[solved] FreeCAD crashes after start
XQAcDozu
Postby XQAcDozu » Mon Sep 25, 2017 3:18 pm
FreeCAD-0.16-1.15.x86_64
On openSUSE Leap 42.3
KDE Plasma: 5.8.7
QT-Version: 5.6.2
Kernel Version: 4.4.87-25-default 64 bit
1. Start on Bash
2. clicking on Draft
3. It crashes
$ FreeCAD
FreeCAD 0.16, Libs: 0.16RUnknown
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
Unhandled std::exception caught in GUIApplication::notify.
The error message is: Keine Berechtigung
Draft workbench activated
FreeCAD: SoType.cpp:730: SbBool SoType::isDerivedFrom(SoType) const: Zusicherung »!this->isBad()« nicht erfüllt.
Abgebrochen (Speicherabzug geschrieben)
OS: "openSUSE Leap 42.3"
Version: 0.16.Unknown
Python version: 2.7.13
Qt version: 4.8.6
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18
Site Admin
Re: FreeCAD crashes after start
Postby wmayer » Mon Sep 25, 2017 4:55 pm
Check the dependencies of the _coin.so lib of the pivy package and libFreeCADGui.so
ldd _coin.so
ldd libFreeCADGui.so
What is the output of both?
XQAcDozu
Postby XQAcDozu » Mon Sep 25, 2017 6:03 pm
there is no _coin.so, only
/usr/lib64 # find . -iname "*coin*" -exec ls -l {} \;
lrwxrwxrwx 1 root root 17 26. Dez 2016  ./libCoin.so.80 -> libCoin.so.80.0.0
-rwxr-xr-x 1 root root 10165896 18. Nov 2016  ./libCoin.so.80.0.0
lrwxrwxrwx 1 root root 17 15. Aug 22:50 ./libCoin.so.60 -> libCoin.so.60.1.3
-rwxr-xr-x 1 root root 9506272 22. Mai 19:04 ./libCoin.so.60.1.3
and here is the output of ...
/usr/lib64 # ldd ./FreeCAD/lib/libFreeCADGui.so
        linux-vdso.so.1 (0x00007ffef8b6f000)
        libFreeCADApp.so => /usr/lib64/FreeCAD/lib/libFreeCADApp.so (0x00007fc176754000)
        libCoin.so.60 => /usr/lib64/libCoin.so.60 (0x00007fc175c3c000)
        libGL.so.1 => /usr/lib64/libGL.so.1 (0x00007fc1759cc000)
        libX11.so.6 => /usr/lib64/libX11.so.6 (0x00007fc17568c000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fc17546c000)
        libQtOpenGL.so.4 => /usr/lib64/libQtOpenGL.so.4 (0x00007fc17516c000)
        libQtSvg.so.4 => /usr/lib64/libQtSvg.so.4 (0x00007fc174f14000)
        libQtWebKit.so.4 => /usr/lib64/libQtWebKit.so.4 (0x00007fc172bbc000)
        libQtGui.so.4 => /usr/lib64/libQtGui.so.4 (0x00007fc171efc000)
        libQtXml.so.4 => /usr/lib64/libQtXml.so.4 (0x00007fc171cb4000)
        libQtNetwork.so.4 => /usr/lib64/libQtNetwork.so.4 (0x00007fc17196c000)
        libQtCore.so.4 => /usr/lib64/libQtCore.so.4 (0x00007fc17147c000)
        libboost_regex.so.1.58.0 => /usr/lib64/libboost_regex.so.1.58.0 (0x00007fc171174000)
        libboost_signals.so.1.58.0 => /usr/lib64/libboost_signals.so.1.58.0 (0x00007fc170f5c000)
        libboost_system.so.1.58.0 => /usr/lib64/libboost_system.so.1.58.0 (0x00007fc170d54000)
        libspnav.so.0 => /usr/lib64/libspnav.so.0 (0x00007fc170b4c000)
        libshiboken-python2.7.so.1.2 => /usr/lib64/libshiboken-python2.7.so.1.2 (0x00007fc17091c000)
        libFreeCADBase.so => /usr/lib64/FreeCAD/lib/libFreeCADBase.so (0x00007fc17059c000)
        libpython2.7.so.1.0 => /usr/lib64/libpython2.7.so.1.0 (0x00007fc17018c000)
        libxerces-c-3.1.so => /usr/lib64/libxerces-c-3.1.so (0x00007fc16fbcc000)
        libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007fc16f83c000)
        libm.so.6 => /lib64/libm.so.6 (0x00007fc16f53c000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fc16f324000)
        libc.so.6 => /lib64/libc.so.6 (0x00007fc16ef7c000)
        libboost_program_options.so.1.58.0 => /usr/lib64/libboost_program_options.so.1.58.0 (0x00007fc16ed04000)
        libGLU.so.1 => /usr/lib64/libGLU.so.1 (0x00007fc16ea84000)
        libbz2.so.1 => /usr/lib64/libbz2.so.1 (0x00007fc16e874000)
        libz.so.1 => /lib64/libz.so.1 (0x00007fc16e65c000)
        libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00007fc16e3bc000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007fc16e1b4000)
        libopenal.so.1 => /usr/lib64/libopenal.so.1 (0x00007fc16df44000)
        libexpat.so.1 => /usr/lib64/libexpat.so.1 (0x00007fc16dd14000)
        libxcb-dri3.so.0 => /usr/lib64/libxcb-dri3.so.0 (0x00007fc16db0c000)
        libxcb-present.so.0 => /usr/lib64/libxcb-present.so.0 (0x00007fc16d904000)
        libxcb-sync.so.1 => /usr/lib64/libxcb-sync.so.1 (0x00007fc16d6fc000)
        libxshmfence.so.1 => /usr/lib64/libxshmfence.so.1 (0x00007fc16d4f4000)
        libglapi.so.0 => /usr/lib64/libglapi.so.0 (0x00007fc16d2c4000)
        libXext.so.6 => /usr/lib64/libXext.so.6 (0x00007fc16d0ac000)
        libXdamage.so.1 => /usr/lib64/libXdamage.so.1 (0x00007fc16cea4000)
        libXfixes.so.3 => /usr/lib64/libXfixes.so.3 (0x00007fc16cc9c000)
        libX11-xcb.so.1 => /usr/lib64/libX11-xcb.so.1 (0x00007fc16ca94000)
        libxcb-glx.so.0 => /usr/lib64/libxcb-glx.so.0 (0x00007fc16c87c000)
        libxcb-dri2.so.0 => /usr/lib64/libxcb-dri2.so.0 (0x00007fc16c674000)
        libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x00007fc16c454000)
        libXxf86vm.so.1 => /usr/lib64/libXxf86vm.so.1 (0x00007fc16c24c000)
        libdrm.so.2 => /usr/lib64/libdrm.so.2 (0x00007fc16c034000)
        /lib64/ld-linux-x86-64.so.2 (0x00007fc1777fc000)
        libXrender.so.1 => /usr/lib64/libXrender.so.1 (0x00007fc16be24000)
        libjpeg.so.8 => /usr/lib64/libjpeg.so.8 (0x00007fc16bbcc000)
        libpng16.so.16 => /usr/lib64/libpng16.so.16 (0x00007fc16b98c000)
        libwebp.so.5 => /usr/lib64/libwebp.so.5 (0x00007fc16b72c000)
        libxslt.so.1 => /usr/lib64/libxslt.so.1 (0x00007fc16b4ec000)
        libxml2.so.2 => /usr/lib64/libxml2.so.2 (0x00007fc16b17c000)
        libgstapp-1.0.so.0 => /usr/lib64/libgstapp-1.0.so.0 (0x00007fc16af6c000)
        libgstpbutils-1.0.so.0 => /usr/lib64/libgstpbutils-1.0.so.0 (0x00007fc16ad34000)
        libgstvideo-1.0.so.0 => /usr/lib64/libgstvideo-1.0.so.0 (0x00007fc16aaac000)
        libgstaudio-1.0.so.0 => /usr/lib64/libgstaudio-1.0.so.0 (0x00007fc16a84c000)
        libgstbase-1.0.so.0 => /usr/lib64/libgstbase-1.0.so.0 (0x00007fc16a5ec000)
        libgstreamer-1.0.so.0 => /usr/lib64/libgstreamer-1.0.so.0 (0x00007fc16a2c4000)
        libgobject-2.0.so.0 => /usr/lib64/libgobject-2.0.so.0 (0x00007fc16a06c000)
        libglib-2.0.so.0 => /usr/lib64/libglib-2.0.so.0 (0x00007fc169d5c000)
        libsqlite3.so.0 => /usr/lib64/libsqlite3.so.0 (0x00007fc169a94000)
        libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1 (0x00007fc169854000)
        libSM.so.6 => /usr/lib64/libSM.so.6 (0x00007fc16964c000)
        libICE.so.6 => /usr/lib64/libICE.so.6 (0x00007fc16942c000)
        libXi.so.6 => /usr/lib64/libXi.so.6 (0x00007fc16921c000)
        libXrandr.so.2 => /usr/lib64/libXrandr.so.2 (0x00007fc16900c000)
        libXcursor.so.1 => /usr/lib64/libXcursor.so.1 (0x00007fc168dfc000)
        libXinerama.so.1 => /usr/lib64/libXinerama.so.1 (0x00007fc168bf4000)
        libssl.so.1.0.0 => /lib64/libssl.so.1.0.0 (0x00007fc168984000)
        libcrypto.so.1.0.0 => /lib64/libcrypto.so.1.0.0 (0x00007fc168524000)
        librt.so.1 => /lib64/librt.so.1 (0x00007fc16831c000)
        libicui18n.so.52.1 => /usr/lib64/libicui18n.so.52.1 (0x00007fc167f04000)
        libicuuc.so.52.1 => /usr/lib64/libicuuc.so.52.1 (0x00007fc167b84000)
