Well there is no advantage in having one of them, and changing the existing one is not a good idea. However if you have both you have the benefits of both and only the disadvantages of the one you're currently using.GeneFC wrote: ↑Sat Sep 30, 2017 3:32 pmThat sort of behavior is a choice made by the program designers. I have some graphics-related programs that work on the "touch" method and other that require the entire object to be selected.SparkyCola wrote: ↑Sat Sep 30, 2017 1:24 pmI can't get Sketcher to select the whole line/circle/element when I only box a part of it, no matter from where I start the selection. That is what I was looking for.
There are pluses and minuses to both approaches. The "touch" method sounds easy, but it also makes it very easy to select unwanted elements that may have portions close to the desired selection. The "entire" method is generally more definite for selection, but it is slightly more work.
I don't see an obvious advantage for one method over the other.
Just learn the "rules" and go forward.
Gene
