Assembly3 preview
freecad-heini-1
Re: Assembly3 preview
Postby freecad-heini-1 » Fri Jun 08, 2018 2:23 pm
Gentlemen, nice to see your teamwork in such a constructive manner.
realthunder
Postby realthunder » Fri Jun 08, 2018 2:52 pm
easyw-fc wrote:
Fri Jun 08, 2018 1:44 pm
For a better comparison, would it be possible to have also an option to convert the Links to only Part containers when exporting the file?
For exporting, there is no need to change object type, just call Part::getTopoShape(), which is the work horse behind python Part.getShape(). But then that means I'll have to change upstream exporter code. But what exactly do you want to compare by doing this?
easyw-fc
Postby easyw-fc » Fri Jun 08, 2018 3:17 pm
I would like to let both exporters cohabit till the new branch get a full stability with a larger user audience.
may be we are too involved into FC to keep this at a non emotional level
realthunder
Postby realthunder » Fri Jun 08, 2018 3:37 pm
In that case, I'd suggestion using a macro. I'll modify the script you passed to me tomorrow. BTW, the hang problem is fixed. Any other problem you found?
easyw-fc
Postby easyw-fc » Fri Jun 08, 2018 3:55 pm
thx, I'll appreciate it :D
Just started testing, but it seems many issue have gone :)
I noticed that in some case, some of the STEP objects get strange colors... (here a test with arietta imported with both modes)
I think this A3 branch would add a new 'STEP' improvement for CAD interoperability, apart the other big one on the assembly and constraints wb that was still missing ;)
EDIT
frame rate is still better in FC mainstream with VBO enabled...
a part the fps displayed, you can see that the FC mainstream board is turning faster than the A3 branch one...
I'm using the following code for spinning comparison
FreeCADGui.ActiveDocument.ActiveView.startAnimating(0,1,0,0.2)
May be you can get some useful reference here:
https://forum.freecadweb.org/viewtopic. ... 7&start=20
realthunder
Postby realthunder » Sat Jun 09, 2018 3:11 pm
STEP file can save colors for both edge and face. And this particular STEP file sets both face and edge color with the same value. It is weird when displayed in FC. I'll ignore the edge color in case the shape has face, and the face color is the same as edge color.
Thanks, I'll check later.
Here is script for copying linked objects. You can select any object(s) in any document(s), and switch to a new document before calling this function to copy the object(s) into that document.
import FreeCAD, FreeCADGui, Part
def copy_obj(parentObj=None,doc=None,subname=''):
    if not doc:
        # 'doc' allows you to copy object into another document.
        # If not give, then use the current document.
        doc = FreeCAD.ActiveDocument
    if not parentObj:
        # If no object is given, then obtain selection from all opened document
        parentObj = []
        for sel in FreeCADGui.Selection.getSelectionEx('*'):
            parentObj.append(sel.Object)
        if not parentObj:
            return
    if isinstance(parentObj,(tuple,list)):
        if len(parentObj) == 1:
            copy = copy_obj(parentObj[0],doc)
        else:
            part = doc.addObject('App::Part','Part')
            for o in parentObj:
                copy = copy_obj(o,doc)
                if copy:
                    part.addObject(copy)
            copy = part
        if copy:
            FreeCADGui.SendMsgToActiveView("ViewFit")
            copy.recompute(True)
        return copy
    obj,matrix = parentObj.getSubObject(subname,1,FreeCAD.Matrix(),not subname)
    if not obj:
