Assembly3 preview
realthunder
Re: Assembly3 preview
Postby realthunder » Sat Mar 31, 2018 12:04 am
triplus wrote:
Fri Mar 30, 2018 3:54 pm
Yes. When you enabled redundant constraint tolerance. PlaneAlignment started to work more like Assembly 2. Composite constraints didn't cause solver troubles anymore as before. After you added the additional logic to handle composite constraints. I got results as seen above. I didn't save the original file therefore i made a new one and attached it. Notice that it only took 2 PlaneAlignment constraints this time for things to start misbehaving. In addition try to delete a cube from assembly (FreeCAD crash).
I have added property to Assembly container named 'AutoRelax' to let user turn on/off this option. It is by default off right now, because it is apparently not matured yet. PlaneCoincident relaxation is always on regardless of this setting because SolveSpace always fail otherwise. The crash seems to have been fixed, as I cannot repeat it. I am about to release a new version, so I am in asm3 master branch and FreeCAD LinkStage3 now.
realthunder
Postby realthunder » Sat Mar 31, 2018 12:12 am
GlouGlou wrote:
Fri Mar 30, 2018 2:39 pm
I agree with that. But its not possible to use clones?
You don't want to use clone here, because you loose all the useful child objects.
If you don't want the assembly to touch your body's placement, simple right click the item in the tree view and select 'Link actions' -> 'Make link', and then add the newly created link to the assembly container, instead. This way, you can access the child object as usual.
If that is your workflow, i.e. you never want assembly to change your original object's placement, change the 'Parts' (under assembly) container's property 'GroupMode' to 'AutoLink' or 'AutoUnlink'. Now, when drag anything into the assembly, it will automatically create link(s) for you. If 'GroupMode' is 'AutoUnlink', if you drag out the link inside the assembly, it will auto delete the link.
realthunder
Postby realthunder » Sat Mar 31, 2018 5:52 am
New version is released, although this release is mostly for testing the new topological naming in Part workbench.
triplus
Postby triplus » Sat Mar 31, 2018 3:25 pm
Sounds reasonable.
Good to hear that.
freecad-heini-1
Postby freecad-heini-1 » Sat Mar 31, 2018 5:20 pm
Whow, what a great Easter present for us.
Thank you so much Realthunder.
I tried the appimage:
Happy Easter to all.
GlouGlou
Postby GlouGlou » Fri Apr 06, 2018 8:33 am
about the new realease
Arrgggg :cry: how to disable auto highlight? its useless, and make a lot of bug.
.cannot select any face or edge
.cannot use ext geometry
realthunder
Postby realthunder » Fri Apr 06, 2018 8:38 am
Right click anywhere in the tree view, select 'Tree View Options' -> 'Pre-Select'. Could you please elaborate on the problem you have encountered? Better if you can attach some screencast, and the FreeCAD about page.
GlouGlou
Postby GlouGlou » Fri Apr 06, 2018 10:32 am
ok for the autohighlight ;)
I still can't select any edge as external geometry on sketch 4.
test.FCStd
(28.66 KiB) Downloaded 10 times
realthunder
Postby realthunder » Sat Apr 07, 2018 12:18 am
Thanks to your reporting, I've identified and fixed at least three bugs. Can you build FreeCAD yourself? If so, please sync and update LinkStage3. If not, I can release a bug fix version. I'll release it either way, but would like to wait for a while in case there are other bugs reported.
GlouGlou
Postby GlouGlou » Sat Apr 07, 2018 1:22 am
No, sorry im a only W10 user :roll:
