Freecad 0.17 - Pad up to face - Datum Plane is invalid
vectronic
Re: Freecad 0.17 - Pad up to face - Datum Plane is invalid
Postby vectronic » Sun Sep 02, 2018 8:28 pm
@freedman, just checking in if you ended up raising this as a bug?
NormandC
Postby NormandC » Sun Sep 02, 2018 8:37 pm
@vectronic
I wish you had attached your FreeCAD file showing the issue. I believe this was reported in the past, but I need to make sure with your file.
TheMarkster
Postby TheMarkster » Mon Sep 03, 2018 5:20 am
@vectronic
Is this the same thing Werner fixed recently? padding to a datum plane with pad to face? I think he said there was a bug that causing the dimension to be zero.
NormandC
Postby NormandC » Mon Sep 03, 2018 8:11 am
No, I believe this is the same bug as issue #1190.
Site Admin
Postby wmayer » Mon Sep 03, 2018 8:16 am
At the least the issue the OP has reported is fixed.
NormandC
Postby NormandC » Mon Sep 03, 2018 8:21 am
Site Admin
Postby wmayer » Mon Sep 03, 2018 11:29 am
Unfortunately, with a limitation: https://freecadweb.org/tracker/view.php?id=3177#c11687
I only have fixed the case where the padding fails if the sketch is the first element in the body and a datum is used to limit the pad. However, I added one small extension too: the limiting plane doesn't need to be a plane but it suffices to be planar which e.g. includes a B-spline surface if all its poles lie on a plane.
I did not pay any attention to use a line, a point as limiting element or that the datum plane does not need to be parallel. When looking at the old code then there is an explicit check that the datum plane must be parallel to the sketch. I did not modify this behaviour.
NormandC
Postby NormandC » Mon Sep 03, 2018 8:58 pm
Thanks for the info. Should I create a separate Mantis report about it then? I really see no logical reason for purposely making this limitation.
vectronic
Postby vectronic » Mon Sep 03, 2018 9:56 pm
Now with added sample file (forgot that might be useful!)
If you change the "sticks_pad" pad parameters from "Up to face" to "Dimension" you will see a second item from the "sticks_sketch" sketch appear.
I realise now that this is different to the OP issue. Didn't mean to hijack the thread - still learning concepts in FreeCAD.
So I agree the issue I am experiencing is not
0003177: Part Design Pad should allow besides "Up to face" something like "Up to plane" as well
But can't say whether it is the same as:
0001190: Polar pattern doesn't obey UpToFirst/UpToLast/UpToFace pad features
Just tried this with:
OS: Mac OS X
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
test.FCStd
(36.53 KiB) Downloaded 10 times
NormandC
Postby NormandC » Mon Sep 03, 2018 10:33 pm
Thanks for providing your file. Sorry I was mistaken, I believe your issue is not related to issue #1190 which relates to Polar Pattern, this is not the case here.
This is a separate, third issue that does not depend on the datum plane: even if you select a face on the body, it fails to pad the second cylinder.
BTW is there a specific reason why the second set of circles is not constrained to the horizontal sketch axis, but is on a line only angled 0.0165833 degrees from the horizontal? This angle value is so negligible as to suggest some error...