        return
    # getSubObjects() is the API for getting child of a group. It returns a list
    # of subnames, and the subname inside may contain more than one levels of
    # hierarchy. Assembly uses this API to skip hierarchy to PartGroup.
    subs = obj.getSubObjects()
    if not subs:
        # Non group object will return empty subs
        shape = Part.getShape(obj,transform=False)
        if shape.isNull():
            return
        shape.transformShape(matrix,False,True)
        copy = doc.addObject('Part::Feature',obj.Name)
        copy.Label = obj.Label
        copy.Shape = shape
        copy.ViewObject.mapShapeColors(obj.Document)
        return copy
    part = doc.addObject('App::Part',obj.Name)
    part.Label = obj.Label
    part.Placement = FreeCAD.Placement(matrix)
    for sub in subs:
        sobj,parent,childName,_ = obj.resolve(sub)
        if not sobj:
            continue
        copy = copy_obj(obj,doc,sub)
        if not copy:
            continue
        vis = parent.isElementVisible(childName)
        if vis < 0:
            copy.Visibility = sobj.Visibility
        else:
            copy.Visibility = vis>0
    return part
realthunder
Postby realthunder » Sat Jun 09, 2018 4:52 pm
I have trace the code for VBO rendering, at least on Linux, my code has no effect on VBO. That is really a mystery, and I really want to know why it behave like that on your machine. Here is a screencast showing the effect of VBO active and inactive. Rendering transparency disables VBO. The 17fps is about the same for App::Part on my machine.
kwahoo
Postby kwahoo » Sat Jun 09, 2018 7:50 pm
Excuse me interrupting your (interesting!) rendering discussion, but I have to report something confusing me in 0.6.2 release;)
Is offset property in the PlaneAlignment constraint supposed to work?
If I set "Offset" value to eg. 10mm it gives me an error:
<asm3.gui> 846.976399 - gui.py(226): command "asm3CmdSolve" exception
  File "/tmp/.mount_FreeCAF9bJ5F/usr/lib/freecad-daily/Ext/freecad/asm3/FCADLogger.py", line 106, in report
    return func(*args,**kargs)
  File "/tmp/.mount_FreeCAF9bJ5F/usr/lib/freecad-daily/Ext/freecad/asm3/solver.py", line 348, in solve
    return _solve(*args,**kargs)
  File "/tmp/.mount_FreeCAF9bJ5F/usr/lib/freecad-daily/Ext/freecad/asm3/solver.py", line 318, in _solve
    Solver(assembly,reportFailed,dragPart,recompute,rollback)
  File "/tmp/.mount_FreeCAF9bJ5F/usr/lib/freecad-daily/Ext/freecad/asm3/solver.py", line 67, in __init__
    ret = Constraint.prepare(cstr,self)
  File "/tmp/.mount_FreeCAF9bJ5F/usr/lib/freecad-daily/Ext/freecad/asm3/constraint.py", line 469, in prepare
    return mcs.getProxy(obj).prepare(obj,solver)
  File "/tmp/.mount_FreeCAF9bJ5F/usr/lib/freecad-daily/Ext/freecad/asm3/constraint.py", line 907, in prepare
    return super(BaseCascade,cls).prepare(obj,solver)
  File "/tmp/.mount_FreeCAF9bJ5F/usr/lib/freecad-daily/Ext/freecad/asm3/constraint.py", line 895, in prepare
    h = func(*params,group=solver.group)
  File "/tmp/.mount_FreeCAF9bJ5F/usr/lib/freecad-daily/Ext/freecad/asm3/system.py", line 233, in addPlaneAlignment
    d, pln2.origin.entity, pln1.entity.entity, group=group))
AttributeError: 'int' object has no attribute 'entity'
zawieszenie.fcstd
(34.77 KiB) Downloaded 14 times
OS: Ubuntu 18.04 LTS
Version: 0.17.5235 (Git shallow) AppImage
Build type: None
Branch: LinkStage3
Hash: ccaa87e12aaadbd3106607fc503542a863b742da
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.2.0
Locale: Polish/Poland (pl_PL)
easyw-fc
Postby easyw-fc » Sat Jun 09, 2018 8:18 pm
Thanks a lot! it works perfectly!
I see your result ... this is strange...
I'm going to see if I can find the e-mails I had with Jean Marie about our VBO testing to get some tips...
BTW I made some test also on STEP with external references and the results are very good... an other very big STEP ahead!
Thx
Postby Kunda1 » Sun Jun 10, 2018 4:10 am
BTW, will Assembly3 solve issue #2462 ?
