FC 0.17/Qt5 compatible NaviCube
Moderator: agryson
nyholku
Postby nyholku » Sat Nov 18, 2017 11:12 am
Hi everyone,
I've updated my experimental NaviCube to FC 0.17 code base and refactored it to be compatible with Qt5.
You can find the code here:
https://github.com/nyholku/FreeCAD/tree/navicube-qt5
Screenshot below.
wbr Kusti
Screen Shot 2017-11-18 at 13.10.53.png (246.03 KiB) Viewed 2501 times
Jee-Bee
Re: FC 0.17/Qt5 compatible NaviCube
Postby Jee-Bee » Sat Nov 18, 2017 1:52 pm
Nice work!!
triplus
Postby triplus » Tue Nov 21, 2017 4:12 pm
It works when compiled on Ubuntu 16.04 (Qt 5).
P.S. Has the size changed and it is a bit bigger?
Postby Kunda1 » Tue Nov 21, 2017 4:19 pm
Will this be part of 0.17 release ?
If not we should track it via the bugtracker as well.
nyholku
Postby nyholku » Tue Nov 21, 2017 7:07 pm
Yes, it is a bit bigger, I felt it now optimal for me, but this is not final. Might be configurable. We'll see.
regis
Postby regis » Fri Dec 08, 2017 3:13 pm
Hi everyone,
Screenshot below.
wbr Kusti
Amazing, but I see a bunch of new icons, that i don't see often, what are those?
pablogil
Postby pablogil » Fri Dec 08, 2017 10:50 pm
I have the feeling it has been asked before but: could Navicube be ported to an “easy to install” addon?
It’s so cool that I feel it should go into master or shared as an addon...
Thanks
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
Dacicusan
Postby Dacicusan » Sat Dec 09, 2017 9:04 am
Very nice interface. This will make FreeCAD more usable.
The icons are also nice. They are available for download? Maybe a new icon theme using this icons will make the interface more pleasant to work with.
looo
Postby looo » Sat Dec 09, 2017 9:46 am
It's a nice add-on but last time I tried it, it slowed down the scene quite a bit. I don't know how it is implemented, but it feels like a qt-widget overlay?
nyholku
Postby nyholku » Sat Dec 09, 2017 4:11 pm
Slowed down?
Hmm, interesting, did not notice that.
It is not a qwidget it simply taps to the opengl render/redraw call on (on View3DInventorViewer) and renders to the OpenGL context (just like the standard XYZ axise orientation indicator) so I would not expect drawing twenty odd more polygons make any difference.
Hmm...perhaps it is the cursor tracking that takes time as this draws offscreen (but then again that is just the same few polygons).
I may have to investigate this further.
wbr Kusti
PS Those new icons are from here:
https://github.com/pgilfernandez/FreeCA ... eme_simple