        libutil.so.1 => /lib64/libutil.so.1 (0x00007fc16797c000)
        libXau.so.6 => /usr/lib64/libXau.so.6 (0x00007fc167774000)
        liblzma.so.5 => /usr/lib64/liblzma.so.5 (0x00007fc167544000)
        libgsttag-1.0.so.0 => /usr/lib64/libgsttag-1.0.so.0 (0x00007fc167304000)
        liborc-0.4.so.0 => /usr/lib64/liborc-0.4.so.0 (0x00007fc16707c000)
        libgmodule-2.0.so.0 => /usr/lib64/libgmodule-2.0.so.0 (0x00007fc166e74000)
        libffi.so.4 => /usr/lib64/libffi.so.4 (0x00007fc166c64000)
        libpcre.so.1 => /usr/lib64/libpcre.so.1 (0x00007fc1669f4000)
        libuuid.so.1 => /usr/lib64/libuuid.so.1 (0x00007fc1667ec000)
        libicudata.so.52.1 => /usr/lib64/libicudata.so.52.1 (0x00007fc1665e4000)
I get the feeling, that this will be your next question
/usr/lib64 # rpm -aq | grep pivy
python-pivy-0.5.0+hg20101206.2327-2.2.x86_64
Greetings
Qt version: 4.8.6
Coin version: 3.1.3
Site Admin
Postby wmayer » Mon Sep 25, 2017 7:32 pm
Don't you have a package called pivy or python-pivy on suse? Usually you get this error
when an application links two different Coin versions.
Obviously FreeCAD GUI links against libCoin.so.60 which is v3.1.3 and another library (I assume pivy) links against libCoin.so.80 which is 3.1.4 (or 4.0.0)
XQAcDozu
Postby XQAcDozu » Mon Sep 25, 2017 8:04 pm
already posted I installed python-pivy from packman
I found the coin lib files under
/usr/lib/python2.7/site-packages/pivy/_coin.so
and
On which path does FreeCAD looking for these librarys? Maybe it would help to create a logical link on this path.
Greetings
Qt version: 4.8.6
Coin version: 3.1.3
Site Admin
Postby wmayer » Tue Sep 26, 2017 12:42 pm
Oh, I overlooked this.
So, what is the output of
ldd /usr/lib/python2.7/site-packages/pivy/_coin.so
Is it also /usr/lib64/libCoin.so.60 or is it /usr/lib64/libCoin.so.80?
It's not the problem that FreeCAD can't find the library. The problem is that two different Coin versions are loaded at runtime and this leads to undefined behaviour.
XQAcDozu
Postby XQAcDozu » Tue Sep 26, 2017 4:05 pm
$ ldd /usr/lib/python2.7/site-packages/pivy/_coin.so | grep libCoin
        libCoin.so.80 => /usr/lib64/libCoin.so.80 (0x00007efe9245f000)
$ ldd /usr/lib/python2.7/site-packages/pivy/_coin.so | grep 60
Well, if I understand right, FreeCAD needs libCoin 60, but python links 80s version. Is there an elegant method to bend the linker to the right library?
Greetings
Qt version: 4.8.6
Coin version: 3.1.3
Site Admin
Postby wmayer » Tue Sep 26, 2017 5:15 pm
No, that's not possible. Coin3d is a C++ library and version 3.1.3 and 3.1.4 (or 4.0.0 respectively) are binary incompatible. Any attempt to trick out the linker will either lead to an immediate crash or the linker reports unresolved symbols.
The one and only way is to report a bug to the package maintainer. Since pivy links against the newer version I recommend to contact the package maintainer for FreecAD to move to the newer Coin3d version. This should be fairly easy because only a build script or so needs to be adjusted, I guess. Source code of FreeCAD doesn't need to be touched as it runs with that Coin3d version for several years now.
XQAcDozu
Postby XQAcDozu » Wed Oct 04, 2017 7:03 pm
after deinstalling python-pivy FreeCAD starts and loads old sketches without crashing.
Currently I don't see a negative effect on FreeCAD. It will take time to find side effects.
Qt version: 4.8.6
Coin version: 3.1.3
Site Admin
Re: [solved] FreeCAD crashes after start
Postby wmayer » Thu Oct 05, 2017 6:21 am
The side-effects will be that modules like Arch or Draft cannot be used any more.
