help on sheet metal script
jaisejames
Re: help on sheet metal script
Postby jaisejames » Mon Feb 04, 2019 5:28 am
Seems to be some precision issue with part 3d offset. if I change Length from 20 to 21 or 19, it works. If I changes thickness to 1.001 or any other value, offset is success. No much idea why it is happening.
reox
Postby reox » Wed Feb 20, 2019 6:49 pm
A topic came up in the german subforum regarding bend along sketch line.
It looks like that this feature was somewhere developed but did not find it's way into master.
@wega found the code and merged it into master here: https://forum.freecadweb.org/viewtopic. ... 20#p288098 (not in git)
Would be nice to see this feature in the master. Is the code sitting somewhere, waiting to be merged?
Postby Kunda1 » Sat Feb 23, 2019 12:36 pm
I don't see it in the PR queue
Care to make a PR ?
reox
Postby reox » Sat Feb 23, 2019 12:43 pm
Care to make a PR ?
I somehow put the files @wega supplied into a repo, see here: https://github.com/shaise/FreeCAD_Sheet ... x:new_wall
But some things do not work and there are three different invert options and I have no idea what they are about.
Also I found some code which will not work (grep for FIXME)
I'll create a PR and comment on the things which probably need some fixing.
Postby Kunda1 » Sat Feb 23, 2019 1:45 pm
shaise wrote:
At your convenience, care to weight in?
shaise
Postby shaise » Sat Feb 23, 2019 3:21 pm
Its a nice feature, but unless most of the issues are resolved, I do not think it should be merged.
jaisejames
Postby jaisejames » Sun Feb 24, 2019 2:51 pm
pls see new Fold Along line code
import Part
import BOPTools.SplitFeatures, BOPTools.JoinFeatures
def smthk(obj, foldface) :
  normal = foldface.normalAt(0,0)
  theVol = obj.Volume
  if theVol < 0.0001:
      SMError("Shape is not a real 3D-object or to small for a metal-sheet!")
  else:
      # Make a first estimate of the thickness
      estimated_thk = theVol/(obj.Area / 2.0)
  p1 = foldface.CenterOfMass
  p2 = foldface.CenterOfMass + estimated_thk * -1.3 * normal
  e1 = Part.makeLine(p1, p2)
  thkedge = obj.common(e1)
  thk = thkedge.Length
  return thk
def smFold(bendR = 1.0, bendA = 90.0, kfactor = 0.45, invertbend = False, flipped = False, unfold = False,
            bendlinesketch = None, selFaceNames = '', MainObject = None):
  FoldShape = MainObject.Shape
  foldface = FoldShape.getElement(selFaceNames[0])
  thk = smthk(FoldShape, foldface)
  offset = thk / 2.0 * kfactor
  tool = bendlinesketch.Shape
  tool_faces = tool.extrude(normal * -thk)
  #Part.show(tool_faces)
  cutSolid = BOPTools.SplitAPI.slice(FoldShape, tool_faces.Faces, "Standard", 0.0)
  cutface = BOPTools.SplitAPI.slice(foldface, tool.Edges, "Standard", 0.0)
  sketch = tool.copy()
  sketch.translate(normal * -offset)
  cutface.translate(normal * -offset)
  Axis = FoldShape.common(sketch)
  #Part.show(Axis)
  edge = Axis.Edges[0]
  revAxisP = edge.valueAt(edge.FirstParameter)
  revAxisV = edge.valueAt(edge.LastParameter) - edge.valueAt(edge.FirstParameter)
  revAxisV.normalize()
  face0 = cutface.childShapes()[0]
  face1 = cutface.childShapes()[1]
  face1.rotate(revAxisP, revAxisV, bendA)
  #Part.show(face1)
  facecommon = face1.common(tool)
  #Part.show(facecommon)
  if not(facecommon.Edges) :
    revAxisV = revAxisV * -1
  solid0 = cutSolid.childShapes()[0]
  solid1 = cutSolid.childShapes()[1]
  solid1.rotate(revAxisP, revAxisV, bendA)
  #Part.show(solid0)
  #Part.show(solid1)
  facelist = [face0, face1]
  joinface = BOPTools.JoinAPI.connect(facelist)
  filletedface = joinface.makeFillet(bendR + offset, joinface.Edges)
  #Part.show(filletedface)
  offsetfacelist = []
  offsetsolidlist = []
  for face in filletedface.Faces :
    if str(face.Surface) != "<Plane object>" :
      offsetface = face.makeOffsetShape(offset-thk, 0.0)
      #Part.show(offsetface)
      offsetfacelist.append(offsetface)
  for face in offsetfacelist :
    offsetsolid = face.makeOffsetShape(thk, 0.0, fill = True)
    #Part.show(offsetsolid)
    offsetsolidlist.append(offsetsolid)
  if len(offsetsolidlist) > 1 :
    offsetsolid = offsetsolidlist[0].multiFuse(offsetsolidlist[1:])
  else :
  cutsolid1 = BOPTools.JoinAPI.cutout_legacy(solid0, offsetsolid, 0.0)
  cutsolid2 = BOPTools.JoinAPI.cutout_legacy(solid1, offsetsolid, 0.0)
  solidlist = [cutsolid1, cutsolid2, offsetsolid]
  resultsolid = BOPTools.JoinAPI.connect(solidlist)
  return resultsolid
base = Gui.Selection.getSelectionEx()[0].Object
face = Gui.Selection.getSelectionEx()[0].SubElementNames
sketch = Gui.Selection.getSelectionEx()[1].Object
a = smFold(bendR = 1.0, bendA = 90.0, kfactor = 0.4, bendlinesketch = sketch, selFaceNames = face, MainObject = base)
Part.show(a)
Steps
1. select face required to bend.
2. select sketch on that
unfolded view.png (27.69 KiB) Viewed 582 times
folded view.png (21.61 KiB) Viewed 582 times
easyw-fc
Postby easyw-fc » Sun Feb 24, 2019 3:15 pm
@jaisejames
would you mind to post the FC file too?
Thanks
freecad-heini-1
Postby freecad-heini-1 » Sun Feb 24, 2019 4:43 pm
import Part
  theVol = obj.Volume
  if theVol < 0.0001:
  else:
  return thk
  #Part.show(Axis)
  #Part.show(face1)
  #Part.show(solid0)
  #Part.show(solid1)
  offsetfacelist = []
  else :
  return resultsolid
Part.show(a)
Steps
Whow, thank you so much, very nice. Here is an example from the German forum section:
Forumfrage_Sheetmetal2_FH-1.FCStd
(22.02 KiB) Downloaded 38 times
If the sketch dimension is on 0mm it works, but if the sketch is on 2,5mm it fails, because of the hole, I guess.
The hole should be deformed a little bit, like to see in my video with Creo:
https://peertube.mastodon.host/videos/w ... afe1c4eeaf
The wallthickness is 5mm, the bend radius 5mm, angle 45°.
Any idea to solve this?
reox
Postby reox » Sun Feb 24, 2019 5:29 pm
true. better use the new one then.
