CAM simulation for the Path Workbench
realthunder
Re: CAM simulation for the Path Workbench
Postby realthunder » Thu Oct 26, 2017 10:09 am
This looks awesome! Excellent job
sliptonic
Postby sliptonic » Thu Oct 26, 2017 1:44 pm
shaise wrote:
Thu Oct 26, 2017 9:50 am
Hi Sliptonic,
I have managed to integrate my C++ voxel simulation into FreeCAD. The thing is, since it has C++ code, it can not be a separate module or macro.
I would like to integrate it into main freecad, but before issuing a pull request, I would like to talk to developpers in charge of the Path workbech, to ask some questions and make sure my code is acceptable by them.
This looks amazing. I can't wait. Do you use IRC or Gitter? For something like this, I'd recommend we meet in the Path room and do an informal walk-thru. It's easier to ask questions in realtime but is still logged and available to anyone who wants to join.
shaise
Postby shaise » Thu Oct 26, 2017 2:05 pm
Hi Sliptonic,
I have just joined gitter.
Do I just leave a long message there explaining what changes I made?
shai
JoshM
Postby JoshM » Wed Nov 15, 2017 2:55 pm
Hi Shaise,
I just used your simulator for a job I'm about to run. Initially I thought the icon was a placeholder because when I 1st tried to use it nothing happened--turns out because I have Custom-GCode Operations in my list which it doesn't like. It also doesn't like the Fixture-Operataion.
Once I deselected those from the simulation, it ran and is BEAUTIFUL! Thanks so much for your work. If anyone else hasn't tried this yet, you're missing a wonderful addition to FC-Path!
At maximum Speed, Best-Accuracy, it takes a couple of minutes to run on my PC.
Best Regards,
Josh
shaise
Postby shaise » Wed Nov 15, 2017 4:02 pm
Happy to hear it worked for you.
I will add Custom-GCode Operations to the to-do list.
What is the Fixture-Operataion? I am not familiar with.
JoshM
Postby JoshM » Wed Nov 15, 2017 4:54 pm
Hi Shaise,
The Fixture-Operation is under the Path-Partial_Commands, and all it does is specify the coordinate-system. In my case, I am using it to set my job in the G55 coordinate-system.
You really knocked this one out of the park!
If anyone wants to check it out on a semi-complex job, I saved a copy of my project and it simply requires that Fixture and Custom Commands be de-selected in order to run. https://ln.sync.com/dl/703870e60/6suhi2 ... t-ffesyjym
Best Regards,
Josh
roivai
Postby roivai » Wed Nov 15, 2017 8:32 pm
Hi Shaise,
I finally had time to build and try the new simulator. I did not succeed as well as others..
I'm running Linux. Just pulled the latest source like one hour ago.
OS: Debian GNU/Linux 8.6 (jessie)
Version: 0.17.12600 (Git)
Build type: Unknown
Hash: 987b8db0b5ab31ea4d5148787495b1ed856cef41
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
I created a simple path operation with one tool and two operations.
When I launch the simulator by clicking the icon on the toolbar I get:
Running the Python command 'Path_Simulator' failed:
  File "/home/pekka/builds/FreeCAD/freecad-build2/Mod/Path/PathScripts/PathSimulatorGui.py", line 519, in Activated
    pathSimulation.Activate()
  File "/home/pekka/builds/FreeCAD/freecad-build2/Mod/Path/PathScripts/PathSimulatorGui.py", line 82, in Activate
    self.SimulateMill()
  File "/home/pekka/builds/FreeCAD/freecad-build2/Mod/Path/PathScripts/PathSimulatorGui.py", line 154, in SimulateMill
    self.SetupSimulation()
  File "/home/pekka/builds/FreeCAD/freecad-build2/Mod/Path/PathScripts/PathSimulatorGui.py", line 105, in SetupSimulation
    self.SetupOperation(0)
  File "/home/pekka/builds/FreeCAD/freecad-build2/Mod/Path/PathScripts/PathSimulatorGui.py", line 112, in SetupOperation
    toolProf = self.CreateToolProfile(self.tool, Vector(0,1,0), Vector(0,0,0), self.tool.Diameter / 2.0)
  File "/home/pekka/builds/FreeCAD/freecad-build2/Mod/Path/PathScripts/PathSimulatorGui.py", line 392, in CreateToolProfile
    lR = Part.makeLine(vBR, vTR)
    Line through identic points
If I still go on and press the Play button, I get
  File "/home/pekka/builds/FreeCAD/freecad-build2/Mod/Path/PathScripts/PathSimulatorGui.py", line 243, in PerformCut
    self.PerformCutVoxel()
  File "/home/pekka/builds/FreeCAD/freecad-build2/Mod/Path/PathScripts/PathSimulatorGui.py", line 213, in PerformCutVoxel
    if self.resetSimulation:
AttributeError: PathSimulation instance has no attribute 'resetSimulation'
That error message keeps coming multiple times per second until I press Stop button..
My test file is attached.
Any clue what could be wrong? Thanks for any hints.
Pekka
simutest.fcstd
(18.08 KiB) Downloaded 20 times
shaise
Postby shaise » Wed Nov 15, 2017 10:41 pm
Hi roivai,
The tools you use are invalid.
Just edit your tools and give the cutting edge height a value other then 0.
shai
shaise
Postby shaise » Wed Nov 15, 2017 10:46 pm
Hi Josh,
I'm curious. How much time your complex simulation takes when you press the fast forward button. (this skips the animation but shows you the final result)
shai
JoshM
Postby JoshM » Thu Nov 16, 2017 2:37 pm
Hi Shai,
About 5 seconds--didn't catch on to that. Beautifully done. So, now I get it, I can look at final output in 5 Seconds or so, but playback if I need to see where something bad happened. That's so cool!
Thanks,
Josh
Version: 0.17.12595 (Git)
Hash: 8c7bb0cd551cf11551ff71d716a16211c6d5e13d
Python version: 2.7.8
OCC version: 7.1.0
