Freecad 0.17 - Pad up to face - Datum Plane is invalid
freecad-heini-1
Postby freecad-heini-1 » Wed Sep 06, 2017 7:34 am
In the German forum I asked about to create a pad out of a sketch and extrude it up to a face.
It's impossible to use a datum plane. Is it a bug, or forgotten during development, or should I ask for a feature request?
From my point of view it would be very helpful, if datum planes are allowed.
Link to the German forum discussion:
https://forum.freecadweb.org/viewtopic. ... 02#p189802
Re: Freecad 0.17 - Pad up to face - Datum Plane is invalid
Postby chrisb » Wed Sep 06, 2017 11:48 am
Created issue #3177. Looking for proposals for a common name for "Up to face/plane", "Up to edge/line", "Up to vertex/point".
Jee-Bee
Postby Jee-Bee » Wed Sep 06, 2017 4:44 pm
I think you make this to complicated. up to face should be the same as up to a plane. I would think none of the other CAD Packages have dual naming...
Postby chrisb » Wed Sep 06, 2017 5:08 pm
Yes, obviously.
What I wanted to say: We need a single name for this usecase which will do any of the three variants. "Up to something" doesn't sound good. "Up to object" is still very global, so I was hoping for something intuitive and precise.
peterl94
Postby peterl94 » Wed Sep 06, 2017 8:59 pm
The option is named "until selected" in NX, which then prompts you to "select object." It's called "object" in Fusion 360 too. The only thing is I tend to first think of a solid rather than any kind of geometry when I see the term "object" in freecad. Maybe we can get away with not naming the geometry type:
Screen Shot 2017-09-06 at 4.48.07 PM.png (27.14 KiB) Viewed 1401 times
NormandC
Postby NormandC » Thu Sep 07, 2017 4:08 am
It works for me in the following test file. I wonder if it's because the Pad feature is based on an existing solid? I'm afraid I don't have time to test further.
OS: Ubuntu 16.04.3 LTS
Version: 0.17.11967 (Git)
Build type: None
Hash: d0c5865f323aa9555662912f2ff96188f29096a6
Python version: 2.7.12
OCC version: 7.1.0
Locale: French/Canada (fr_CA)
FC017_Pad_Up_to_DatumPlane_nc1.fcstd
(33.85 KiB) Downloaded 21 times
NormandC
Postby NormandC » Thu Sep 07, 2017 4:14 am
If I create a slanted DatumPlane in an empty Body, then create a Circle sketch and pad it with "Up to face" set to the datum plane, I get a different error than you:
Pad: Extruding up to a face is only possible if the sketch plane is parallel to it
Yet it didn't complain with my slanted datum plane in the other file! :?
freecad-heini-1
Postby freecad-heini-1 » Thu Sep 07, 2017 7:09 am
In the German forum Stefan (ickby) wrote "it's a bug".
https://forum.freecadweb.org/viewtopic. ... 44#p189944
http://freecadweb.org/tracker/view.php?id=3177
freecad-heini-1
Postby freecad-heini-1 » Thu Sep 07, 2017 7:16 am
Your proposal:
Great idea! :D
Postby chrisb » Thu Sep 07, 2017 9:57 am
If others call it object we could do so too (I know I said something different before, but I'm willing to learn :? ). Then this term could be repeated for the Button, so that the connection of the two becomes clear.
Type: "Up to selected object"
Button: "Select object"
