help on sheet metal script
jaisejames
Re: help on sheet metal script
Postby jaisejames » Sat Nov 11, 2017 4:11 pm
First thank you for the sheet metal work bench. If it is working properly, definitely you can add. :)
shaise
Postby shaise » Sat Nov 11, 2017 5:25 pm
@jaisejames, your script works great, but it is not backward compatible. If you try to load old files with sheetmetal, and try to modify old bends, it will throw an error. I have fixed that so it will work, and commited the changes.
See line 193, if you want to know what I added.
Thanks!
shai
jaisejames
Postby jaisejames » Sun Nov 12, 2017 6:53 am
Another option added "Simple Fold". please check & tell me, it will be useful or not.
Selection face is same as bend.
SimpleFold.py
(8.6 KiB) Downloaded 38 times
shaise
Postby shaise » Sun Nov 12, 2017 9:14 am
Can you explain what it does and how you integrated it?
jaisejames
Postby jaisejames » Wed Mar 21, 2018 12:41 pm
I added simple edit option to bend.
Double click on sheet metal to open. Useful to rescue for some cases model is broken due to topological name changing
SheetMetalCmd.py
(18.5 KiB) Downloaded 32 times
sheetmetal edit.png (8.26 KiB) Viewed 711 times
jaisejames
Postby jaisejames » Fri Jun 15, 2018 1:33 pm
I modified sheetmetalCmd.py[attached]
* Rectified miter-angle code work with unfold
* Added Round Relief
* Added extend wall to add corner relief [manual process]
* double click to edit face selected [ work if base created part workbench, not working in PartDesign Exception : getEditDialog() not implemented ]
SheetMetalCmd.py
(19.76 KiB) Downloaded 31 times
Postby chrisb » Fri Jun 15, 2018 7:08 pm
Good stuff, thanks. Do I have to exchange the attached file manually or is it sufficient to update via Addon Manager?
jaisejames
Postby jaisejames » Sat Jun 16, 2018 12:33 pm
Backup your exsisting sheetmetalCmd.py, then copy & replace.
shaise
Postby shaise » Mon Jun 18, 2018 11:51 am
Hi Jaisejams,
I like your changes!
I want to add it officially to the WB. It looks like the round relief option works good and also backward compatible, so this is very good.
But I have some issues with the edit window.
1. If there are more then one face bended, I can see only one in the list. Pressing the add, actualy replace the current face, not adding. Is it intended?
2. Pressing Add without selecting anything generates an error.
3. a bit related to 1: selecting more then one face and pressing add, again shows only one face, even though actually when pressing OK, both faces will be bended.
4. If you find a way to make it work on "Part Design" as well, this will be great. If not, maybe just show a message that it works only on "Part".
Great work!
shai
jaisejames
Postby jaisejames » Tue Jun 19, 2018 5:08 am
Edit is implemented to rescue model as no of face changes during adding gap or extend, selected bend face will shift to another face than required. Currently We do not any Gui or data tab editing like property-link method to change face.
It will do for current selected bend only.
We hope that somebody experienced like yorik or wmayer implement editing for selected face like they implemented for propertylink and liklist.
Example it is possible like our expression editor, on click, it will be in observe mode & clik OK or Disard will exit.
