Update on the development of the OpenFOAM CFD workbench (CFDOF)
Moderator: oliveroxtoby
johan
Postby johan » Thu Aug 31, 2017 2:12 pm
Dear all
We would like to share the latest extensions to the OpenFOAM CFD workbench (https://forum.freecadweb.org/viewtopic.php?f=18&t=21576). The majority of the work focussed on the extension to turbulent flow and the implementation of meshing utilities that allow us to model more representative geometries for fluid flow which require large meshes (> 1 M cells). Some of the new features include
  • Implemented snappyHexMesh for cut-cell Cartesian meshing with porous media
  • Implemented cfMesh for cut-cell Cartesian meshing with boundary layers
  • Extension to turbulent using RANS (k-w SST).
  • To improve code maintenance a new case builder using a modular template structure is adopted
  • Workbench supports macro scripting with Python
We have updated the CFD tutorials (https://opensimsa.github.io/training.html) to use the python scripting. Please have look at the new features and let us know what you think. To make it easier to install CFDOF we have requested that it be added to the FC add-ons list, we will in the meantime make a Windows executable available.
thschrader
Re: Update on the development of the OpenFOAM CFD workbench (CFDOF)
Postby thschrader » Fri Sep 01, 2017 12:11 am
Hello Johan,
this is my first cfd-calculation ever according to your tutorial.
fluid: oil SAEW10, inlet-velocity=300 mm/s.
I am only a beginner, but I think you guys are doing a great work!
Greetings to south-africa!
regards Thomas
Version: 0.17.11935 (Git)
Hash: a5bc70cca0d2eaa56709603521650ccb3d8d926c
Python version: 2.7.8
OCC version: 7.1.0
saso
Postby saso » Fri Sep 01, 2017 1:29 am
One of the interesting use cases of cfd for structural engineering can be wind loads (wind tunnel) simulations on structures / buildings...
looo
Postby looo » Fri Sep 01, 2017 5:09 am
I tried one of the tutorials too. But I don't know how to set the OpenFoam -Path in the preference dialog. I guess the open-foam directory should be the directory where for example simpleFoam is:
lo@lo-desktop:~$ which simpleFoam
/usr/bin/simpleFoam
So all the commands are directly available. But somehow the path has to be set, and is not allowed to be /usr/bin...
oliveroxtoby
Postby oliveroxtoby » Fri Sep 01, 2017 6:27 am
/usr/bin/simpleFoam
I haven't seen this before - normally the installation is in its own directory like /opt/openfoam4, /usr/local/OpenFOAM/OpenFOAM4.x, ~/OpenFOAM/OpenFOAM4.x, something like that. Which system and which OpenFOAM package are you using?
looo
Postby looo » Fri Sep 01, 2017 6:44 am
oliveroxtoby wrote: Which system and which OpenFOAM package are you using?
should be this package: https://launchpad.net/ubuntu/zesty/+source/openfoam (ubuntu 17.04, openfoam4.1)
I think the binaries are directly in bin and therefore accessible without any paths. But I don't know what is needed to run the simulation
oliveroxtoby
Postby oliveroxtoby » Fri Sep 01, 2017 7:11 am
  • The latest Windows build incorporating the CFD workbench is now available at https://opensimsa.github.io/download.html
  • The CFDOF workbench is available from https://github.com/jaheyns/CfdOF
  • Please note that the workbench will only work with a very recent prerelease of FreeCAD - version 0.17.11832 or later
  • For full information please see the Readme
  • Also added is basic multiphase (interFoam/multiphaseInterFoam) support (currently lacking support for surface tension, and setting non-default values of gravity). Thank you to Klaus Sembritzki for his contribution.
looo
Postby looo » Fri Sep 01, 2017 7:44 am
rusing the official repository installes openfoam in /opt/openfoam4/ and this makes the dependency-checker is happy. Maybe the package from the ubuntu repositories shouldn't be used...
oliveroxtoby
Postby oliveroxtoby » Fri Sep 01, 2017 7:49 am
From the README:
Set the OpenFOAM install directory in the preferences panel - typical install locations are /home/user/OpenFOAM/OpenFOAM-4.x or /opt/openfoam4 (It will be automatically detected in common default install locations.)
The install path that the CFD workbench wants is the one containing etc/bashrc which is used to initialise the OpenFOAM environment.
My understanding with the Ubuntu package is that this should be /opt/openfoam4, but I'd like to hear if this is not the case. If it is, then it should be picked up automatically if you just leave the install path blank.
Aha, interesting. I did not realise there was a distinction. It sounds as if the ubuntu repository package integrates the directory structure into the system. If you are able it would be helpful to know if there is a path set up in the WM_PROJECT_DIR environment variable (I guess not, as this would have satisfied the dependency checker), or alternatively whether the FOAM_ETC variable is set?
makkemal
Postby makkemal » Fri Sep 01, 2017 8:08 am
When will this be part of the addon manager ?
It really full featured workbench already
