(PyEval_EvalFrameEx+0xeaf) [0x7fcc81e751cf]
#61 /usr/lib/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x2d5) [0x7fcc81ed54c5]
#62 /usr/lib/libpython2.7.so.1.0(+0xb469e) [0x7fcc81e4269e]
#63 /usr/lib/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7fcc81ea00e3]
#64 /usr/lib/libpython2.7.so.1.0(+0xe261e) [0x7fcc81e7061e]
#65 /usr/lib/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7fcc81ea00e3]
#66 /usr/lib/libpython2.7.so.1.0(PyEval_CallObjectWithKeywords+0x30) [0x7fcc81ed4bd0]
#67 0x7fcc82d2e1e4 in Py::Callable::apply(Py::Tuple const&) const from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x14
#68 0x7fcc830063d7 in Gui::ViewProviderPythonFeatureImp::setEdit(int) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x4a7
#69 0x7fcbdbab1427 in Gui::ViewProviderPythonFeatureT<PathGui::ViewProviderPath>::setEdit(int) from /Data1/kostia/Bin/git/FreeCAD/build/Mod/Path/PathGui.so+0x17
#70 0x7fcc82fe434a in Gui::ViewProvider::startEditing(int) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x3a
#71 0x7fcc82fff308 in Gui::ViewProviderPy::startEditing(_object*) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x58
#72 0x7fcc82fff437 in Gui::ViewProviderPy::staticCallback_startEditing(_object*, _object*) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x37
#73 /usr/lib/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x35a) [0x7fcc81e7467a]
#74 /usr/lib/libpython2.7.so.1.0(PyEval_EvalFrameEx+0xeaf) [0x7fcc81e751cf]
#75 /usr/lib/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x2d5) [0x7fcc81ed54c5]
#76 /usr/lib/libpython2.7.so.1.0(+0xb469e) [0x7fcc81e4269e]
#77 /usr/lib/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7fcc81ea00e3]
#78 /usr/lib/libpython2.7.so.1.0(+0xe261e) [0x7fcc81e7061e]
#79 /usr/lib/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7fcc81ea00e3]
#80 /usr/lib/libpython2.7.so.1.0(PyEval_CallObjectWithKeywords+0x30) [0x7fcc81ed4bd0]
#81 /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADBase.so(PP_Run_Method+0xe7) [0x7fcc82314697]
#82 0x7fcc82293839 in Base::InterpreterSingleton::runMethodVoid(_object*, char const*) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADBase.so+0x29
#83 0x7fcc82dac370 in Gui::PythonCommand::activated(int) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x90
#84 0x7fcc82dafecb in Gui::Command::invoke(int) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x7b
#85 0x7fcc7c8bf786 in QMetaObject::activate(QObject*, int, int, void**) from /usr/lib/libQt5Core.so.5+0x886
#86 0x7fcc7d5b0543 in QAction::triggered(bool) from /usr/lib/libQt5Widgets.so.5+0x43
#87 0x7fcc7d5b2d66 in QAction::activate(QAction::ActionEvent) from /usr/lib/libQt5Widgets.so.5+0xd6
#88 /usr/lib/libQt5Widgets.so.5(+0x3128dc) [0x7fcc7d77d8dc]
#89 0x7fcc7d77db45 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/libQt5Widgets.so.5+0xf5
#90 0x7fcc7d75c22b in QToolButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/libQt5Widgets.so.5+0xb
#91 0x7fcc7d5f8d68 in QWidget::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x1f8
#92 0x7fcc7d75c2c5 in QToolButton::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x35
#93 0x7fcc7d5b6e4c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x9c
#94 0x7fcc7d5beea1 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x821
#95 0x7fcc82d7cc98 in Gui::GUIApplication::notify(QObject*, QEvent*) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x88
#96 0x7fcc7c88fbd0 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x120
#97 0x7fcc7d5bde2a in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) from /usr/lib/libQt5Widgets.so.5+0x1da
#98 /usr/lib/libQt5Widgets.so.5(+0x1a8f51) [0x7fcc7d613f51]
#99 /usr/lib/libQt5Widgets.so.5(+0x1ab691) [0x7fcc7d616691]
#100 0x7fcc7d5b6e4c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x9c
#101 0x7fcc7d5be926 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x2a6
#102 0x7fcc82d7cc98 in Gui::GUIApplication::notify(QObject*, QEvent*) from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x88
#103 0x7fcc7c88fbd0 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x120
#104 0x7fcc7cdf21e4 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /usr/lib/libQt5Gui.so.5+0x704
#105 0x7fcc7cdf3d46 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /usr/lib/libQt5Gui.so.5+0x136
#106 0x7fcc7cdcb4ac in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Gui.so.5+0xac
#107 /usr/lib/libQt5XcbQpa.so.5(+0x99cc1) [0x7fcc70ed5cc1]
#108 /usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x2e7) [0x7fcc7654ba57]
#109 /usr/lib/libglib-2.0.so.0(+0x4ac88) [0x7fcc7654bc88]
#110 /usr/lib/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7fcc7654bd1c]
#111 0x7fcc7c8ea061 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x61
#112 0x7fcc7c88dffb in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x13b
#113 0x7fcc7c897048 in QCoreApplication::exec() from /usr/lib/libQt5Core.so.5+0x98
#114 0x7fcc82d29c23 in Gui::Application::runApplication() from /home/kostia/Bin/git/FreeCAD/build/lib/libFreeCADGui.so+0x1153
#115 ./FreeCAD(main+0x61f) [0x40b7f43af]
#116 /usr/lib/libc.so.6(__libc_start_main+0xea) [0x7fcc7b35b4ca]
#117 ./FreeCAD(_start+0x2a) [0x40b7f4f8a]
OS: "Manjaro Linux"
Version: 0.17.11907 (Git)
Hash: 5996ebcf61e518bb0124a6e95ebb03543907a7b5
Python version: 2.7.13
Qt version: 5.9.1
Coin version: 3.1.3
OCC version: 7.1.0
Locale: C/Default (C)
Should I recompile FreeCAD with Qt4? (actually It would mean compiling again all qtwebkit, vtk-qt4 and so on,) Or it is not related with Pyside2 and Qt5?
